Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
7redorbs
Hey, what were you specifically after a drawing of Scotty? For the meantime here is something I found to be of great interest:
Source New York Times, 1927, Title: "Nikola Tesla tells of new Radio Theory"
For all the Leedskalnin fans listening, you should consider it an OLD radio theory, as Tesla did in other quotes. I think you know what I mean.
"I have read the article, and I quite agree with the opinion expressed - that wireless power transmission is impractical with present apparatus.  This conclusion will be naturally reached by any one who recognizes the nature of the agent by which the impulses are transmitted in present wireless practice.
"When Dr. Heinrich Hertz undertook his experiments from 1887 to 1889 his object was to demonstrate a theory postulating a medium filling all space, called the ether, which was structureless, of inconceivable tenuity and yet solid and possessed of rigidity incomparably greater than that of the hardest steel.  He obtained certain results and the whole world acclaimed them as an experimental verification of that cherished theory.  But in reality what he observed tended to prove just its fallacy.
"I had maintained for many years before that such a medium as supposed could not exist, and that we must rather accept the view that all space is filled with a gaseous substance.  On repeating the Hertz experiments with much improved and very powerful apparatus, I satisfied myself that what he had observed was nothing else but effects of longitudinal waves in a gaseous medium, that is to say, waves, propagated by alternate compression and expansion.  He had observed waves in the ether much of the nature of sound waves in the air.
"Up to 1896, however, I did not succeed in obtaining a positive experimental proof of the existence of such a medium.  But in that year I brought out a new form of vacuum tube capable of being charged to any desired potential, and operated it with effective pressures of about 4,000,000 volts.  I produced cathodic and other rays of transcending intensity.  The effects, according to my view, were due to minute particles of matter carrying enormous electrical charges, which, for want of a better name, I designated as matter not further decomposable.  Subsequently those particles were called electrons.
"One of the first striking observations made with my tubes was that a purplish glow for several feet around the end of the tube was formed, and I readily ascertained that it was due to the escape of the charges of the particles as soon as they passed out into the air; for it was only in a nearly perfect vacuum that these charges could be confined to them.  The coronal discharge proved that there must be a medium besides air in the space, composed of particles immeasurably smaller than those of air, as otherwise such a discharge would not be possible.  On further investigation I found that this gas was so light that a volume equal to that of the earth would weigh only about one-twentieth of a pound.
"The velocity of any sound wave depends on a certain ratio between elasticity and density, and for this ether or universal gas the ratio is 800,000,000,000 times greater than for air.  This means that the velocity of the sound waves propagated through the ether is about 300,000 times greater than that of the sound waves in air, which travel at approximately 1,085 feet a second.  Consequently the speed in ether is 900,000 x 1,085 feet, or 186,000 miles, and that is the speed of light.
"As the waves of this kind are all the more penetrative the shorter they are, I have for years urged the wireless experts to use such waves in order to get good results, but it took a long time before they settled upon this practice.
"Although the world is still skeptical as to the feasibility of my undertaking, I note that some advanced experts, at least, share my views, and I hope that before long wireless power transmission will be as common as transmission by wires."
I have to say, what Leedskalnin said about magnetic push and pull being equal on a ground level, and how a pyramid has a SQUARE of highness, and a square of LOW point, and possible conductors in between, then, we could say that Tesla's claim about 1085 feet * 900,000 gives the speed of light in miles per second. It also reveals that the speed of propogation was a function of the height, in the same way Leedskalnin tells you that magnetic polar strength is equal at the same level. Both in Tesla's patents, (such as raised capacitance antennae, multiple loaded antennae) and Edward Leedskalnins machine, you will find the same elevated terminals.
Interesting shit huh? ;-)
http://www.tfcbooks.com/tesla/1929-09-22.htm
On yet again another separate 'note' I attach a "square" diagram approximating the outlay of the magnetic streams correlating the 'relativity' between them. Since Einstein doesnt apply to Leedskalnin or Tesla's physics (mainly because the source of the magnetic stream is moving too), unlike in electrical transformers, where the poles alternate, Leedskalnins stay the same, so a moving source of this kind might be a more practical prime mover than would have otherwise been in it's place. We may be reaching the edge of my engineering knowledge now,
Best,
A
Doug1
Orb
Not sure I understand your drawing.What provides the movement?
