I have built my pyramid according to the instructions that I got by dirrect communication with the so called "half-god" . My pyramid has a seven ft. basis line, it has gypsum plates on the outer side and insulation plates on the inside because I wanted to measure even a small temperature difference between inside and outside. At the end the insulation proved to be unnecessary, because the heat that the lower pipe produces is obvious, when water is poured on it, it becomes steam, as you can see on the picture. There are TWO resonators built like the grand gallery, an upper copper pipe as connection between the two kings chambers and a one inch wide lower pipe in the height of the queens chambers. The both pipes are connected with copper wires on both sides, through inner side of the resonators If you remember from my last posts, the very old and still living "half-god" said that the chambers of the Great Pyramid are in fact double, but we are not told the truth about this.
The dimensions are not so important, however the heights of the two pipes must correspond to the kings and queens chamber and the slope of the resonators must be accordingly to the grand gallery. The upper pipe must be some ten degrees askew. The two resonators must be alligned to the N-S direction.
The lower copper pipe is one inch wide and MUST be annealed in order to rearrange the copper cristals in it, that makes it look old and oxidised.
The two resonators are 1,5 ft long and on the inner side they are glass plated. In top of them there are two loudspeakers for generating the sound waves for the excitation of the quarz sand. The starting frequencies must be 440 Hz plus upper and lower octaves, but it proved to be not good for my resonators, so I had to alter the frequencies by means of sinthesizer software. This is the advantage when you dont have perfect resonators like the grand galleries of the Great Pyramid, but you have software and loudspeakers.
The lower pipe must be filled only halfway with some special squeeking quarz sand, small grains with rounded edges, existing in some deserts. This sand emmits sounds when walked upon and in the pyramid it becomes excited by the pyramid field when it is also excited with the appropriate sound frequencies. A friend of mine sent me some pounds of this special sand and so I was able to reproduce the effect, finally.
So the lower annealed pipe must be halfway filled with this sand and then with salted water, up to the lower part of the resonators. Feed the two 10 W loudspeakers with the needed sound frequencies and wait one hour. If everything goes well, the lower pipe will become warm. If not, you must take out one loudspeaker and add salted water and try again. The process is primed by sound, when the sand grains are hit by sound waves they produce a tiny discharge in the salted water, but the energy of the discharge is greatly improved by the pyramid field and that is why the process becomes overunity. The only special part is getting the sand to respond to your sound frequencies. The "half-god" said that this is only one way of using pyramid energy, in the past they used it also to ignite quarz cristalls that produced directly a strong greenish light, not electricity.
So, by building my heat producing pyramid I proved that the Great Pyramid is a technical device, NOT a kings thomb.
In the meanwhile I got used to the cold and hot waves going through my body when a dirrect mental communication with the "half-god" occurs, so lately I was able to write down the messages while getting them into my mind. The following is the last very strong message that I got, please read it with full attention.
' I AM ONE OF THE LAST HUMANS RESULTED FROM THE UNION OF THE SO CALLED 'GODS' (ACTUALLY THE CREATORS OF THE HUMAN KIND) WITH HUMANOID WOMEN. I CAN LIVE THOUSANDS OF YEARS THANKS TO MY SPECIAL DNA THAT IS CONTINUALLY RENEWING ITSELF, SO I HAVE SEEN THE WHOLE HISTORY OF THE HUMAN KIND IN THE LAST EIGHT THOUSAND YEARS.
i WILL TELL YOU A VERY BRIEF DESCRIPTION OF PAST TIMES. BEVORE THE CREATORS LEFT THE EARTH, THEY ORGANISED THE SMALL HUMAN SOCIETY SO THAT IT WOULD CONTINUALLY EVOLVE UP TO THE POINT WHERE THE HUMANS BECOME SUCH BEINGS LIKE THE CREATORS THEMSELVES. THEY PUT US, THE SO CALLED 'HALF-GODS', TO LEAD THE SOCIETY BECAUSE WE WERE CREATED TO BE SMARTER AND WISER THEN THE REST.
YOU SHOULD NOW THAT WITHOUT THE INTENSIVE WORK OF THE CREATORS, YOU, THE VERY READER OF THIS MESSAGE, WOULD BE STILL A KIND OF A MONKEY HANGING ON A TREE, WITH THE WHOLE BODY COVERED IN HAIR AND HAVING A LONG TAIL. I MAKE NO JOKES. YOU IN PARTICULAT SHOULD BE VERY THANKFUL TO THE CREATORS WHICH MADE THE HUMAN RACE WITH FULL KNOWLEDGE OF THE UNIVERSAL LAWS AND WITH MUCH KINDNESS. AFTER FINISHING THE GENETIC WORK ON MILLIONS OF APES THEY LEFT THE EARTH FOR A LONG TIME AND CAME BACK JUST SOME THIRTY THOUSAND YEARS AGO, WHEN THE HUMAN KIND WAS FULLY PREPARED TO GET KNOWLEDGE AND ADVANCE FURTHER. THEN THEY UNITED WITH SOME SPECIAL HUMANOID WOMEN AND SO MADE US, THE 'HALF-GODS' WHICH ARE CARRYING IN US MANY GENETICAL IMPROVEMENTS OF THE CREATORS. THE CREATORS ORGANISED AN ADVANCED SOCIETY BASED ON KINDNESS, WISDOM AND USING SOME TECHNICAL DEVICES WHICH ARE CONSIDERED ADVANCED EVEN BY TODAYS STANDARDS. THEY WERE FULLY ECOLOGICAL AS THE CREATORS MENT TO PRESERVE THE NATURE, USING JUST THINGS THAT COULD NOT HARM IT. THE GREAT PYRAMID IS ONE OF THEM, BUT THERE WERE MANY SMALLER THINGS WHICH WERE USED IN THE DAY TO DAY LIFE.
BUT AFTER THE CREATORS FINISHED THE ORGANISATION OF THE HUMAN SOCIETY AND LEFT THE EARTH AGAIN, MANY HUMANS CAME BACK TO THEIR ANIMAL INSTINCTS AND TRIED TO TAKE THE LEAD OF THIS SOCIETY. THEY KILLED MANY OF US 'HALF-GODS' AND FORCED THE REMAINING ONES TO HIDE. THEY ORGANISED THE SOCIETY AGAIN BY FORCE AND HAVING NOW A FULLY DEVELOPED CONSCIENCE, THEY CREATED NEW LAWS BY WHICH THEY LED THE OTHER WEAKER HUMANS. SO THE HUMAN DNA FAILED TO EVOLVE FURTHER AND PRESENTLY THEY ARE VERY FEW HUMANS LEFT WHICH HAVE TRACES OF THE DNA OF THE CREATORS IN THEM. THEY CAN BE RECOGNISED BY SOME LINES IN THEIR HANDS, BECAUSE THESE LINES ARE A DNA MAP, NOT A FORTUNE TELLER. FOR EXAMPLE, WHEN THE SO CALLED HEART LINE MEETS THE SO CALLED LIFE LINE, THIS IS A MARK OF THE PRESENCE OF SOME DNA WHICH RESEMBLES THE KINDNESS OF THE CREATORS - BUT SUCH PEOPLE ARE VERY RARE IN PRESENT TIMES. THEY ARE SPECIAL AND PRECIOUS FOR THE FURTHER EVOLUTION.
