Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
Bulbz
Quote from: WattBuilder on October 29, 2009, 12:41:41 PM
@ All Readers,
I have been repeatedly posting it does to a point.
Let it be very clear the servo adds energy by shifting the magnet weight.
It adds energy only to a point. The array of magnets allows it to go past that point. Servo say “Point X” and now with the array energy “Gain Point Y”
Child on a swing… Say a five-year on the swing can only reach to an 8 o’clock position the child can not reach to the 11 o’clock position without help like the array.  If the child can reach to the 11 o’clock on his own then I’ll will say that’s one super baby! Then I will check if that child is on steroid’s.
Hey Howard, I've got an idea !
Why not remove the magnet array and do the experiment again, just to prove a point that it's not just simply the "Child on Swing" effect of the shifting weight.
I'm pretty sure there is gain as the servo assembly shoots through the magnet array. As I know from my experience with servos, that one servo has not got enough kick to swing that pendulum on its own, while it's mounted in that way.
I think you are doing a great job, and I think your idea has great potential.
Best regards.
Steve Ancell.
powercat
Howard
Once you get to the point where the device is running itself,
will you allow an independent team to visit you and inspect your device ?
cat
markdansie
@Bulbiz ,
what an excellent suggestion. So WattBuilder run the same experiment without the magnetic array at the top. How is easy is that. At least its a start. So it should not be too hard to organise that.
Failing to do that you have to demonstrate the device with no shift in weight, other wise you have no credability. Any amount of semantics does not replace good practical demonstrations.
@Stefan
it appears the smot ramp does have no resistance...think it through carefully why this is so. I think Spoondini has hit the nail on the head.
This is a rather fun thread and in some ways has many people thinking. However good questions and suggestions have been raised. They need to be addressed to progress your development of the device.
Kind Regards
Mark
Cloxxki
Quote from: Cloxxki on October 29, 2009, 03:28:49 AM
A relatively simple "proof" as far as video proof goes, would perhaps be to put the array on a vertical rail. Let's say you repeat the video as it was, with the addition of an assistent lifting the array out of range for the servo driven magnet. Can you use the servo to load the oscillator as concerns offered?
Hey, I proposed that first! :-)
But thanks for supporting the idea.
noonespecial
I have an idea for a purely mechanical solution to reorient the drive magnet. If I get time I will post.
