Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
jbignes5
Again I can not agree more with you and John B. Paralleling these will substantially improve their life spans. But I still think we need to build in some safety device to make sure the cells are not capable of self destruction. It will limit the current and keep them strong.
NickZ
  I wouldn't think that to be necessary as the current is already limited by the weakest cell in the bunch, when they are in all parallel there. Which acts as a resistor to the currents output level.
jbignes5
 Yes the BMS will be very necessary for this application. You got to understand that each cell in the parallel bunch are singular and they have limits from what I am seeing. This limit is based on the material we choose for the crystalline structure. It's phasing point or melting point is the problem. It is all well known about how this process works. Too much heat and the battery goes gooey.
So I am guessing that this is what chemical batteries do. The initial reaction is from the setup and gets a boost from the chemical reaction. When the chemical reaction is spent either the battery needs a recharge or the battery will maintain a limited current capability.
Having many of these weak cells in parallel will eventually even the odds and we should be able to attain the same level as battery technology currently with no use of chemical reaction or at the least very little chemical reaction.
jbignes5
Hey nick could you send IBpointless a message for me to check here. I thought he was going back and forth here but no one seems to be working here besides me and you?
jbignes5
I had a chance last night to think about this in the half dreaming state. The process we are seeing here to lock in this materials structure is the heat phase transition of the crystalline material we are using. Through complicated structure geometry it is making a diode like structure. When we short out the cell as well in the forming of this structure it aligns up more efficiently through the structure. We are not allowing the structure to form in any other fashion by using this process.
When I was younger I saw a video of a very important experiment. It was a very simple experiment. Charge a plastic comb with static energy and it will make the salt or sugar crystals jump and move around. Well I am having a hard time finding the original video this one should help you to understand the process a bit. http://www.youtube.com/watch?v=JT4UVsfZkwg
In that video we see the effects of potential on the matter of the rice crispies. I suggest we are doing the same thing but in our case the charge is based off the matter itself. With one metal having a better ability to convey charge through itself then the other. We increase the phase temp of the crystalline structure into the molten phase. This allows the structure to become very mobile and pliable. With two metals with different charge levels inserted it will pull the crystalline structure into a new form. That form is locked in as the temperature lowers back into the rigid structure mode and locks that new form in. This new form is very capable of providing one way flow by virtue of it's shape(geometry) alone. Water and heat are merely the method to use in this process. It is not what drives this new type of battery. It is the mechanic building process and if there is water left in the crystal then it is working against the action we have set up.
Most of my revelations about this always lead me back to surfaces and tensions on those surfaces. Just like a drum we are creating a surface tension then letting the ambient waves drum on that surface and collecting that energy. These batteries are only acting as one way valves in that sense and reject most anything in the other direction. This is very akin to the way Moray did his device.
I would suspect that the best geometry of this device should reflect back to the geometry of the field we are using to setup the crystal lattice in the phase transform. Since we are using pyramidal based crystals the device should resonate with that shape as well. I'm assuming the tetrahedron(Borax) is that structure or geometry and the pyramid is the fill material or Alum or in some way fits together to provide a flow in one way.