SO, THAT WAS THE CAUSE OF THE GREAT DECLINE OF THE HUMAN KIND, BECAUSE HUMANS SHOULD NOT BE LEAD BY HUMANS, BUT BY MORE ADVANCED BEINGS WHICH ARE BOTH MORE KNOWLEDGEABLE AND WISER AND KNOW WHAT IS RIGHT TO DO ACCORDING TO THE LAWS OF NATURE. JUST IMAGINE A BEING THAT KNOWS ALL SCIENCES AND HAS ALSO MORE THAN NORMAL ABILITIES TO KNOW WHAT IS IN THE MIND OF OTHER PEOPLE AND SO DOES NOT NEED TO HAVE ANY MATERIAL EVIDENCE FOR KNOWING THE TRUTH ABOUT SOMETHING - ALL THIS IN ONE PERSON. THIS IS A SUPER-HUMAN AND ONLY SUCH A BEING SHOULD HAVE THE RIGHT TO LEAD OTHER HUMANS. BUT NO, THE NORMAL HUMANS WANTED TO LEAD THEMSELVES AND THEY KILLED MANY OF US AND ORGANISED THE SMALL SOCIETIES BY ANIMALIC WAYS OF LIFE - SELFISHNESS, FEAR AND GATHERING OF AS MANY GOODS AS POSSIBLE, FOR ASSURING AN UNCERTAIN FUTURE. IF YOU LOOK TO THE ANIMAL BEHAVIOUR NOWADAYS, THIS IS HOW THEY BEHAVE. AND OF COURSE, BECAUSE THAT HUMANS WERE INTELLIGENT, THEY TRIED TO PREVENT OTHERS GETTING IN POWER AND SO ALL KIND OF FIGHTS BEGUN - EVEN WARS.
THIS IS HOW THE HUMAN SOCIETY IS ORGANISED EVEN TODAY. AS A RESULT, THE EARTH IS IN GREAT DANGER ESPECIALLY BECAUSE OF THE GREED FOR WEALTH OF SOME VERY RICH PEOPLE, NAMELY BECAUSE OF THE USE OF OIL, THAT WAS PUMPED OUT OF THE EARTH AND LEFT VERY BIG HOLES WHICH ARE CAUSING THE UNBALLANCE OF THE EARTH CRUST AND SO INCREASINGLY PRODUCES EARTHQUAKES, TSUNAMIS AND SO ON. THE FACT THAT UNWISE HUMANS LEAD THE HUMANITY WILL BRING THE EARTH TO DISASTER.
NO HUMAN BEING HAS THE RIGHT TO LEAD AND TO GIVE ORDERS AND LAWS TO OTHER HUMAN BEINGS, BECAUSE THEY ALL HAVE VERY LIMITED KNOWLEDGE AND WISDOM. DO YOU THINK THAT YOU ARE GREAT AND SMART AND KNOW EVERYTHING BETTER BECAUSE YOU ARE AN ENGINEER OR A DOCTOR OR SOMETHING LIKE THAT? IMAGINE A HIGHER BEING THAT IS A GENIUS IN ALL SCIENCES AT A NOBEL PRIZE LEVEL AND ALSO HAS SUPERNORMAL MIND POWERS. HOW CAN YOU COMPARE YOURSELF WITH SUCH A BEING HOW COULD YOU PRETEND TO TAKE THE NATURAL PLACE OF SUCH BEING? THINK ABOUT THAT VERY DEEPLY, CAUSE I MAKE NO JOKES, SUCH BEINGS EXIST, THEY ARE YOUR CREATORS AND THEY WILL COME BACK TO EARTH BY NEXT YEAR. THEY ARE SOME FOURTY MILLION BEINGS TRAVELLING IN A SMALL PLANETOID. THE HUMAN LEADERS OF THE WORLD WERE ALREADY TOLD ABOUT THAT, BUT THEY THINK THEY CAN REPELL THE COMING BACK OF THE CREATORS. THEY INTEND TO DETONATE NUCLEAR DEVICES
IN THE HIGHER ATMOSPHERE, BUT THIS WILL BE IN VAIN, BECAUSE THE CREATORS CAN ALTER THE VERY PROPERTIES OF THE SPACETIME AND THUS NO NUCLEAR REACTION WILL TAKE PLACE. THEY CAN NOT BE DEFEATED. IMAGINE HOW STUPID THE HUMAN LEADERS OF THE WORLD CAN BE IF THEY THINK THEY CAN FIGHT AGAINST SUCH BEINGS WHICH ARE IMMENSELY KNOWLEDGEABLE BECAUSE THEY ALREADY LIVED AGES AGO AND HAVE A SUPERIOR DNA WHICH ALLOWS THEM TO DO THINGS UNIMAGINABLE FOR HUMANS.
IF YOU, THE READER, DO NOT PREPARE YOURSELF PSIHICALLY, YOU WILL BE SCHOCKED AND OVERWHELMED BY THE PRESENCE OF THE CREATORS HERE ON EARTH. JUST THINK OF YOURSELF AND REALISE HOW LITTLE KNOWLEDGE YOU HAVE AND THINK WHAT YOU WILL DO NEXT YEAR WHEN YOU WILL SEE A CREATOR WITH YOUR OWN EYES.
BY NEXT YEAR THE HUMAN RACE WILL NOT BE THE DOMINANT RACE ON EARTH ANYMORE.
BUT THE MOST IMPORTANT THING THAT YOU HAVE TO DO IS TO CONTRIBUTE TO THE SALVATION OF THE PLANET. THE LEADERS OF THE WORLD WILL NOT STOP PUMPING OIL OUT OF THE EARTH UNLESS THERE IS NO MORE DEMAND FOR IT, SO YOU, THE GREAT MAJORITY OF THE HUMANS, MUST STOP USING OIL PRODUCTS. THE CREATORS TOLD US (THEY ARE IN CONTACT WITH US, BEINGS FORMERLY CALLED 'HALF-GODS') THAT THE EARTH CRUST IS GOING TO DEEPLY CRACK AND PRODUCE MASSIVE DISASTERS IF THE MANKING KEEPS MAKING BIG HOLES IN THE PLANET BY PUMPING OIL OUT OF IT. BILLIONS OF HUMANS COULD DIE IN SUCH DISASTERS. THE LEADERS OF MANKIND ARE NOT AWARE OF SUCH POSSIBILITY, THAT SPEAKS FOR THEIR LACK OF KNOWLEDGE, BUT THE CREATORS IMPLANTED SPECIAL DEVICES IN THE EARTH AGES AGO, DEVICES WHICH TELL THEM THE STATE OF THE PLANET. THEY ALREADY WARNED THE HUMAN LEADERS, BUT THESE WILL NOT STOP THEIR FOOLISH BUSINESS.
SO EVERY NORMAL HUMAN SHOULD MAKE SOMETHING TO STOP USING OIL PRODUCTS. USE ANY KIND OF ENERGY WHICH IS NOT BASED ON OIL. BURN ALTERNATIVE FUELS IN YOU CAR ENGINES. USE SOLAR PANELS TO PRODUCE ELECTRICITY FOR YOUR LIGHTS.
