Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
Quote from: CRANKYpants on August 06, 2009, 05:12:18 PM
IN A FEW DAYS WE SHOULD HAVE A FACTORY MADE CORE WITH OR WITHOUT WINDINGS SO ANYBODY THAT WANTS ONE CAN HAVE IT.
Do you have an estimate cost with and without shipping to europe?
minde4000
How does it work coupled with perpetia generator Thane? Whats the output and prime mover reaction?
Also what is the cost of your transformer? (and where to find discount coupons :P)
Tnx
CRANKYpants
Quote from: Kator01 on August 06, 2009, 03:09:36 PM
Broli,
#518 on page 52,  read and understand first what I am talking about. Then you should read Thanes first answer #563 on page 57.
THANKS FOR POINTING OUT THAT POST BECAUSE THE REACTIVE POWER CALCULATION IS NOT CORRECT ALTHOUGH THE OUTCOME IS VIRTUALLY THE SAME. IT SHOULD BE...
THE REACTIVE POWER IS = 120.4 V x 0.006 A x sin 87
                                  = 120.4 x 0.006 x 0.999
                                  = 0.72 VAr
THE REAL POWER IS: 120.4 V x 0.006 A x 0.05 = 0.036 W
BECAUSE THE VOLTAGE AND CURRENT ARE OUT OF PHASE BY 87 DEGREES ONLY 3% OF THE REACTIVE CURRENT IS REAL.
T
Now the point is this :
The mere assumption that driving the primary coil of a transformer with no load at the secondary is for free is simply wrong.
I FULLY EXPECT THE PERFORMANCE OF THE BI-TOROID TO INCREASE SO THAT EVEN IF REACTIVE POWER IS USED IN THE PRIMARY - THE SECONDARY OUTPUT WILL SURPASS IT.
ALSO IF WE ARE USING REAL CURRENT AND NOT REACTIVE CURRENT THEN THE CURRENT ACTUALLY BEING DISSIPATED IN THE PRIMARY IS 3% OF 0.006 A OR 0.00018 A - IT'S NOT FREE -BUT...?
QuoteI will not repeat myself.
Kator01
RATS! - I FOR ONE NEED AT LEAST ANOTHER 999 REPEATS BEFORE I GET IT!  :P
T
CRANKYpants
Quote from: broli on August 06, 2009, 05:14:25 PM
SHIPPING IS FREE;)
ALL YOU NEED TO DO IS PURCHASE 2 ROUND TRIP TICKETS AND I WILL DELIVER IT IN PERSON FOR FREE - WHERE TO SIR, FRANCE, GERMANY, ITALY?
T
Kator01
Hi T,
If this is what you will get - only then will things get serious here. I hope this will be the case.
No Rats anymore.
@Broli : Your answer tells me that you have not understood my point. It may be because of the fact that I miss ( as a german ) the correct grammer.
Before you ever measure a device under load the first thing you do is to measure the idle-mode and determine real power in joule or wattseconds to generate appearant power. I do not know how to make it more clear.
At least Thane has got the point although he is not expressing this directly
Regards K-Rats
