Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
cletushowell
its not the chemicals its the colors blue ice red flame blue torch
so red blue red blue
the blood of the lamb unlimited power
but you can use any rock but you need to radiate it with a antenna and water now by hanging it and misting it it will spin and I noticed that the rock started turning to granite to much water it kills energy to little it stops absorbing energy so what im saying is you can make a nuclear rock
so thats why I use granite. someone can improve my granite im shure but
Im broke with no lab so the zero point energy is only as good as strong the frequency you charge to it.
also white is all color the blood of the lamb is pure like snow the breast milk
so black is canceling frequency using opposite colors. whit already has all color so it cant absorb any more its already full  which is why a baby gets any energy it needs from breast milk.
das aloda bullspit
uat the hell is this guy talking about? this is about semipeduedomonoclinicpolycrystalinepetrovoltaic energy recievers aka crystal batteries  babys milk? string? i think ue are into it a bit more than just rocks taer and lambs blood although i have a good mix for you to try
BariumTitanate
aluminium oxide
sodium silicate
borax
kaolin
gallium a tiny amount
Noibium pure or oxide best do both
and other common semiconducting oxides
fill the tube and heat up apply voltage or dont either ay it should ork for you
das aloda bullspit
ive had a good idea has anybody tried suing sound aves or other forms of this like sautooth frequency to see if there is any change
mrbr00k5
@cletushowell
??? What in blazes are you trying to say!?  ???
@Das Aloda Bullspit
Good thinking about trying some frequencies and wave forms with the cells. I hooked a cell to a joule thief, and attached a small l.e.d., I then connected a signal generator to the crystal cell. I had to set the amplitude very high, and the pan very low to get a result. But once I did, I could then make the l.e.d. blink, and easily control the rate of blinking. The crystal cell seemed to respond to frequency quite well. At about 19 Megahertz the L.E.D. got dimmer, but when I lowered the frequency to around 11-13 Megahertz, it got much brighter. Brighter than without the signal generator being attached. Also, something I thought was quite weird, if I start at 1 hertz then go up, the blinking of the l.e.d. follows of course, it blinks faster and faster, until you reach a high enough frequency, and can't see the blinking anymore with your eye. But, at exactly 9597.46 Hertz, it suddenly starts blinking at an easily visible rate, if you move the frequency the slightest bit away from 9597.46 Hertz, then it speeds up again and you can't see the blinking. I'm not sure what that means. I welcome any ideas from anyone.
@Everybody
Hi everyone, I put together a flashlight, (I like making lights! ;D ) I connected my best crystal cell to a joule thief, then connected a 50 farad super capacitor to the output of the joule thief, then connected the super capacitor to a second joule thief, which lights a bright l.e.d. It's kind of Rube Goldberg I know, ::) but it works! For now anyway, I'll be monitoring it. The first joule thief which the crystal cell is running, runs all the time, I didn't put an off switch on it. So it keeps the super cap charged up for when I need the light. The second joule thief has an on/off switch and a 5Kohm potentiometer, which can change the brightness of the l.e.d. I attached some pictures if anyone is interested.
My sealant cells are still doing fine, they show no signs of stopping. But my lepidolite cell has dropped quite a bit. It can't even run a joule thief now. :'( I'm not sure what happened, it like some others, seemed to quit all at once. So I guess I need to alter that mixture, oh well, this is most certainly a learning experience!
cletushowell
Sorry be paitient i said a lot in a small space
start with a plasma ball one you stick your finger on you
see the red blue red blue this is the energy
of everything the primary colors are wrong
the primary color is magenta/ indigo
the blood of the lamb blood goes red blue
its a bible refrence the blood of the lamb overcomes
the reason its all power there is no negative energy
its a illusion of open loop
so blue is double the power of red
its ice and a torch so if you understand the power of color
the frequency is e and f 144,000
electromagnetic frequency
you can do anything you want
so any zero point combination
needs red and blue or white
zinc or copper earth batteries
salt and magnezium air batteries
color hope this help keep asking if your confused im a bad teacher
