Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
chrisC
Quote from: ltseung888 on September 06, 2010, 04:47:33 AM
Building the first FLEET product
If the charging time is 3 hours and the lighting time is 6 hours, we have a clear winner!  ...
*** The unit was NOT built nor manufactured nor marketed by me.  They might have read the information in this forum or attended one of my seminars or shows. ***
Er, No. You'e the loser and you copied their 'toy' idea! Bill already told you your stuff is so primitive; his JT experiments far exceed what your little 12 LED flashlight is able to produce.
What are you selling? I still don't get it.
cheers
chrisC
ltseung888
The US$1.5 solar recharged LED
I turned the device on all night in a dark room.  The three LEDs went dim but still showed light.  It was obvious that the battery was drained to a low level.  That was over 12 hours continuous lighting.
This morning, I put the device at the window under bright sunlight for 3 hours as suggested by the retailer.  Sure enough, the LEDs were bright again.  There was no noticeable degrading.
Bill et al have managed to light hundreds of LEDs for days with one AA battery.  Our engineers should be able to light 12 LEDs for 6 hours on the Solar recharged LED device.  I am now confident that even if the lighting "shifted the lead-out energy resonance condition" somewhat, we should be able to correct the condition with the solar panel recharging.
I know for sure that the standard JT with frequency at over 100,000 Hz could last for days.  If the frequency were reduced to 100 Hz, the energy consumed should be lowered by 1,000 times.  The one second flashing JT is still flashing in my bedroom.   It might continue doing that past my dying day.
The lighting or electricity supply Industry may undergo a revolution with the LED technology.  The steps may be:.
1.   LEDs to replace traditional lamps
2.   LEDs will have Joule Thief Circuits
3.   LEDs will have enhanced windings on the JT circuit.
4.   LEDs will have enhanced JT windings tuned to lead-out energy resonance
5.   LEDs system will not drain energy from the grid but will supply energy back to the grid!  The energy is the lead-out energy from the environment (electron motion energy).
Engineers can start working on steps 1-4 now.  The basic components are here.  Poor Countries with good sunlight will never need to work in the dark ever again.  This is even before we master the 1KW FLEET generator!  Is God working miracles again???
chrisC
Quote from: ltseung888 on September 06, 2010, 10:55:35 PM
OK, let's recap:
20KW Lead Out Generator - promised, still working on it. Needs 'investment'
5  KW Lead Out Generator - easier to build, less investment needed, coming...
1  KW lead Out Generator - will be available soon, teams are working on it, coming ...
50 W Lead Out Generator - Still working on it, should be a piece of cake ...
Solar powered LED - Finally success! But look
http://www.amazon.com/Solar-Powered-LED-Keychain/dp/B001T3UFJ8/ref=sr_1_32?ie=UTF8&s=sporting-goods&qid=1283830036&sr=8-32
Sorry, Tseung, you're too late!
cheers
chrisC
chrisC
Quote from: Paul-R on September 07, 2010, 08:11:19 AM
What's its curent draw, chrisC, you prat?
Paul-R:
Your British colloquialism is just about as good as your one liner understanding of electronics in boosting old Tseung's ego.
The point is, current is meaningless if you're using solar to support high efficiency LEDs! You're the ASSHOLE!
cheers
chrisC
