Bruce's Discovery, Tesla's Missing Link for his Unipolar Generator!
Started by Bruce_TPU, March 21, 2010, 07:22:45 PM
gravityblock
Bruce, I just realized, with my method you would still need to use 20 small pancake coils, and you want to use just a single pancake coil.  It would work with a solid disc that could wrap around half the length of a long cylinder magnet being formed by stacking many magnets together, but you can't wrap the pancake coil around the length of a long cylinder magnet.  The nickel coating on the neo magnets can replace the solid disc, so it's not a problem to stack many neo magnets together to form a large cylinder magnet/disc, then extract the current with an external circuit between the axis and at half the length of the cylinder at the periphery.  This increases your voltage and is the same as having a larger diameter magnet/disc.
Placing several magnets on the back of an 8 in. steel piece so you can use 1 large pancake coil is an excellent idea, but i'm not sure of the results.  The field will need to be uniform in all directions between the center and outer edge of the circular steel piece.
I will give this more thought, this is a good question.
GB
Bruce_TPU
Hi GB,
I have drawn it out crudely, to make sure you understand what I am meaning...
Thanks!
Bruce
EDIT:
Based on the thickness of wire, etc, I figure I can put about four (4) pancake coils between the magnets.  If it will work, or must it be a "single" magnet, rotating on it's axis??
gravityblock
Quote from: Bruce_TPU on April 03, 2010, 11:52:06 PM
Hi GB,
Thanks!
Bruce
EDIT:
I can't say if it would work or not.  It's an interesting concept.  I will run some quick tests on Monday to test this idea.  I don't think it needs to be a single magnet, as long as the field is uniform.  The domains of the steel should be aligned with the field of the magnets to create an uniform field between the steel plates.
GB
Bruce_TPU
Quote from: gravityblock on April 04, 2010, 05:28:06 AM
GB
That is what I am thinking also.  But... please let me know how your test goes tomorrow.  If it works, I will build it.
Cheers,
Bruce
pese
Bruce.
i think the steel plate will never become North polarity this way. Also not wuth an single magnet (this way)
Gustav Pese
