Romanian SECRET Technology which WORKED ! Lots of OU.
Started by spacetrax, September 20, 2009, 05:11:09 AM
markdansie
@Lucian,
you have had several requests of perhaps showing your replication or if you would be happy to have your motor (replication) tested independently. You have not given a straight answer, in fact your answer would rate highly as propaganda.
The trouble here is , we do appreciate your efforts, but just remeber there are some smart people here.
most of what you talked about has been well researched.
So I get back to my questions,
1. Are you happy to show a photo of your replication? If not, why not.
2. Are you happy to have it tested independently for the OU you have claimed (I can arrange this)
i am sad you will be leaving us. I havnt had so much fun since Mylow.
Kind Regards
Mark
teslaalset
Lucian Stefan
Quote from: markdansie on September 30, 2009, 03:14:39 PM
Mark
Do not try to blackmail me.
I’ve already stated that the information and demonstration devices that I've created are my business and I’m not going to make charity donations. Demonstrations are made exclusively for military applications. You do not order me what to present to the public or what to do with the information I posses.
Explicit images contain technical information and technical information are not free nor for civil market sales. Images that do not contain technical information (for example a case of electric motor that is not seen nothing inside) are without value and it can be anything you want to imagine.
You states that you are not stupid. Yeah, me neither .
rotaryfcg
i've found something interesting , someone could do some translation if needed.
"Instalatia aceasta de atac geofizic presupune asadar emiterea de fascicule electrice de semne contrare cu deplasare complementara si care sunt purtate si accelerate pe unda radio sau pe „ghid de unda radio”.
Transportul ionilor se putea face pana la nivelul ionosferei, creandu-se de acolo adevarate „baraje” de sarcini electrice, acestea fiind realizate prin incarcarea straturilor respective pe un anumit volum, cu electroni, ioni pozitivi si negativi. In straturile ionosferice, ionii sunt negativi.
Fata de aceasta situatie, savantul Nicolae Moraru a inteles ca mai intai ar trebui ca instalatia sa lucreze pe canalul negativ, creand o supraincarcare pe acest semn, si abia apoi sa declanseze asupra ionosferei canalul pozitiv.
Arma aceasta a putut fi utilizata in mai multe moduri:
    * arma climaterica-utilizarea fasciculelor electrice in scopul de a crea o puternica supraincarcare electrica intr-o anumita zona a atmosferei joase, avand drept efect fortarea unei deplasari de aer si mai ales de umiditate dintr-o anumita zona, catre o alta, potrivit diferentei de sarcina electrica dar si de presiune; in acest fel, arma poate fi utilizata mai ales in zonele care se afla in relativa apropiere a unei coaste, deci pentru teritoriile care au deschidere la mare. Cu ajutorul acestei arme de transport electronic, se poate crea un dezechilibru atmosferic de asa natura incat sa fie colectata umiditatea atmosferica de deasupra zonei maritime si din apropierea coastei, pentru a fi deplasata cateva sute de kilometri in interiorul tarmului, unde se romania-arma-suprema-128893vor produce precipitatii masive, complet anormale si care pot provoca importante prejudicii.;
    * arma climaterica, dar de data aceasta prin creearea unor regiuni de atmosfera foarte incalzita (prin descarcari electrice), ceea ce creaza mai departe un dezechilibru termic si barometric major, fapt care declanseaza puternice furtuni si chiar tornade sau altfel de manifestari climaterice extreme; pentru aceasta arma este reglata la o emisie puternica;
    * arma antiaeriana si anticosmica- destinata distrugerii prin sublimare a apartelor de zbor aflate in atmosfera ori in spatiul cosmic; nu este nici o greseala in text-„sublimare”, pentru ca temperatura la care este brusc ridicat corpul tintei este atat de mare, incat il sublimeaza, nu-l topeste!
    * arma sol-sol- care poate actiona pornind de la simplul regim de arma antitanc sau antiinfanterie si pana la arma de nimicire in masa, cu efecte de genul „Tunguska-1908”.
Importanta strategica a unui asemenea sistem de armament este neindoielnica, iar capacitatea acesteia de a fi utilizata in cele mai variate situatii tactice face ca arma geofizica de tip Tesla-Moraru sa devina un fel de arma universala, ce poate fi adaptata pentru orice aplicatii!
In 1967, Romania putea dobori… sateliti!!
Pentru apararea Romaniei impotriva oricarei agresiuni externe, dar in special impotriva Uniunii Sovietice, pana in 1967 a fost realizata o arma de o factura cu totul si cu totul speciala, denumita „instalatia elctronica de aparare antiaeriana si antisatelit”.
Era vorba despre un procedeu si o instalatie de aparare antiaeriana prin intermediul careia se creau baraje de sarcini electrice in straturile inalte ale ionosferei sar si in paturile inferioare ale atmosferei, dupa necesitate.
Astfel de baraje erau obtinute prin incarcarea straturilor, pe un anumit volum al acestora, cu electroni, pozitroni si ioni. Se stie ca, pana in 1963, apararea antiaeriana, antiracheta si antisatelit era bazata exclusiv pe utilizarea energiei cinetice (de impact) a unor proiectile realizate din materiale solide (metalice), transportate pana la contactul cu tinta prin intermediul unui mijloc de propulsie, fie propriu fie al unui aparat purtator.
