Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
7redorbs
The following passage is the result of many years of amateur observation, in the field of magnetic current and conductors. You will find that through my basic inspection of simple faculties such as the waves of the ocean, we are able to discover the presence of some 'cosmic force rays' emanations which account for the currents in the vast and long sea conductor in the same way as the phenomenon in long transmission lines is referred to as "Anomalous Voltages in Transformers", this cosmic 'interference' in transformers has been known for the last 100 years or so (Dollard). Whilst of course it has been known to Dollard, and a few others, there has not been a simple rational approach to prove this cosmic forces effect to the layman. Except the sea.
Of course it has been known by the engineers at RCA for almost 100 years now that planets affect the transmission in a line (Dollard). Further, alchemists and scientists have known 1000's, maybe 10's of thousands of years that the distance or phase of the moon affects the current of the huge ocean. Both are entirely independently established.
What appears abundantly clear is that nobody has put the two together yet, in the wheelwork of nature, as Tesla hinted ; the sea waves gain their additional energy via the cosmic induction of local magnetic forces, so does the long transmission wire. As both are independently established I can be thanked for merely adding the two faculties together to more readily describe a higher current. Both Ocean and Wire seem to have the same source of higher current intereference thusly, and both have had this 'external gain', or 'fluctuation variation' measured with a high degree of accuracy. This leaves the sea and the transmission line as conductors to be effected by this cosmic power. Induction being comparable to the size of a conductor and the strength of the effecting total local magnetic induction(s).
As such we may be discussing the subject or harnessing the collective power of the cosmic force in the same was as the Ocean, except in the oceans abscence a transmission line, or sea of aether being present.
Now, with this explanation there is no anomalous currents in the ocean, or in any wire and thusly there can be no anomalous waves in any transformer coil anywhere, or any anomalous voltage at all. Merely a re-interpretation was required to account for the sources of the induction, not this madness we call 'intereference'. The largest ratified conductor of great length and width would have to be the sea.
And now for the paragraph of inspiration in my mind that really inspired this thought:
"The sea being a large and long conductor body connected together, exhibits the cosmic wave forms caused by rays from outer space in the same way the first transmission lines did. The factor of strength of the induced wave current caused by outer space cosmic rays is based solely the distance of the moon from the planet, or the closest, most dominant magnetic pole. As is the wire" -
I saw someone posted an Einstein quote about reinspecting the groundwork of physics, nothing could be more important than this, especially today.
Does this mean the moon puts magnets in the Ocean as the nearest magnetic source? The same way cosmic ray interferes put's voltage in wire?
That is what I have gone at length to indicate for your further researches and pursuits..
And don't forget the Alexanderson Generator which was seized by RCA in 1914, used longitudinal waves of a speed of 291,000mi/sec, 105,000mi/sec faster than the speed of light 186,000mi/sec.
Maybe it is time to start making all kinds of light with your conductor arrangements. (I really wish and cannot fathom why there is not more interest in this). So I will take the danger of posting the truth about this technology as best I know it.
Best Wishes,
A
truesearch
@hope
@7redorbs
Based on your understandings and concepts of Leedskalnin's work how can we go about building a working device to tap into the magnetic force?
truesearch
7redorbs
Creating a new Working Device that employs faster than light wave speeds is not a new concept. This is something you can find in the Marconi Wireless Alexanderson Generator designed by Steinmetz's Protege Alexanderson (hence the flawless generator being named after him).
The Alexanderson Type Generator using the improved multiple loaded flat top antennae, which was subsequently removed just after WW2, there is absolutely no doubt that with it's diminished leakages and multiplicate reicrulcating currents, the Radio Aerial is capable of generating 1000's of times more powerful radio signals than a regular Rhombic Transverse D type aerial. Surely then, this must be why Eric Dollard was chased by an environmentalist group called "COMMONWEAL", and had his equipment bulldozed by a SWAT team, for the use of this type of technology. Of course, it is considered a harassment, for the sole reason that the magneto dielectric (i.e. using longitudinal waves) is vastly and infinitely superior to the fallacy that we call today the most advanced electrical technology. The Transverse system, as such must be treated as a complete joke.
The reasoning is because the Rhombic Transverse Aerial type (look it up) is a Transverse ONLY Sinusoidal wave form receiver. Whereas the Multiple Loaded Flat Top Antennae might be considered to propogate both transverse waves at 186,000mi/sec (light), and longitudinal waves at 291,000mi/sec ("another kind of light"), because at any given time in the Multiple Loaded Flat Antennae's both used by Alexanderson and Leedskalnin there is clearly more than 2nd order type currents running through it. (Given the relationship between Transverse (horizontal + vertical) and longitudinal (horizontal only) waves.)
My response, is plain, The Alexanderson Generator does all the same things with magnetic current that Edward Leedskalnin does, and that is why in 1914, it was seized from Marconi, and put away from the sights of the public at the beginning of about World War I, this is documented historically and has been under military government general rule under RCA since nog long after then. Obviously the longitudinal 291,000mi/sec propogations do not belong in the public eye since about the beginning of World War I, this does not change the irrefutable fact that both Tesla and Reich speak at length of these waves. As we know all magnetic current to run in any direction must run in the other (as in Newtons Law), however in the Multiple Loaded Flat Top Antennae, many , many, many currents are running, at different moments, forming a complex synthesis of Alternating Currents, with negligible leakage, and essentially a magnification or amplification effect over time. (Remember the load is utilised in the same way, there is no overunity, just magnetic concentration at the center, and preventing it's leakage. If anyone has wondered, this is why the Earth can spin, because more magnets hit that magnetic centre of the planet on the East.