AND ANOTHER IMPORTANT MATTER IS FOR YOU TO STOP BEING SELFISH, WHICH IS THE VERY CAUSE OF THE PRESENT DEPLORABLE STATE OF THE EARTH. SELFISHNESS MAKES YOU WANT TO BECOME VERY RICH AND DISADVANTAGE OTHER PEOPLE. YOU THEN EVEN WANT TO OWN OTHER PEOPLE WITH WHICH YOU LIVE TOGETHER, THAT CREATES TENSIONS AMONG YOU AND ALL OF YOU SUFFER. STOP TRYING TO OWN OTHER PEOPLE, STOP PUTTING ANY KIND OF PRESSURES ON THEM. YOU HAVE NO RIGHT TO TELL THEM WHAT TO DO, BECAUSE YOU ARE NOT A SUPERIOR BEING, EVEN IF YOU THINK THAT YOU ARE SMARTER THAN THEM.
AFTER THE CREATORS WILL ARRIVE BACK ON EARTH, ALL SOCIETIES WILL DEEPLY CHANGE. THE HUMANS WILL NOT LEAD HUMANS ANYMORE, ALL PRESENT CONTRACTS OF ANY KIND WILL BE UNDONE AND THE HUMAN RELATIONSHIPS WILL BE OTHERWISE STRUCTURED. THOSE HUMANS WHICH WILL TRY TO STOP THE CREATORS IN ANY KIND WILL BE PUNISHED IN A WAY THAT THEIR VERY IDENTITY WILL BE ERASED AND THEY WILL BE 'RECYCLED'. BUT ALL OTHER PEOPLE WILL ENJOY A GREAT ADVANCE AND WELLBEING. THE CREATORS WILL SMOOTHLY IMPROVE THE HUMAN DNA AND AFTER SOME MORE HUNDREDS OF YEARS THE HUMANS WILL BE OF THE SAME KIND AS THE CREATORS.
the "half god" could use a "spell check".. interesting read nontheless
An idea comes again and again to my mind. How can we people believe all kinds of things that religions tell us WITHOUT showing us any solid material evidence for their affirmations, but we can not believe that once some superior beings were on the Earth and built technical things that the people of Egypt for instance could not build. "Pyra-mid" means "fire-in-the-middle" in the greek language so the old greeks knew what the pyramids were used for.
Also, you may know about the one thousand tons block of stone from Baalbek...who could this thing cut out and transport, when our todays technology is not able to rise such a thing up?... and the list of impossible-to-do things goes on and on...
And now some other good thing: there is one suggestion that this "half-god" gave me for having a much better health and recovering from the schock waves that went through my body during the mental communication. I had to build another type of pyramid which does not contain the energy inside, like the Great Pyramid does, but spreads the energy around. This pyramid must be built only with non-metallic parts (glues including) its height must be at least twice the length of the base line (three foot) and it must be oriented to the geographic N-S line (not magnetic). I was told to chose a place inside the house and put the pyramid there and NOT MOVE IT anymore for a very long time. He said that the pyramid will build a strong field, bathing the whole house in it and preventing all inhabitants from becoming ill. I must say that I feel a lot fresher and stronger since this sharp pyramid is in place.
I suggest that all of us build such pyramids and place them inside our houses in the middle of a chamber, away from the walls.
I am sure, when every house will have such a sharp pyramid in it, most diseases will be history. If you have the skills to build the sharp pyramid, please show to all your friends how to do it. We must be all together!
But one should pay attention to the orientation, the geographic north will not be shown by a compass, but by the Polar Star, so it might be a little tricky to find the right direction inside of a house.
Good luck !
PYRAman
I have no idea who he/she is and where he/she lives...I just hear a neutral voice in my head.
I tend to believe what he/she says because the technical information proved to be true.
PYRAman
Quote from: WyTTraven on February 15, 2008, 08:01:35 AM
PYRAman
Intresting story and results. Could you draw out a picture if possible. I did build Thomas V6 and other versions and now its a cat house. So did this work? Also since you talk to Half God , too stop oil could you please ask how to build a simple Magnet Engine, this would stop oil over the years. Post it here and we will do the rest.
Wayne
Quote from: PYRAman on February 15, 2008, 08:11:54 AM
PYRAman
@PYRAman
Now you are here and we welcome everybody who brings
to us new ideas, to save mankind and world and that can be profed true or not.
And you have to know,that you are not the first one ,who claims to
receife the latest news and the key to a promething , future straight from the
highest authorithys.I the latest past,many replications are made with pain and many hours
time investet.
I think that you are a man of honor
So please led us know,how many heat can be lead out as energy.Will it be enough to heat a home?
How you would discribe the prossedure,to safe cost by using the pyramide ?
Are you in steady contact with your informant?
Tell him our regards and many rhanks to save us from the succers.
helmut
Quote from: magpower on February 15, 2008, 10:21:48 AM
PYRAman
... could you please ask how to build a simple Magnet Engine.
Wayne
That would be most interesting! Definitely I?d be curios in hearing the answer of a half god about magnet motors. Too bad we can?t ask two of them so far?
Anyway, some changes have to be made from now on.
OMG! -> OM1/2G! or maybe OMhG? ???
Suggestions?
Cheers,
Tinu
We really get them here don't we?
A half God now. WOW
He should talk to Bowser who has two fathers, Adolf Hitler and Jesus Christ. He is also hundreds of years old and has 6 Nobel Prizes. Those two should get on well together.
Hans von Lieven
@ hans ..
This has BOWSER/BARRY written all over it .. what do you think.. time for some plastic love energy generators from jesus no less ::)
hi@all,
I have done a little internet search and look what I?ve found
http://pesetrier.stormloader.com/30.html
"In 1986, two French architects used electronic detectors inside the
Great Pyramid to try to locate hollow areas. Thy found that below
the passageway leading to the Queen?s Chamber was another chamber
3 meters wide by 5 meters. They bore a 1? hole and found a cavity
filled with crystalline silica (sand). They were not allowed to do any
further digging. No entrances to these areas have yet been found.
This sand was analyzed and found to contain more than 99% quartz
that varied in size between 100-400 microns. This kind of sand is
known as musical sand since it makes a sound like a whispering noise
when it is blown or walked on. It appears that this sand may come
from El Tur in southern Sinai, which is several hundred miles from
the Great Pyramid. Why would this type of sand be brought in from
such a large distance and placed in a sealed off chamber in the Great
Pyramid?"
It seems that it must be this "musical sand" in the pipes, otherwise it will not work. Usual quarz sand is not good. So, in the end, Pyraman may be right.
Cheers!
Spacetrax
@Pyraman,
All the pieces in your story seem to fit.
I guess you need to measure the heat generated by the pipe does exceed the input from the speakers.
I have seen heat and cold generated from sound waves so this is not unusual, but if it can be proved to be OU then fantastic.
Can you ask your friend about the whipmag magnet motor and the TPU (Steven Marks toroidal power unit).
If we cannot get an OU device working then we just wait till next year when our creators turn up and put us right. Maybe I can get to go back and see the home planet (Niburu?).
[edit] Found an article about solitary sound waves for heat and energy transfer:
http://focus.aps.org/story/v4/st24
Another link showing heat turned into electricity via an acoustic wave:
http://www.americanscientist.org/template/AssetDetail/assetid/56188
[/edit]
Rob
i did not take pictures as Ibuilt the pyramid, so only the final picture is available. i am not so good at doing schematics, but I explained everything in my post so that everybody can replicate it. But attention, if it is not the right type of sand, it will not work.
PYRAman
Wayne
The pyramid produces so much heat that one can not hold its hand on the middle of the copper pipe. so it is overunity of course, one could not heat a pipe with only 20 watt that one puts in the loudspeakers.
