This device is the real self-running overunity?
Started by Arthurs, May 17, 2010, 03:45:15 PM
Arthurs
On the polarity of the magnet,Video author the return e-mail:
(B) is correct. I will double my efforts to up load a new video for you. This is a very difficult machine. It only looks easy.
What place is not easy?
Xu Yuan
ramset
Xu
A master can make the most difficult task look easy!!
After 25 years I am sure this man is a "Master" at making this work,
probably a lot of "tuning" and ever changing parameters to deal with.
Chet
PS
I hope he is a good teacher!
Thanks Grandma
e2matrix
I was always under the impression the side magnets were diametric in his setup.  Otherwise what good would it be to make them able to rotate?  I guess if they end up spinning it might add more power to the coils.  I was even more sure they were diametric when he showed the one with the drill motor as it was clearly diametric.  It seems it might be worth trying both ways.  Do we know if these large magnets are Neo's or are they ceramic or as it appears somewhat like speaker magnets?
   I think Skywatcher tried replicating this a month or two ago but I haven't seen any updates lately from him (energeticforum)
scotty1
Oh dear what a mess.... ;D
Ok I have just done an experiment to see what's going on.
I used a rotor that turns very easily.
Then I set up a magnet the same as "B" on the side of the rotor.
The magnet could also spin freely about its own axis.
Then I spun up a large copper disc over the edge of the magnet.
Result.
With the magnet the same as "B" the EMF generated in the copper disc CAUSED THE MAIN ROTOR TO START REVOLVING.
The magnet itself did nothing. It did not rotate on its own axis.
It was a normal speaker magnet.
So now I have to say that the magnet should be as "A" which makes sense according to the drill test that was shown in the videos.
If it is as "A" then the magnet is not rotating on its own axis so the coil will push it away and the force will not be directed to the main rotor as I saw in my test.
Hope this helps.
Scotty.
scotty1
Experiment No 2.
This time I replaced the speaker magnet with a stack of Neo's to make it like "A" more or less.
This time when I spun up the copper disc THE MAGNET STACK ROTATED.
It actually flew off my rotor.... ;D
The EMF in the copper disc caused the Neo's to rotate but not the main rotor.
So there you have it.
Scotty.