If you had thought of the Earth as an electrical transformer,  you would see the goal of a 15 degree adjustment, and indeed, the mutual goal of the degree's 105 and 195, and, indeed, their 90 degree separation, and, if the earth a transformer, and a sun an inductor, then, you will see why the Egyptians had it right, and indeed, why the Pyramid Builders, also, had it right too.
Size of conductor is obviously important, as is the size of your FRAMING, if you increase the transformer frame size, and scale up, it becomes clear, what runs in a wire as a fluctuation is at all times being inducted by the cosmic force and the local magnetic force of the earth.
If you were to run your magnetic current in the vacuum of space, I think you might be impressed with the difference away from the local magnetic field of the earth (the ground).
Indeed, the culmination in the MLFTA of transverse and longitudinal propogations become reactive components to eachother, in the same way that the North and South Pole magnetic currents form recirprocals or antithesis of eachother. This is akin to Newtons claim that for every f1 there was a diametrically opposed f2 force in the absolute opposite vector. You could say that the longitudinal waveform and the transverse wave form, combined with a trigonometric frame of reference (and making the right multiple connections) one is able to alter the phase of the reactive f2 force, whereby it might be aligned with the f1 input force, therefore causing a 3rd derivative of "f3" whereby f3 = f1+f2 and whereby f3 consisting of f1 input and f2 reactive force on the same vector alignment, then f4 reactive force will equal f3 or f1+f2. This is a very interesting and bold statement, I would not put forward to share if I did not feel had a definite and grounded base to it.
When we re-inspect the work of Tesla at Wardenclyffe, and indeed Leedskalnin himself, and his many books , we become open to the positively true fact that the planets, or magnetic polar regions of stars, are in reality quite effecting the planet earth's ocean to gain a very large amount of energy. This derived energy in the wave's of the ocean comes positively from the nearest local magnetic influence, and, right now the closest magnetic influence is the moon. All of that energy in those ocean waves came from other planet's magnetic influence, as we established, and thusly such a wire transmission line as massive as the ocean, would indeed, be subject to the fluctuations of the planets , and the stars, in the same manner, total surface area of the conductor, and the volume, and symmetry, being key. The earth being entirely round, and consisting of 4 quadrants, and having differing permeability to the magnets of the star, we are able to see the cosmic force building up, and taking down the atoms of rock matter by this system.
This is both how Edward Leedskalnin did it, as well as the Ancient Pyramid Builders, as well as Nikola Tesla accomplished his theory. Except, in the world of wireless radio transmission, a transmission line of physical MASS of wire, is totally unrequired, since, in the sea of the aether, a similar surface area and volume to the sea, of which is receiving the same kinetic influence, is abundant in it's availability.
I do promise this is a fact, and you can start work right now, simply by following the Work of Eric Dollard and Chris Carson on the rotary electrostatic transformer, or follow the early work of the German Government and Military throughout 1914-45 study on Parametric transformation, best read Eric Dollard Wireless Power and Eric Dollard Primary & Secondary Coils to get a firmer grasp on the historic nature of radio systems, since about 1890, and the involvement of Oliver Heaviside, and the Maxwell theory as a whole.
I will save you some time, though, there are 2 versions of Maxwell. One that works for longitudinal wave propagations of 291,000mi/sec, and one that was written after, with QUATERNIONS REMOVED from it, replaced by 2nd order dervitatives vectors ONLY, therefore being totally unsuitable of representing propagations faster than 186,000mi/sec, (ignoring phase velocity), and as a result the Four Quadrant Theory of 'gravitic' or rather, magnetic lag and lead time, and electrical distribution, have been lost to the ages.
It was only after inexhaustible efforts to uncover this knowledge, and a life almost ruined to get as far as I have. The things that you ultimately have to sacrifice to understand Nikola Tesla, Wilhelm Reichs and Edward Leedskalnins work is shed this stupid idea of material gains. Part of the longitudinal component is , as well as massless, completely immaterial component, which seems to form the antithesis, or rather the dielectric longitudinal counterpart to the transverse sinsusoidal function, attained merely by distribution of a transformer alone, and usually unseperated in Transverse type systems, can be seperated into the TRANSVERSE (HORIZONTAL + VERTICAL SINE WAVE COUNTERPART) as well as the LONGITUDINAL (HORIZONTAL ONLY OR VERTICAL ONLY), as you can see by quarternion theory, the longitudinal or (push pull), 180 or 0 degree component sits on the same axis as 1 half of the Transverse wave.
The Transverse Wave shape space/time is "L" shaped.
The Longitudinal Wave Shape space/time is "I" shaped.
The I can fit into the L on two dimensions 90 degree's apart.
I hope I have said enough.
Best,
A
Doug1
7redobes
  Good job there.You made me smile if that is any consolation to your your years of digging.There was some mention of Scotty in the past tense, did something happen to him?I was looking for his email some months ago and could not remember where I had placed it.
Ya know at some point you'll have to give a more physical desrcription of a possible design direction.
Dont take it too much to heart if responses are slow you gave a lot of reading material sugjestions that will be time consumming to locate.
