Rosemary Ainslie COP>17 Circuit / A First Application on a Hot Water Cylinder
Started by Rosemary Ainslie, July 18, 2010, 10:42:04 AM
Rosemary Ainslie
Quote from: nievesoliveras on July 19, 2010, 10:22:00 AM
It is not my circuit I found it on page 9 and 10 of:
http://www.scribd.com/doc/26240411/PROVING-OVER-UNITY-THE-HARD-WORK-OF-MANY-DEDICATED-OPEN-SOURCE-MEMBERS
But I can make a list of components if you post a higher resolution copy.
Jesus
Jesus,  I missed this.  Many thanks for this offer.  I'll message you and see how to send the file across.
THANK YOU - very much.  :D
nievesoliveras
This component parts list was shared by @fuzzytomcat on a public experimentation he made of the @ainslie circuit at Crudd website.
Jesus
ramset
Thanks Grandma
vonwolf
  Wow I didn't know you were banned from the Energetic Forum, I was wondering why the posts seem to end on 7-06? I didn't see any problems going on with the thread so I guess it must of been a behind the scene kind of thing? There's lots of strange things going on over there and I have a hard time keeping up, I hope you get things strained out.
   I saw your Coil and it kind of looks like a element in a water heater so I know where you are going with it. If you can heat water thats the beginning of everything, steam can do it all at least thats what I've been thinking from the first I saw you collaboration. The more efficiently you boil water the better, to achieve over unity and still get the job done is what we all need.
   The infrastructure is already there in much of the world and where its lacking it will be much simpler setting it up if a cheap means of electrical generation is discovered. Its only part of the energy solution but its a start and I hope you and people like you can keep this moving in the right direction.
  good luck Pete
PS for some reason (no good reason I can think of)I use a different name at EF but I have been following both thread for quite some time
Rosemary Ainslie
Quote from: vonwolf on July 19, 2010, 09:54:42 PM
Hello Pete.  Yes indeed.  Ostensibly I was banned for saying the following.  "Guys.  Anyone who claims to understand everything about Leedskalnin must first be able to duplicate his miracle engineering feats' - words to that effect.  I think that was it as the post was deleted.  LOL.  I think it will go down in history as the flimsiest excluse ever used for banning a member.
Quote from: vonwolf on July 19, 2010, 09:54:42 PMI saw your Coil and it kind of looks like a element in a water heater so I know where you are going with it. If you can heat water thats the beginning of everything, steam can do it all at least thats what I've been thinking from the first I saw you collaboration. The more efficiently you boil water the better, to achieve over unity and still get the job done is what we all need.
The use of that 'standard type' element is only motivated in the hopes that it may be able to achieve that same effect under resonance.  But while the design is 'standard' there is nothing standard in the resistive wire.  Those of you who get to replicate and want to take this further will need to PM me to get details here.
Quote from: vonwolf on July 19, 2010, 09:54:42 PMThe infrastructure is already there in much of the world and where its lacking it will be much simpler setting it up if a cheap means of electrical generation is discovered. Its only part of the energy solution but its a start and I hope you and people like you can keep this moving in the right direction.
  good luck Pete
Indeed.  Many thanks Pete.  All good wishes much appreciated.
Quote from: vonwolf on July 19, 2010, 09:54:42 PMPS for some reason (no good reason I can think of)I use a different name at EF but I have been following both thread for quite some time
I was wondering about this.  Something 'familiar' in your turn of phrase?  or signature?  LOL.  I hope so anyway.
Kindest as ever,
Rosie
http://www.scribd.com/aetherevarising
