fuzzytomcat
Hi,
HAPPY NEW YEAR EVERYONE!!!!
I'm going to have another demonstration set up and am inviting all members and guests again with hopefully those that missed last weeks "LIVE" interactive streaming broadcast of this threads Rosemary Ainslie COP Heater Circuit.
This also provides a opertunity for anyone to ask questions in real time inside the "on line" chat room and talk to myself or others that are involved with the project in some way or hope to be.
"LIVE" NEW YEARS DAY (USA) January 1, 2010
at 12:00 PM (noon) Pacific Standard Time or GMT -8
Open Source Research and Development -
http://www.livestream.com/opensourceresearchanddevelopment
Best Wishes,
Fuzzy
;D
Rosemary Ainslie
Quote from: fuzzytomcat on December 31, 2009, 11:20:47 PM
Hi,
Best Wishes,
Fuzzy
;D
Thanks Fuzzy - can't wait.   :-*
fuzzytomcat
Hi everyone,
I see that many of the members and guests here have shown up on my   "Open Source Research and Development" channel showing this threads circuit in operation in various stages of oscillation. The last show was the "Preferred Mode Of Oscillation" that includes the subharmonic modulation that we have deemed necessary for the COP> 1 results which we prefer and must be forced by careful adjustments.
The January 9, 2010 show was the best showing this "Preferred Mode Of Oscillation" in the first 2 hours of the 5 Hour long tape ..... ( search-able video timer shown with time left )
Open Source Research and Development - January 9, 2010
http://bit.ly/4XVsAj (link)
TIME
4:45 _ 24.68 to 24.69 VDC Starting Voltage
4:01 _ 24.72 VDC Highest Voltage Reading
4:00 _ 24.71 VDC
3:33 _ 24.70 VDC
3:17 _ 24.69 VDC Return to Starting Voltage
2:54 _ Temperature Readings
2:52 _ 24.68 VDC
STARTING TEMPERATURES READINGS -
139 Degrees F - 10 ohm load resistor
161 Degrees F - Mosfet
113 Degrees F - .25 ohm shunt resistor
2:54 TEMPERATURE READINGS -
138 Degrees F - 10 ohm load resistor
158 Degrees F - Mosfet
107 Degrees F - .25 ohm shunt resistor
5.27 Watt Load ( Load Resistor ) on circuit during operating throughout the time length indicated.
I hope anyone interested might check it out because non stop it's quite interesting .....
Fuzzy
;D
guruji
Hi Fuzzy very well done. I think now you should move experiments to those water heater elements  ;)
Thanks for sharing
Ken the Great
So, do some useful work with the 5 watts.
Light a 5 watt lamp. I would be interested in seeing that video.
I do not trust measurements for proof of the input/output, and never will.
Simply use 2, 24 volt batteries, one hooked directly to one 5 watt lamp. Time that and watch for a drop in the battery voltage.
Then use the other 24 volt battery with your circuit and one 5 watt lamp.
Will the battery last longer?
Have Fun    8)
