The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
Tito L. Oracion
Quote from: Magnon on April 03, 2009, 05:49:53 PM
Some answers to your questions,
1. How to amplify small source of watts?
Build a guide EM field to compress and suck the energy from the environment.
The environment is full of charges and ions, and spacetime itself has an electric nature.
Collect and compress this energy.
If you build a nested cylindrical EM field, then the charges, that are under the influence of the nested EM field, are sucked into system and can not escape. Use this collected energy / spacetime compression .Spacetime compression means that the local time is curved, compared to average spacetime on earth surface.
2. How to make a controlled loop accumalaiting energy?
When you play with a microwaves, the wavelenght is on cm range. This means that one turn antenna can be used to transfer a lot of energy ( collector on TPU ). This is what happens with a TPU.
There is a phenomena that explains the TPU and it is a magnetoacoustic resonance effect, that is known since 1960. But if you tune this frequency so that it creates a nested cylindrical field without subharmonics ( prime numbers of waves on devices circumference ), it starts to suck energy from the environment nearby.
--Magnon
Hi sir good day!
Theoretically your correct, can you demonstrate a simple example sir  ;)
God bless
otits
Tito L. Oracion
Quote from: giantkiller on April 03, 2009, 10:58:57 AM
The magnetic field around the conductor is a tube. ;D
--giantkiller.
oh i see i'm learning sir  ;D
you're great  ;) therefore no need for vacuum tubes  ;D
otits
Magnon
Quote from: Tito L. Oracion on April 04, 2009, 06:56:35 AM
Hi sir good day!
God bless
otits
Here is a few example about this phenomena.
In a Roschin & Godin SEG replication project there was measured a nested EM field around the SEG, see the picture. There was 23 rollers around the stator.
Lakhovskys multiple wave generator, he was using nested loops that creates a nested EM fields.
The idea is that when a phase changes in a cylindrical formed wall, the charge will move to next inner wall. For example electron, when it feels that the wall charge changes to be negative, will move to next inner wall, that has a positive charge. This way you can collect and compress charges from the environment nearby.
--Magnon
Bruce_TPU
Quote from: forest on April 02, 2009, 01:39:12 PM
maybe
E) divide signal into harmonics and let them grow indepedently, then collect all
Hi Forest,
Yes, that is a part of it, but you subtract them (IF's) down, and then you must understand how to use them to create power.  To understand that, look to Tesla and his work in Colorado Springs and his discovery there.
We need to understand that there is a magnetic component attached to "certain" frequency's that are much stronger than a normal mag field.  Create hundred's of thousands of these magnetic kicks within the circumference of the collectors, going in both directions, and you are using Litz for your collectors, and ....
It is amazingly engineered, eloquently designed.  Sophisticated beyond it's years in operation, but relatively simple in parts.  One Mag loop antenna plus three VHF Triode Tube amps.  Some filters, caps and resistors and that's it.  DC Bias the collectors.
We are building...
Tito L. Oracion
@ magnon good day !
thank you very much sir  ;)
God bless
otits