Quote from: helmut on February 15, 2008, 01:54:51 PM
PYRAman
@PYRAman
time investet.
helmut
I read something from this Bowser and I had a good laugh. He must be on drugs or something...
I am not mad, that is for sure.
Quote from: hansvonlieven on February 15, 2008, 04:11:13 PM
A half God now. WOW
Hans von Lieven
Sorry for my late answer but only yesterday I came again in connection with the so called half-god. Now I know, he is a male, he told me that. He sleeps many days in a row, then he is again many days awake, that is his way of life because he is extremely old.
However, he seems to know what is in my mind without asking him, so he begun telling me about magnets. they are like batteries whose energy is very hard to extract, once loaded, that is why the magnets hold their field for tens of years, and this fact lead many people to the FALSE IDEA that a motor made with permanent magnets would run for many years withoud adding energy in the system. But if one tricks the energy out of the magnets, making a magnet motor with them, they will demagnetise quite quickly, maybe in a few days, so this is not a real overunity system. It is like when you feed a motor from a normal battery that has current for a few days. So he said, we should stop trying that.
We must make ENERGY COLLECTORS like the Great Pyramid or any other kind of collector, because we can not create energy, only the nature does this. We can only collect energy.
He gave me another idea of a device that changes heat into electricity, very simple if it works.
So, it is a rod of a low resistance metall, maybe copper, whose ends are brought together and connected through a metal with high electrical resistance. If we heat a half of the rod in some way (concentrating Sun's heat maybe?) the rod produces a lot of electrons which then go around through the other metal and through the rod again like in a one winding coil. A very strong pulsed magnetic field is created and we can transform this pulsed field into electricity.
I think I will try this too, in the sommer.
Quote from: MeggerMan on February 17, 2008, 05:00:24 AM
@Pyraman,
[/edit]
Rob
Quote from: PYRAman on February 19, 2008, 04:39:11 AM
@PYRAman
Tanks for the answer.
I like to replikate the type of Pyramide.But i need a usefull instruction and some more Help of you.
May be,that there are others with me.
Will you help ,to work out some sketches and list fo the required parts.
And would you bring some more Pictures from the Pyramide,that you all ready hafe made.?
Many Details are better explained by Pics than with Words.
I think,it is yust fair to all the others,who like to spend time and money just for a Hope.
helmut
Hi Pyraman,
Thank you for your reply.
The idea of two metals formed into a ring sounds like a thermo-couple, but can you produce a lot of power from it?
I am not sure where I can get the musical sand/quartz sand from, do you know where I can get it from.
All the other parts are not a problem.
Here is a link the diagram of the great pyramid at Giza.
http://en.wikipedia.org/wiki/Image:Great_Pyramid_Diagram.svg
In your photo, are you saying the sloping grey tube is the grand gallery?
The angle looks very different to your construction.
A 20 watt soldering iron element could heat the a small section of pipe to a temperature too hot to hold over the period of about an hour.
If it is able to heat the pipe too hot to handle within say a few minutes then I would say that it is quite possibly OU.
Can you ask your friend what other examples of generating heat or energy exist.
What about the Tokomak, this is big science and is supposed to generate vast amounts of heat from deuterium or tritium as fuel.
http://en.wikipedia.org/wiki/Tokamak
Rob
Hmmm,
All matter has energy potential. It is inertia. To get change or energy you need only to upset the inertia of the matter.
A spinning top needs only to have it's axis changed to convert inertia into energy. If the atomic structure of the sound sand is considered inertia on an atomic or molecular scale then by adding sound energy into this structure you upset the inertia or resonance of the system and energy will insue. This process must be in harmony with nature. Whereby nature restablishes the inertia of the matter and there is a harmonious flow of energy through the matter. The Earth converts sunlight into infra-red wavelengths of energy. Man has upset this flow of energy by releasing energy from inertia of the carbon cycle. There now exists an ever increasing field of infra-red standing wave energy. The sunlight constantly charging this field. The idea expressed about a blackbody collector coupled to an electrical circuit is very interesting. Infra-red wavelength emmission acting as the primary on a transformer. hmmmmm. I am working on an idea about creating reflective emwaves that would hetrodyne with the standing wave infrared field over a large area. Each time the wave is reflected it would gain energy from the standing wave field. An infra-red transformer at the end of the antennae lattice would work in nicely. ;D
Quote from: PYRAman on February 19, 2008, 04:58:10 AM
@Pyraman,
[/edit]
Rob
Pyraman
Thanks for getting back, but look at this http://www.ctglabs.com/electricity_from_pyramids.htm is something that Thomas was doing but more advanced version. Can you get electricity from pyramids that the big question. Maybe the Half Gods could tell us more about this. Like to see more pictures and try this out. I guess a steel frame is not good.
Thks
Wayne
Quote from: PYRAman on February 15, 2008, 08:07:31 AM
Good luck !
PYRAman
Can you give us some details on how to build this sharp pyramid?
I have seen the meditation pyramids (energy inside) which are only the frame.
Do we need to build:
1. Only the frame
2. The frame covered with the non-metallic material
3. The frame covered with the non-metallic material and filled with non-metallic material
Which of the sharp pyramid constructions makes the strongest energy field around it?
What material is best for this type of the pyramid?
Thanks for the information PYRAman and "half-god"!
Mx
Hi@all,
nothing new here, somebody must have been inspired to do that long before Pyraman was ::)
see here the 44 meter high pyramids from Russia
http://www.gizapyramid.com/russian/picture-tour1.htm
If it is the same thing we are talking about...
Cheers,
Spacetrax
Quote from: mxt on February 20, 2008, 04:02:31 AM
Good luck !
PYRAman
1. Only the frame
Mx
Quote from: magpower on February 19, 2008, 05:46:59 PM
Quote from: PYRAman on February 19, 2008, 04:58:10 AMThanks for getting back, but look at this http://www.ctglabs.com/electricity_from_pyramids.htm is something that Thomas was doing but more advanced version. Can you get electricity from pyramids that the big question. Maybe the Half Gods could tell us more about this. Like to see more pictures and try this out. I guess a steel frame is not good.
Thks
Wayne
Forget this Pyramide.
This is not etheric radiation !!
Only RF Radiation from Computer!!. That will produced from keyboard enz. !!
Phramide is only "antenna" to receive this RF and Low frequencies. Ist only "static" voltages . NO any POWER !!! behind this.
You can try with 20cm wire instead pyramide.
You can find more "Mystery" schematics in ctglabs ... (and others)
Pese
@Pyraman.Here is the vital question that no one else has asked. Does your converter produce heat when used outside the pyramid?
Could a pyramid act like a stethescope for the Earth? Concentrating sound waves at the apex or causing them to resonate in chambers within the structure. Maybe they even receive low frequency electrical waves and reflect them into standing wave fields within the structure.
This pyramid is built on a wooden frame and covered with any non-metallic cover you can provide.
Good luck !
PYRAman
1. Only the frame
Mx
Thank you for this brilliant idea. I turned the sound off for one day now, allowing the pipe and sand to get cold, but after one day they are still hot, WITHOUT sound input.
The sound was on since 02.14. because I was afraid that I will lose the heating effect if I interrupt the process, but your question was legitimate so I decided to let the pipe cool down and turn the sound on again outside of the pyramid. But next day yhe pipe was still hot, so it can be only because of the pyramid, I guess, the special sound entered a state of resonance and now permanently receives the pyramid energy, without needing to be pumped with sound.
