Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
Groundloop
Group,
Attached is a proposed circuit for testing a looped configuration of TR's setup.
If the coil gives out more (power + back emf voltage) than was put into it,
then the battery will charge. If not, then the battery will discharge.
[EDIT-1]  First version did not run very well so I have changed the trigger coil setup.
[EDIT-2]  The attached version runs very well.
[EDIT-3]  Tested the unit with an external function generator from 0 - 500KHz. (All waveforms, all duty cycle.)
              No charging of battery on any frequency or duty cycle.
The connected lead acid battery is NOT charging up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Groundloop.
powercat
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
gotoluc
Well this new video is now demonstrating a very possible amp meter problem since at a higher scale his meter is reading serious under unity and when he reduces his pulse width a little to use his meters lower scale it show over unity :-\
I was suspecting something like this. He should of used the same higher scale when he turned down the pulse width since it would of still showed a true results then using a lower scale at its maximum.
He has not replied to the request I made yesterday of coming to see his unit.
Luc
gotoluc
Come to think of it, he cannot use a DC amp meter to measure the power coming out of his batteries as the power is being turn on and off at 10KHz (I think he said) and a DC meter can only measure a constant flow (not turned off and on)
His meter is probably not defective as he thinks, he is just not using it in the correct way.
I now retract my belief that his unit is over unity.
Luc
gotoluc
Quote from: Groundloop on April 25, 2009, 09:47:39 AM
Group,
Groundloop.
Great effective and simple circuit Groundloop ;)
Thanks for taking the time to build and share your findings. Like if you did not know the outcome ;D
Your help is always appreciated... I wouldn't mind your opinion on his last video since I wouldn't want to give out incorrect information.
Thanks for helping as usual.
Luc
