Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
Asymatrix
Wouldn't it be possible to eliminate the servo if you simply used a drive shaft through the magnet mount arm and linked it to a gear which would mechanically engage to flip the magnet once it passes the top magnet array? It would create a little bit of drag, and you'd need to use a small magnet or clasp to keep the servo magnet in place while it passes the top array, but by the looks of the momentum, it seems like it could work.
WattBuilder
Hi Stefan,
Sure, I may be able put up a video explaining the magnetic array. It can work linear as well too. I don’t have the time in the near future though. I‘m getting closer to power testing on the YOG.   ;D
For now attached is an example explaining the force values behind it.
Best Regards,
Howard
YOG Gain Video  http://www.youtube.com/watch?v=Cq5r08eqgsk
WattBuilder
@PowerCat
Sure no problem but I think the replicators will beat them to it.
@Asymatrix
In theory it should. Your right.
@Other guys,
I’m not going to risk throwing it off just for your curiosity and setting me back. I’m telling you what’s going to happen. If you guys don’t believe me then it’s your problem not mine? Respectfully.  ;)
Quote from: WattBuilder on October 27, 2009, 11:25:45 PM
@MileHigh
Ummm,  Of course I did.. I do have it right here you know.
Howard
WattBuilder
@All
Theirs still some of you who don’t fully understand yet. That’s okay I blame myself for not being clearer. Hopefully majority of you guys are past the point of the “one cycle video”. If you’re not past that point then, take a look at OC’s posted video on this thread. If that does not do it for you. Then go to a hardware store buy two magnets, a nail and a wooden stick. Glue one magnet to the end of the stick then take the other end and put a nail through it. Find something you can nail it to. You just made a pendulum. Get a marker and simply mark where you start and stop just like the videos. Then try it with out the magnet. You just proved energy gain from magnets.
For those guys that are past that point but can’t make that connection. Let’s try to look at it instead of energy lifting weights. Let’s look at it as Time of Production. Try to focus on what happens to the gain magnetic energy?
In my Proof of gain video, you see the YOG swing around but can’t figure out how to separate the energy from the servo to the magnets gain energy.
Now in that video you see me stop the hand controller and talk then start again. Did you notice how the YOG was still in production power until the end of the video? Can you see how no input power was entered into the YOG.
Okay now you may think It’s just the kinetic energy getting released from the servo. Yes it is and also releasing the gain magnetic energy.
If you picture the YOG with array and without array. The YOG with the array will take longer to slow down to a complete stop turning a turbine.
Ok almost see it?
Lets look at that one cycle video. One with array one without. Now picture a bicycle upside down. The pedal is now the lever part of the YOG. The array lever turns longer causing the bicycle wheel rotating for a longer time. Time of Production vs the lever using the rock.
Did that help guys?
For the guys past that point and sees what I see.
Be patience…. On how to make the YOG better. Lets focus on how the can get the technology available to the world first then build from their. The faster the technology is out the faster we save lives.
Howard
spider4re
Congratulations Howard. Please don't get distracted by detractors.