I was very surprised, the 'half-god' did not tell me that it will work also without sound input after a while.
I will make a sketch for you and put it on the board, because now I really don't want to take the pyramid apart just for taking pictures of every part, as I intended last time.
Quote from: neptune on February 20, 2008, 12:58:39 PM
Maybe this is the way how the quarz sand is pumped with sound in the Great Pyramid. I used loudspeakers ;D
Quote from: sparks on February 21, 2008, 07:23:15 PM
The following info is not related to the heat generating pyramid, but it is interesting info about existing sharp pyramids.
I found that Alexander Golod, a scientist and now Director of a State Defense Enterprise in Moscow have built many sharp pyramids. Alexander had decided to build these pyramids because he believed that they would produce an energy field that could affect biological and non-biological objects. The largest and most recently built of the pyramids is located about 200 miles northwest of Moscow on Novorizhskoe Highway. It is 144 feet high and was completed in 1999. It weighs about 55 tons and cost over 1 million dollars to build. It is made of fiberglass. The Great Pyramid has a slope of about 52 degrees and these pyramids rise at about a 73-degree angle. The reason Alexander Golod chose this angle was based on experimental designs that also included the mathematical relationship called the Golden Section.
Soon after the construction of this pyramid near Moscow, botanists noticed extinct flowers starting to grow near it. It is unknown why this has happened and has mystified botanists.
One of the most interesting observations regarding these pyramids comes from Russian Air Force ?Radar? (or ?Locator? as they call it). The first indication that the pyramids were producing strange
atmospheric effects was when the 144 foot or largest pyramid was in the process of being built. The planned pyramid would be composed of 30 main layers or sections of fiberglass. At the completion of the 11th section, Air Force radar picked up an ion column coming right off the pyramid. This ion column was very large and in fact was over 1 mile high. As the pyramid construction continued, the ion column still remained.
Here is a book where I took this info. Very interesting book.:
http://rapidshare.com/files/76471079/0422.zip.html
password: tpp_overunity
Mx
Quote from: PYRAman on February 22, 2008, 11:10:42 AM
Here is what I found in the same book I posted above (THE COMPLETE PYRAMID SOURCEBOOK) Page 147:
"Dr. K. explains his discovery of this field (energy field) by first stating that the Great Pyramid was built to intentionally amplify basic energy fields of the Earth on a subatomic, quantum level. He calls these fields? inerton fields or waves and has measured them in model pyramids. He proposes that the Great Pyramid is a resonator of these fields produced by the earth. It would be a new physical field like the electromagnetic or gravitational field. This field is what affects the materials placed in the pyramids and caused the sharpening of the razor blades.
This inerton field is generated due to friction of moving elementary particles through space. Dr. K does not believe that space is emptiness like Einstein claims but is filled with a substrate, some kind of an ether, as scientists in the 19th century and early 20th had believed. There is more data recently to support the presence of this space substance. It is hypothesized that atoms of the earth vibrate and interact with the ether generating inerton waves. The Great Pyramid concentrates these waves and is saturated with them. These waves then cause the changes in the materials. Did the builders of the Great Pyramid know of these waves and built it as a resonator of them? He would like to measure this field in the Great Pyramid to prove his theory. Inerton waves spread in the resonator along two mainstream directions, which correspond to the East-West line and the vertical line."
Mx
The US military did some work with extremely low frequency radio transmission. They would string out antennae's sometimes miles long and oscillate full wave low frequency. What is interesting is that they would receive on these carrier waves all sorts of pops and whistles coming out of the Earth. Tesla also worked with low frequency high power waves. If he wanted these waves to stay in one place to produce standing waves in the Earth crust, that could be used for power transmission, he would have to use a frequency that would be resonant with whatever natural frequency was in the crust. Now if the geoscientists are correct the molten core of the Earth is spinning. This is a shitload of mass at high temperatures moving around just a few miles away. Think of an Earth sized sphere of molten if not vaporized iron spinning around in place of the moon. You sure as hell would get some radiant energy of some sort from it. Now think of having the same thing going on 30 miles down the road. Definite sun burn potential. Perhaps the Earth's energy flow is magnetosphere to polar regions to core vortex to surface to magnetosphere over and over. The energy taking on the form of massive low frequency electromagnetic radiation. Way below sound waves, but the em waves acting as carrier waves for sound or infra-red whatever. Inerton carrier waves. :-X
double post
Quote from: mxt on February 22, 2008, 01:08:56 PM
Mx
Not only, also this is pritty much interesting:
Arab?s was to place their women in tombs with gabled ceilings (as
opposed to flat ones for men), so this room came to be labeled by the
Arab?s as the Queen?s Chamber. The chamber dimensions are 18 feet
10 inches by 17 feet 2 inches. It has a double pitched ceiling 20 1/2
feet at its highest point, formed by huge blocks of limestone at a slope
of about 30 degrees.
When this chamber was first entered, the walls
were encrusted with salt up to 1/2 inch thick. This has been removed
since then, most likely when the chamber was cleaned. Salt
encrustation was also found on the walls of the subterranean chamber.
The cause is unknown.
If the chambers were filled with salt water, than whatever process happened might have left residue of salt on the walls once the water evaporated/leaked out. Do they mention what kind of salt it was (magnesium chloride, natrium [aka sodium] chloride)?
Salt water could've acted as a collector, a converter or a conductor of waves or energy (which are basically one and the same, oscillation is energy)...
Salt water was used in the very first capacitors the leyden jar. It is a liquid electrical conductor. The razor blade sharpening sounds like what Keely was doing with resonating sound waves to "machine" the inside of organ pipes.
The sand mentioned sounds very much like a type readily available on some Australian beaches, "Squeaky beach" being the most well known, I have personally walked on this sand and it has different Rheology to the more common sands, it is also almost pure white and it does squeak. Hope that helps someone.
Hi MXT,
thanks for the link to that eBook from Golod, but this does not work for me. Can you put it somewhere else or send it to me by eMail? Thanks much!
Best,
Spacetrax
Quote from: mxt on February 22, 2008, 11:43:54 AM
Mx
Hi,
thanks for posting this. Do you have some pics of this sand, maybe you can chose a segment of your holiday pics and post it here. Thanks!
Best,
Spacetrax
Quote from: PulsedPower on February 23, 2008, 11:20:27 PM
@spacetrax
My snaps of this are on film which show nothing other than white sand, google will turn up pictures but they will reveal little about the sand itself.
This type of sand appears to have some application in the foundary industry as casting sand, there are many different types of casting sand but at least there is a chance of getting a local supplier.
Quote from: rensseak on February 22, 2008, 05:30:56 PM
Mx
of about 30 degrees. When this chamber was first entered, the walls
You are forgetting the aplicable time lines here, what historical events might have caused sea water to flow into such chambers (through ventilation holes, which are well documented) aslo such events have caused erosion through which egyptologists have dated the sphinx, and guess, what...........its alot older than we think.
