Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
chrisC
Quote from: Groundloop on April 27, 2009, 08:35:19 PM
@chrisC,
Based on the measurement in his videos, yes, you are correct.
I have modified my test circuit with a hexfet (IRF840) instead of a regular transistor (2N3055).
It seems that I can not loop the output directly back to the input because the internal resistance
of the lead acid battery is so low that it is a short circuit for the captured back emf.
So if we want to do a full looped back test circuit then we will need a impedance match at the output
and to the input.
Groundloop.
@Groundloop
Thanks. As Tommy pointed out, at 30% duty cycle, the OU efficiency is even better!
Hence, giving back the % that will allow the loop to recharge the batteries will indeed make it perpetual and still do more than useful work!
I assume we can capacitively couple back some of the back emf charge. It can be done since Tommey now has proved his point.
cheers
chrisC
chrisC
Quote from: nievesoliveras on April 27, 2009, 08:40:16 PM
@all
My question is:
Is he using an in circuit PWM ? Or He is using an outside PWM ?
If the PWM is from the outside then there is not OU.
Jesus
The PWM is run from the same 12V in the system. That's where the 168 ma is measured. What is the point otherwise?
cheers
chrisC
nievesoliveras
Quote from: chrisC on April 27, 2009, 08:44:39 PM
cheers
chrisC
Thank you @chrisc
Does you or anyone has the circuit for the whole thing with the PWM included?
Jesus
chrisC
Quote from: nievesoliveras on April 27, 2009, 08:48:38 PM
Thank you @chrisc
Jesus
Conceptually, it's very simple. 4 fast diodes of the 4007 type, a single primary of a coil transformer, fast drivers for the 3055 power transistor and large caps rated 200V to collect the back emf. The PWM is probably any single chip PWM capable of 10K.
why no one discovered this back emf captured to a capacitor and filtered for useful work beats me?
cheers
chrisC
nievesoliveras
Quote from: chrisC on April 27, 2009, 08:54:23 PM
cheers
chrisC
The thing is that we are looking for the circuit that has a PWM and is working in order to replicate it. The one kindly posted by @groundloop here: http://www.overunity.com/index.php?topic=7241.msg174681#msg174681 does not have the PWM circuit or chip number included.
Jesus
