explanation of why mass slows time.
Started by nitinnun, June 27, 2009, 10:59:48 PM
Judges
Sir,recent work w/GR and SR (quoted below
, we may be certain that gravity propagates much faster than lightspeed.
End Quote
For your consideration
Joe in Texas
Judges
re: Speed of Gravity
How can black holes have gravity when nothing can get out because escape speed is greater than the speed of light?
Joe
sm0ky2
Quote from: Judges on July 11, 2009, 05:06:06 PM
Joe
The gravitic field, much like the magnetic field, propegates INSTANTLY...  the same moment the mass becomes present, the gravitic field is already there.
Its 'effect' on objects may take some time, defined by that objects particular moment of inertia in that particular gravitic field. (defined as the combination of the effects of both mass' gravity, though in practice this measurement includes friction and other factors)
Therefore, there is no "speed of gravity".
The so-called "escape velocity" for a mass (such as a photon) to escape the gravity of a black hole is theorized to be greater than the speed of light.
While this theory sounds solid, and is backed-up by the fact that we observe no visible light eminating from the masses we have dubbed "black holes" - there are some anomolies that present themselves.
Such as - an infinite build-up of energy inside the event-horizon, nearing he center-of-mass, in the form of (relatively-motionless) light. The ammount of energy is far greater than that presented by the gravitational force, which would result in an explosion of the black hole itself. We dont see black holes exploding, and thus black holes are an anomoly.
Time, however, plays no part in this except to demonstrate the relative velocity of the light from OUR perspective.
inside the black hole, the light would not be moving at all. and thus the "speed of light" is relative only to US - the observer.
My theory is that::
If light went directly into the black hole at the speed of light, then instantly was halted to an abrupt stop, or even slowed down to a fraction of its velocity - it would convert directly into heat (or other form of energy) and there would "be no light" to escape.
although, im not entirely convinced that 'black holes' are exactly what we think they are.
Judges
Chosen at random(first click) to respond to:sm0key,,salutations,greetings,ab,libbum
under:FORUM START:Unanswered Posts:Seems I have OVERLOOKED this wonderful Feature of this Forum;,,START MENU
DUHHHHHH!!
MAKE THAT A 64 YEAR OLD DUHHHHH????
If I live long enough I will enjoy many more wonderful features.
Finally got a camara that "SAYS"upload to YouTube,,,but I haven't found that feature yet.,,,may have to hit a comera forum for a bit ,,,it is a relativly cheap,Phot Shot A495
We Will See How Well It Holds Up To Plasma.
HA!
Quote from:The gravitic field, much like the magnetic field, propegates INSTANTLY...  the same moment the mass becomes present, the gravitic field is already there.
My theory is that::
Ouestion>
Have you given any more thought to what black holes might be??
cheers
Joe in Texas
First Random Post"Folder"Un-Ending Search for anti gravity"
Is this the Holy Grail?
Yes.
But it is impossible by today's standards,,many small steps connected correctly together would possibly NOT connect to OVER-UNITY,instead,a new physics?Any,repeatable,recordable over time,annoyingly,is Acepted Scientific Study's;In other Words Good Science.
I leave the rest to you
cheers
Joe in Texas
EDIT:on to next"Unanswered Post" at Forum Start.
Is that to much to ask?
mapsrg
the time it takes to travel from a to b is determined by the distance travelled.For a wing of an aircraft distance travelled by a particle under the wing is shorter than that travelled over the wing.Thus the mass of the wing has caused an acceleration which may be observed as a slowing of time as the distance to travel around the mass has increased on one path and remained the same on the path under the wing.If this is true mass does not slow time it accelerates it ......