Quote from: spacetrax on February 23, 2008, 11:50:08 PM
Hi,
Best,
Spacetrax
Hi all,
you watch this if you want to hear how it sounds:
http://youtube.com/watch?v=pTgInGXAbHo (http://youtube.com/watch?v=pTgInGXAbHo)
its also nice to heare the sound of singing sand dune:
http://www.youtube.com/watch?v=trg66lPQc5M&NR=1
hello all
You might like to see christopher dunns explanation of the GPG I think that this would clear up alot of debate about the salt on the walls,the chambers and so on. You owe it to yourselves to watch this video
Michael :o
"http://video.google.com/googleplayer.swf?docId=2676128221474744663&hl=en" flashvars=""> </embed>
Hi Spacetrax,
I don't think it will go through the mail server as this eBook is 15MB in size. Later I'll try to place it somewhere online.
Mx
Quote from: spacetrax on February 23, 2008, 11:47:46 PM
Hi MXT,
Best,
Spacetrax
Hi,
eBook can be downloaded from my ftp server:
ftp://ou@85.15.246.98
password: ou
P.S. access to this account is valid 3 days.
Mx
Quote from: mxt on February 24, 2008, 10:34:49 AM
Hi Spacetrax,
Mx
Hi MXT,
Best,
Spacetrax
Thank you very much!
Quote from: mxt on February 24, 2008, 07:27:41 PM
Hi,
password: ou
Mx
Hi Spacetrax,
Mx
Hi MXT,
Best,
Spacetrax
Hi,
What did you mean by this:
"the special sound entered a state of resonance and now permanently receives the pyramid energy, without needing to be pumped with sound."
This makes no sense, I think you wanted to say "the special sand entered a state of resonance..."...
that would make a lot more sense.
Best,
Spacetrax
Quote from: PYRAman on February 22, 2008, 11:08:39 AM
Hi,
password: ou
I can get empty pages only
helmut
same with me!!
eden
Only directory
No Contains that can be load
Pesw
Only directory
Pese
Mine worked last night okay with all files.
@ PYRAman
Have a question for your half god. Always wanted to know how they built these Pyamids with huge blocks and how they lifted them. Even today it would be almost impossible. There has been so many books on the topic. Just like to hear your words on this.
Wayne
Hello everyone.
Long time lurker, first time poster.
For those having issues with downloading the PDFs, you may want to use wget utility.
It works both under Linux as well as Windows.
Once you have it installed, from command line type : wget -m -k -c -np --ftp-user=ou --ftp-password=ou ftp://85.15.246.98/
Wget then will mirror the entire directory onto your hard drive. I did this last night and tried again a few minutes ago just to be sure.
Location for Windows binaries: http://www.christopherlewis.com/WGet/wget-1.11b.zip
Linux users often get wget installed by default.
Unzip the file, then run wget from within the directory where zip file got unzipped.
Good luck.
Alternatively, I could upload the PDFs to zshare, but would prefer to have the ftp server owner's permission before doing so.
Jacek
VERY BIG SURPRISE. I got a photograph by mail from Lebanon showing a creator with a message on the back of the photograph. Now I KNOW that the half-god exists in flesh and blood, until now I only believed it because the technical information that I heard in my mind was accurate.
But I never thought of my address while he spoke to me, so it seems that he can know everything about me even if I don' t think about something specific.
I felt a very strong emotion seeing the photograph and the"half-god' seemed to be aware of my emotion because I immediately heard his voice in my mind. He felt that I don't fully understand the message so he said I should write down a new message explaining everything.
Here it is, I write it with capital letters because it comes from him, not from me.
YOU PEOPLE MUST KNOW THAT YOU HOLD THE BIGGEST TREASURE IN YOURSELF AND THAT IS YOUR DNA WHICH CAN MAKE YOU A MUCH MORE ADVANCED BEING UNDER PROPER CONDITIONS. YOU TREASURE SO MUCH A LOT OF THINGS THAT ARE NOT PART OF YOU BUT YOU DON'T PAY ATTENTION TO WHAT YOU BEAR IN YOURSELF. YOU SHOULD KNOW THAT NOTHING MUST BE MORE IMPORTANT TO YOU THAN YOURSELF, NOT EXTERIOR THINGS, NOT ANOTHER PERSONS, BECAUSE NOTHING ELSE IS PART OF YOU REALLY.
IF YOU BECOME AWARE OF THAT AND BEGIN TO TREASURE JUST YOURSELF, YOU WILL NOT BEHAVE LIKE STUPID HUMANS GREEDY OF THINGS, WEALTH AND ANOTHER PEOPLE THAT YOU WANT TO OWN AND THE WORLD WILL NOT BECOME DEPLETED BECAUSE OF YOUR GREED FOR EXTERIOR THINGS.
I WILL SAY NOW WHAT MUST HAPPEN WITH YOU AND WITH YOUR DNA IN TERMS OF YOUR SCIENCE. WHEN YOUR LIFE BEGINS A LOT OF NEURONAL CONECTIONS ARE MADE IN YOUR NERVOUS SYSTEM ACCORDING TO THE ENVIRONMENT THAT YOU SEE, TOUCH, SMELL, HEAR AND SO ON. THE INPUT OF EXTERIOR INFORMATION IS SO GREAT IN YOUR YOUTH SO THE BRAIN HAS NO MORE TIME AND RESOURCES TO BUILD NEURONAL CONNECTIONS ACCORDING TO A VERY SPECIAL INFORMATION THAT A PART OF OUR DNA HOLDS. SO, INSTEAD OF BECOMING A HIGHER BEING ACCORDING TO THE DNA INFORMATION, YOU BECOME A SIMPLE HUMAN BEING ACCORDING TO THE ENVIRONMENT YOU LIVE IN. THIS ENVIRONMENT KEEPS YOU SO BUSY AND BOMBARDED WITH ALL KINDS OF EXTERIOR INFORMATION SO THERE ARE NO PROPER CONDITIONS FOR THE SPECIAL DNA INFORMATION TO DICTATE THE FORMATION OF YOUR NEURONAL CONECTIONS. THAT IS WHY YOU ARE ALL WEAK BEINGS AND NOT SO SMART.
SELFISHNESS IS ACTUALLY GREED SO IF YOU ARE NOT GREEDY YOU ARE NOT SELFISH AND YOU ALLOW OTHER PEOPLE TO HAVE ENOUGH PART OF RESSOURCES FOR LIFE SO THAT EVERYBODY HAS ENOUGH FOR LIVING AND ALSO ENOUGH PEACE IN THEIR HEARTS BECAUSE THEY MUST NOT STRUGGLE FOR THEIR LIVING ANYMORE.
IF YOU ARE NOT SO BUSY WITH GATHERING THINGS ANS WEALTH YOU ALSO SAVE A LOT OF ENERGY FOR YOUR BRAIN AND ALLOW IT TO ALSO MAKE NEURONAL CONNECTIONS ACCORDING TO THE DNA INSTRUCTIONS. NOW YOU SEE HOW GREED DIRECTLY MAKES YOU A WEAK BEING.
THIS WAY OF LIFE WILL NOT GO ON. SOME CREATORS ARE ALREADY HERE FOR REACTIVATING THEIR OLD UNDERGROUND DWELLINGS IN THE MIDDLE EAST AND FOR COMMUNICATING WITH RELIGIOUS LEADERS BECAUSE THE COMING OF THE 40 MILLION CREATORS NEXT YEAR COULD CAUSE PROBLEMS IF EARTH POPULATION CONTINUES TO BELIEVE IN FALSE RELIGIONS TELLING THEM FALSE STORIES ABOUT GODS AND GODS POWERS AND PUNISHMENTS.