Scotty
The reason for testing the PMH when it's loaded is to see if the feild is moving or the electrons in the windings. Ed had to have some way of picking off the induction.There is no such contraption in any photos to this date which could be used that way.He was very fond of the PMH and if it's princibly a locked electro magnet that just sends it's feilds circling around the core locked in by the PMH windings impressed upon by the U shap magnets in the wheel it would be adjustable by both speed and the starting voltage applied to the PMH to get it charged up. Then comes the figuring out how he plucked off enough induction with out draining the PMH or causing it to magnetically lock against the rotor. Maybe by it's nature (pmh) it doesnt do that any way. It doesnt take a wheel of magnets to check that.
derekwillstar
Quote from: Mk1 on July 25, 2010, 11:45:22 PM
@all
Ed Leedskalnin Was talking about looking to the east , in his book Magnetic current . That is the first thing he mentions.
I you think about it a bit , and also keep in mind that he made spelling errors knowingly ... that should be enough to start imagining hidden message .
This writing is lined up so when you read it you look to the East,  and all the description you will read about magnetic current, it will be just as good for your electricity .
I original copy of the book is hard to come by , i wonder why.
That is the first thing ...
Now what is this about the east ...
Freemason's have the same notion of the east , even the temples are built respecting it , the is some thing here ... ??? ?
But thinking about it , brings me to what happen to a compass in a very weak field , i made a magnet out of a 4 foot piece of steel rod the field is very week in the middle , the compass is blind at this point and is 90 degrees off ... north hum east ...
Now you guys , know motors how can you make a motor with the poles facing away from the coil , basically trying to push it where there is no resistance no north no south , i am clue less but this can't be done ...
Poles should be more active even to a point of generating heat , why are they located there , even the sun is off half of the year ...
Its official this suggest that i am now clinically crazy , but beginning to think we don't know anything ...
Mark
Reset !
Ed Leedskalnin in his book " Magnetic Current "makes some revelations such as:
- A permanent magnet in the "real magnet" non'è the metal but the particles that make up the magnetic field and that there will slide inside.
- The particles that make up the magnetic field are "small" and penetrate anything, more easily pass through the metal that the air.
- They are constantly moving in one direction against the other and if you drive into the right channels, have perpetual motion.
- The North and South (as individual magnets) are the cosmic forces , they keep together this earth and everything on it.
- To be of any practical use must be present in large quantities.
- In a permanent magnet at times some particles can escape from the magnetic field, but others came up, to take their place.
- The current in the wires does not flow in a straight (if you observe carefully the spark caused by short circuit of two wires are we aware)
The key is to consider the magnetic poles as monopolies. Leedskalnin reveals that there is a descendant of the current monopoly of the North Western hemisphere ( positive energy ,light , hot , yellow ) which is due to the force of gravity. But he had a complete overview , which will be more fully explained by the Italian Pier Luigi Ighina with his law of rhythm
sparks
leedskalins particles are what physicists call virtual particles.  They are needed to avoid reactions at afar problems.  The magnetic field is a flow of these virtual particles into and out of charged mass.  When the charged mass moves the flow of virtual particles is altered.  In a permanent magnet the charged mass is frozen or crystalized.  This creates a uniform flow of virtual particles.  Into and out of the permanent magnet.  In an electric circuit the electrons move more or less in the same direction which causes a predictable flow of virtual particles.  Two electrons close to each other cause the vps to collide.  This causes a high density of vps and resulting pressure.  The electrons move apart from high pressure to low pressure.  In a transformer the vps transfer energy from the primary to the secondary.  When a piece of iron is magnetized the flow of virtual particles from the permanent magnet arranges the atoms of the iron so that they mimic the permanent magnet flow.  When a magnet sticks to a fridge it is the flow of vps that keeps it there.  When we take a conductor and move it through a vps flow aka magnetic field the electron vps flow reacts with the external magnetic field and the result is the electrons move.  When they cool a conductor down so the atoms arent going every which way a magnetic field forms around the conductor cause the vps flow into the electrons becomes orderly.
  Where these particles come from and where they go is unanswered making them virtual.  But they do serve the purpose of explaining electromagnetism.  The electromagnetic wave exists as a wave in a sea of virtual particles.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
derekwillstar
Quote from: sparks on May 02, 2012, 03:23:19 AM
- A permanent magnet in the "real magnet" is not the metal but the particles that make up the magnetic field and that there will slide inside.
when he talks about north and south poles as individual , does not refer to the common earth's magnetic field  !!!
Also...it is better to read up on other works of Edward Leedskalnin :
http://www.leedskalnin.com/LeedskalninsWritings.html
It is very interesting "ADVERTISEMENT" :) http://www.leedskalnin.com/Leedskalnins-Writings-ADVERTISEMENT.html