Aceste mijloace de aparare antiaeriana, antiracheta si antisatelit sunt fatalmente foarte limitate- ca raza de actiune, in eficienta lor, in costurile si tehnologiile pe care le presupun, periculozitatea manipularii acestora- si, in plus, pot fi detectate si contracarate de catre inamic cu destula usurinta…
Mijloacele de aparare de la nivelul anului 1963 ( ca si de acum) constau in instalatii radar destinate descoperirii tintelor der si ghidarii proiectilelor catre aceste tinte. Astfel de sisteme de aparare sunt costisitoare si ineficiente, mai ales daca inamicul lanseaza grupuri de rachete insotite de bruiaj radar, rachete anti-radar etc.
Un alt mare dezavantaj este legat de necesitatea unui timp de reactie cel mai adesea foarte scurt. Adica, de la momentul in care radarul a sesizat mijlaoacele de lupta inamice si pana la momentul producerii atacului propriu-zis, sistemul de aparare trebuie sa realizeze identificarea certa a pozitiei inamicului si trimiterea mijloacelor de contracarare a acestuia, care, la randul lor, trebuie sa aiba timpul necesar pentru a ajunge la tinta. Din toate aceste cauze, apararea antiaeriana clasica este costisitoare si ineficienta, fiind cel mult realizat pentru distante si regiuni limitate.
Nicolae Moraru a atras atentia asupra fenomenului exploziei meteoritilor de mare viteza pe timpul in care acestia strabat ionosfera (deci, nici macar nu au intrat in cadrul straturilor relativ dense ale atmosferei), demostrand ca fenomenul de explozie amintit este cauzat de catre intrarea meteoritului cu foarte mare viteza in cadrul unor paturi intens ionizate.
El a gandit sa aplice acelasi fenomen si pentru satelitii inamici, atat doar ca in acest sens era necesar o amplificare deosebita a gradului de ionizare din cadrul paturilor superioare ale ionoisferei, pe care in mod obisnuit le parcurg satelitii artificiali. Evident, aceasta ionizare artificiala a straturilor inalte ale ionosferei trebuie realizata artificial cu ajutorul unei instalatii aflate la sol.
Invazia sovietica din 1968-volatilizata de Arma Suprema!
In anul 1908 a fost observata o puternica descarcare electrica pe cer, urmata de formarea unui glob de foc care a explodat formand unde de soc de o putere uriasa. Fenomenul s-a petrecut intr-o regiune pustie aflata in nordul Siberiei. Cercetarile la fata locului au pus in evidenta urmarile produse de unda de soc si energia termica dezvoltata cu acea ocazie.
Cercetand configuratia undei de soc, oamenii de stiinta au constatat ca este similara aceleia produse de o bomba nucleara care a explodat in aer la o anumita inaltime. S-a gasit urma epicentrului si felul in care s-au dezvoltat si deplasat undele de soc concentrice. Cum arme atomice nu existau in 1908 si nici urmele de infestare radioactiva nu au fost gasite, a fost clar de la bun inceput ca explozia nu a fost produsa de o incarcatura nucleara. „Dar atunci ce a produs-o ?”- a fost intrebarea fireasca pe care si-au pus-o oamenii de stiinta de pretutindeni.
Pana la urma s-a stabilit, fara prea mare convingere, ca ar fi fost vorba de explozia unui meteorit… Ipoteza este complet neverosimila pentru cei care sunt in cunoastinta de cauza…  Explozia unui meteorit la o altitudine atat de joasa… ma rog, sa zicem ca s-ar putea petrece, dar lasa urme evidente si nenumarate fragmente de diverse dimensiuni, ca si un adevarat nor de pulbere in paturile superioare ale atmosferei.
Tocmai pentru ca nu a fost nici vorba de asa-ceva, unii oameni de stiinta au pretins (in mod pertinent, altminteri)  ca a fost vorba de o cometa sau un fragment de cometa, care este compus din gheata, deci prin volatilizare si explozie era normal sa nu se mai gaseasca nimic… Mda, dar „cometa” asta nu este un obiecintunecat si imprevizibil, asa cum este un meteorit din roca sau metal, este un fragment din material care reactioneaza energic fata de vantul solar, ca sa nu mai vorbim de faptul ca se face praf cu mult inainte de a ajunge in straturile dense ale atmosferei. Ori, in cazul nostru, explozia s-a cam produs prin regiunea medie a troposferei, nici macar in stratosfera…!
In fine, prin 1968, adica la 60 de ani de la experimentul impresionant care a fost realizat de catre Tesla, armata romana se afla in fata iminentei unei invazii armate sovietice, de „restabilire a ordinii” in cadrul conducerii de partid si de stat de la Bucuresti. Cu acea ocazie arma inventata in 1963 si realizata de mai multe prototipuri experimentale pana in 1967, a fost testata in conditii reale de lupta…
Cu ajutorul acestei arme s-a reusit volatilizarea unor tancuri si a unui avion sovietic. S-a lucrat cu jeturi electrice care, puse in contact cu corpul sau in regiunea tintei, dadeau o temperatura de ordinul a 15.000-20.000 C la care nici un metal cunoscut nu mai poate fi nici macar in starea topita, ci se volatilizeaza! Adica trece din starea solida direct in starea gazoasa…"
by Lucian Cozma; same as Lucian Stefan? ::)
markdansie
hi Lucian
It was never in my interest to blackmail you. Blackmail implies I will do certain actions to harm you if you do not do as I suggest. That is not the case. i was merely saying can you support your claims in anyway?
I would never want you to disclose this publically if you do not want to. However I do know organisations (non milatary) who would be happy to test your device, sign Non Disclosure Agreements etc etc to fully protect you.
I cannot see why a self running or OU magnetic motor would be such a threat.
if you need reference about my discressions please send me a private email.
markdansie@bigpond.com
if you have nothing, that is ok as well and enjoy your milatary service.
Kind Regards
Mark