THE WORLD LEADERS WILL NOT TELL YOU THAT THE CREATORS ARE GOING TO COME BACK BECAUSE THEY WANT THE COMING TO BE A FULL SURPRISE MAKING FEAR AND PANIC SO YOU WILL BELIEVE THAT THE CREATORS ARE EVIL BEINGS COMING TO CONQUER THE EARTH.
THAT IS WHY ALL OF YOU ARE KINDLY ASKED BY THE CREATORS TO TELL AT LEAST TO YOUR RELATIVES AND FRIENDS ABOUT THEIR COMING, SO THAT PEOPLE WILL BE PREPARED AND NOT TAKEN BY SURPRISE.
AFTER THEIR COMING BACK THE WORLD WILL BE FULLY REORGANIZED SO THAT EVERYBODY WILL BE NOT FORCED ANYMORE TO STRUGGLE FOR LIVING AND THUS WILL HAVE THE CHANCE TO EVOLVE FURTHER.
ALL DEBTS WILL BE ERASED AND THE EARTH CURRENCIES WILL BE REPLACED BY A SPECIAL CURRENCY THAT CAN NOT BE ACCUMULATED IN GREAT AMOUNTS, SO NOBODY WILL BE ABLE TO BECOME VERY RICH AND TAKE AWAY TOO MUCH RESOURCES FROM OTHERS. STATES AND BORDERS WILL DISAPPEAR AND THEIR EMPLOYEES WILL BE EMPLOYED MAINLY IN AGRICULTURE, SINCE THEY DON'T KNOW TO DO A CREATIVE USEFUL WORK. HUMANS WILL NOT LEAD HUMANS ANYMORE, SINCE THEY ARE TOO STUPID TO DO THAT WITHOUT DISTROYING THE PLANET AND THE LIFE OF OTHER PEOPLE.
ALL CONTRACTS OF ALL KINDS WILL BE UNDONE. EVERY HUMAN WILL BE SUPPLIED WITH ENOUGH FOOD AND ENERGY FOR FREE SO THAT EVERYBODY HAS PROPER CONDITIONS FOR FURTHER EVOLUTION. EVOLUTION SHOULD BE THE MAIN PURPOSE IN LIFE, BUT IT WILL NOT BE FORCED, THE HUMANS WHICH WANT TO DIE IN THEIR ACTUAL CONDITION CAN DO SO. THE OTHERS WILL HAVE SPECIAL PROGRAMS OF ENVIRONMENTAL REST PERMITTING THEIR DNA TO CREATE NEW NEURONAL CONNECTIONS SO MAKING THOSE HUMANS ADVANCED AND LONG LIVING BEINGS. HUMANS WILL BECOME FREE FROM ONE ANOTHER.
BUT THERE IS ONE BIG PROBLEM, UNTIL THEN YOU PUT THE PLANET IN GREAT DANGER EXTRACTING OIL AND SO LEAVING GREAT HOLES IN THE EARTH WHICH WILL SOON CAUSE EXTREME NATURAL DISASTERS. YOU MUST STOP USING OIL PRODUCTS SO THAT OIL EXTRACTION WILL COME TO A MINIMUM. MAKE YOUR OWN ENERGY, USE VEGETABLE OIL AS A FUEL FOR YOUR CARS AND MAKE YOUR OWN ELECTRICITY. IT IS ALREADY TOO LATE FOR STUDYING ENERGY FROM PRAMIDS, SO USE MORE CONVENTIONAL WAYS OF MAKING ENERGY. A LOT OF ENERGY PRODUCING PYRAMIDS WILL BE BUILT BY THE CREATORS AFTER THEIR COMING NEXT YEAR, SO YOU WILL SEE THEM IN ACTION SOON ENOUGH.
this is the text from the back of the photograph
and this is the photograph of the Creator
I used normal table salt in the lower pipe
Quote from: amigo on February 22, 2008, 11:25:09 PM
yes, the sand must make sounds when walked upon so it will react when sounds are applied on it.
thanks, I will try to download them too, it seems to be very interesting information, I visited Golod's website and was impressed by his discoveries.
Hi,
password: ou
Mx
Hi Spacetrax,
Mx
Hi MXT,
Best,
Spacetrax
yes, it was my mistake, the sand becomes excited and remains so after a while, even if I TURN THE SOUND OFF. I made a small sketch, sorry for the poor quality but I am no talent, I made it with Paint for Windows.
Quote from: spacetrax on February 25, 2008, 01:05:10 AM
Hi,
Best,
Spacetrax
Hello,
You are getting empty pages because the connection has timed out. In most cases if not at all the cause is if both sides (client and server) are firewalled. FTP server is behind firewall. I have tested the client behind the firewall and it worked just fine for me with Firefox and UNIX CLI FTP client. Don't know anything about windows as no one is using this OS around me.
Mx
Quote from: helmut on February 25, 2008, 05:00:29 AM
Hi,
password: ou
helmut
Hi,
No problem! Of course you can take and share these doc's. I'm illegal owner of these doc's and I'm not proud about that. You can become like me any time. You are welcome!
Mx
Quote from: jacek on February 25, 2008, 10:56:01 PM
Hello everyone.
Good luck.
Jacek
@PYRAman
The Creator does good,to speak to you,so we can communicate all ready now.
I guess,that everyone here as members and readers are interestet to do the best,to save the planet.
But as you can see,there are many qoestions left open.
Now we have a guide to build a pyramide.
He told us,not to use black Oil anymore to save the Planet.He told us to use Vegetable Oil.
But this is a Problem .The Oil is quite expensive too,and the use brings one in trouble with
the local Goverment via tax fraud.At least in my country.
Can you ask the Creator plese some Question?
What about HHO ,Brown Gas or any other fuel to use in car?
What about electricity? By finding a way to produce electricity cheap at home,we can switch off the
oil or gas Heater . Many of us are willing to change the supplyment of energy to get off the oil.
Thats one reason we are here.
What about Gravity.?
Is there a save way to get Gravity in use to produce electricity?
Can we make a eart battery or cristal Power to bring us energy?
As the creator knows all the Nature,maybe he can give instruction
to us,how to build a device.
So than we can start emidiantly to save the planet.
helmut
@PYRAman
did he call himself a "half-god" or did you give him that title?
@PYRAman. You say that the resonant chambers are glss lined. How exactly is this acheived?
I'm wondering if the molten iron core of the Earth is surrounded by a cooled layer of frozen iron. As the thermal energy from the core of the Earth passes into this frozen iron layer it creates thermionic emission. Converting heat to electromagnetic energy. This energy then travels through the crust as low frequency em waves with very little absorption.
Pyramid power scource?
PyraMan ....
I think your pipe is leaking.
8)
@Pyraman,
I guess the level of water will determine the resonant frequency inside the air part of the chamber.
Do you have sand in the upper pipe for the Kings chamber?
I would also like to know how the great pyramid was assembled, can you ask your freinds this question.
How were the stones quarried, move and positioned?
What equipment was used to accurately calculate the size and placement of stones?
Also how did salt end up on the ceilings inside the great pyramid, was this from flooded seawater or intentionally pumped in?
How does your friend know when the creators are returning, for example, does he have contact with them?
Is the return anything to do the return of planet X or Nibiru?
Rob
For those still having issues with downloading the PDFs, here is another link:
http://www.zshare.net/download/81519918136dd2/
The files have been compressed with tar/bzip2.
