bob.diroto
Quote from: tao on June 30, 2006, 04:01:50 AM
I found this Peter Lindemann video on video.google.com and cut out this VERY IMPORTANT clip which explains everything needed to generate the KICKS. Just like my last post says about Tesla, Gray, and Bedini.
WATCH THE CLIP!!!
Excellent!! It definately is a MUST WATCH.
Esa Maunu
I have made some corrections to my excel table.If you use a wire that has a very high permittivity, say with mumetal wire permittivity is max 350.000 ,this means that if you have a frequency of 6 kHz, the wavelenght in a medium is 8,44 cm , and if the coil circumference is 8,07 cm, there are 3.0 waves around the circumference,if the wire lenght is 1000 cm.
I will send a new version of my Excel table ( bifilar coil ) today to my web-site.
http://www.kolumbus.fi/esa.maunu/
Esa
gn0stik
Quote from: bob.diroto on June 30, 2006, 04:50:52 AM
WATCH THE CLIP!!!
Where do we get that book! It's gone from amazon, not available. :(
Ken Adachi is selling them at educate-yourself.org, but the page is old, who knows if he still has them.
Elvis Oswald
Pay close attention to the details of the experiments Tesla did with the spark-gap.
That's why I suggested (a few pages back) that bob.d try to disrupt the discharge on his ignition coil / spark plug set-up and place a coil over it and see if he sees the same effect Tesla saw...
gn0stik
Quote from: Elvis Oswald on July 01, 2006, 01:31:47 AM
Well, if the caps discharge instantaneously over a sparkgap on a large enough piece of wire that would explain why the charge jumps the wire, because it wouldn't have enough time to get to the end of the wire. However I'm unclear as to how to force a cap to do that. Do you simply charge the cap to a high enough potential to be able to jump the gap, At which point it dumps enough of it's energy to create a bunching effect in the control wire, which then dumps the bunched electrons at right angles into the coils?
By the way can anyone make out the number of the second patent in that video? The first one is US4595975, which I have attached.
Also attached is the circuit in the first of the two gray patents discussed in the video.
I have not attached the second picture in the patent as I don't think that SM's device uses a conversion element like gray's. I think the arrangement of the coils does that. I think that both devices perform similarly, however one is defenitely putting out conventional electricity, whereas the other is obviously not(gray's), as noted by the fact that you can place your hand in water with a powered device without being shocked with gray's device, and SM clearly states that you could have your heart stopped with his.