HTH.
J.
Hi@all,
so they are here right now?...unbelievable...
I?ve got an idea, do you know the spaceship pictures taken by Lenard Walson? He believes they are secret spaceships of our governments, but what if they are in fact ships of these Creators? Have a look here
http://www.rense.com/general79/myst5.htm
Best,
Spacetrax
Hi,
making enough cheap electricity for your home is not a problem, everybody can build a pedal powered generator. http://www.humboldt.edu/~ccat/pedalpower/
...and you save a lot of money by not going to gym anymore ;) and also stay healthy and in good shape because of everyday workout.
I?m going to do that, now I have a good reason...until today I was too lazy :'(
Best,
Spacetrax
Quote from: helmut on February 26, 2008, 11:26:34 AM
@PYRAman
helmut
I think I found the easiest way to create some decent power at home. If you have a regular bicycle you put the rear wheel on a device like that http://www.econvergence.net/electro.htm and here you go! The thing is expensive, but you can weld the few pipes yourself and use an old car alternator as a generator. I guess you can make it for less than $50 .
Best,
Spacetrax
Quote from: spacetrax on February 27, 2008, 02:17:18 AM
Hi,
Best,
Spacetrax
@PYRAman
helmut
one more idea... ;D
find a wrecked car driven by a diesel engine, place it on your backyard, use vegetable oil instead of diesel and replace the alternator with a more powerful generator (or not...). The car doesn?t move, so the oil consumption should be very low.
Quote from: spacetrax on February 27, 2008, 02:51:10 AM
Best,
Spacetrax
Hi,
Best,
Spacetrax
@PYRAman
helmut
Hi@all,
I?ve enlarged this picture and I?ve seen something red coming out of the cloth in the upper left corner. Are they red, or what?...
Which one af all known religions has red "gods" ?
Best,
Spacetrax
Quote from: PYRAman on February 26, 2008, 03:08:09 AM
Quote from: spacetrax on Today at 09:51:10 AM
one more idea... Grin
End
Thats what i had all ready in mind
I have a old Diesel Engine from my Sailboat 10PS that can drive a Generator 5KW
But the Engine will consume 2 liter oil/h This adds to a total of 48Liters a Day
My daily need is about 10KW/ a day. Vor this i have to pay 2?uros.
Now do your own calculation.
If there is any usefull way to produce Zero Point Energy according to my personal needs and in a economic way
,i will be the first, to produce a device.
But: Until now,there is no information available to me,that matches the conditions.
So if Pyraman is able to bring such plans here,he will be my best friend.I will invite him to my home and
will try to give him a good time.
Until now his comments souds a little like, a sience fiction story.Compared to others,he shows a device,
and pics,and is doing not blame to others . Thats what i like.
And i am a friend of sience fiction.
helmut
I'm sorry but none of those ideas above are "free" energy. You have to eat nutrients in order to ride that bike, and if you are tired, sick or disabled, then no dice. Vegetable oil has to be processed and if it costs more energy to process it than it produces than it is not worth it.
Then again, even this pyramid heating is not cost effective (energy wise) if you had to invest energy through those 2x10W speakers, which had to be hooked up to an amp and a pre-amp, signal source, etc.
I am of a belief that there's no free (as in beer) energy out of the blue, therefore we must make a small investment of something to (hopefully) get a lot back. Because nature does not work on closed loops we are bound to get energy in a form that our current appliances/applications will not be compatible with. The goal should be two-fold: first we need to produce (negative) energy with a small investment from our side and collect, convert or use it.
If we wish to directly use it then the second part comes in, we need to design/create all new devices that will directly use the energy in the form we obtain it from the Nature, which means new light sources, new motors, etc. The task might be daunting but nothing is impossible, if there's a will there's a way.
PYRAman, if your friend could share with us a proof-of-principle electrical device as well as a light source and a motor that could satisfy those requirements above, that would be really helpful and practical at this point. Everything else is pointless if we are beating around the bush as many researchers are, without the "primer" on how to actually do it.
Just my 2c...
Hi,
I wonder how much fuel will consume the engine of my car if I let it on for a few hours. Your old diesel engine is probably not so energy efficient like the engine of a modern car, so using the very same car that you drive, for electricity generation might be a good solution.
Best,
Spacetrax
Quote from: helmut on February 27, 2008, 07:48:53 AM
End
helmut
Hi,
you are absolutely right! But, as I understood from the messages of the so called "half god" we should now save the planet, not our money... :o If this story proves to be real, our money will be replaced by a new and special currency after the coming back of the "Creators" so the bucks will be of no use anymore.
Best,
Spacetrax
Quote from: amigo on February 27, 2008, 09:14:11 PM
Just my 2c...
I'm really not worried about money in the equation when we speak about clean energy - money should simply not be an issue when it comes to survival of mankind versus destroying our habitat. What I'm talking about it taking the money totally out of the equation because it is one of the corrupting influences. We need a source of energy that will overthrow current system of dependency where we pay a racketeering fee to get onto the grid.
This energy source has to be clean and simple yet impossible to block or put a meter on and charge for it. Therefore we need a primer from whoever is willing to help us at this stage, because as it seems we are to dumb, to ignorant or to disconnected from the Nature to figure it out on our own. :)
Hi@all,
I finished my russian type pyramid, I made a 7 ft. high piece and after some hours of pondering I decided to spend at least 15 minutes inside to see how it feels.
Well, against all expectations, it worked in some way. I remained in the pyramid longer, seated on the ground nearly half an hour, and after some time I felt a great pressure on my forehead, like when the blood pressure rises very much. And after getting out of the pyramid I was very, very tired, I think it was too much!
So, it works and the effects are quite obvious. I attach a picture. The material was wooden plates made of pressed wooden chunks, commonly used in construction works.
Best,
Spacetrax
hi ,
I'm not privy of the Russian pyramids, but it looks dimension wise a little different than the GPG dimensions, Probably it's the camera angle. I don't ever remember getting a headache after sitting or sleeping under one. did you have a headache to begin with? I like the back ground in the pic, reminds me of the calif, foothills
michael ;)
Hi,
it?s about these russian pyramids http://www.gizapyramid.com/russian/picture-tour1.htm
Also, Pyraman said that his "half god" adviced him to build such a pyramid for medical purposes.
Best,
Spacetrax
Quote from: mungibung on February 29, 2008, 01:22:21 AM
hi ,
michael ;)
Nacl crystals are pyraelectric. When heated they will develops an electrostatic charge. The pyramids of Egypt look like some kind of scam by the religious orders of the time. Enslaving people to build monuments to the man made God pharoh dynasty. What a crock. The Egyptians had battery technology and probably alot more that we don't know about. They probably used battery power to emit a light out of the shafts as well as resonating chambers with some sort of minor explosions going off to convince the working joes that there were big things doing in the graveyard. Priests sneaking around fillingup battery resevoirs and throwing switches. Wizard of Oz kinda shit.
Below is a link to salt water burning. The water is exposed to rf and it burns. Must be nasty though if chlorine gas is coming off.
http://www.youtube.com/watch?v=h6vSxR6UKFM&feature=related
;D
Quote from: sparks on March 01, 2008, 01:02:27 AM
Hi,
No, I did not have a headache, it was just like when you put your hand on the forehead, it was just a gentle pressure.
I thought that this feeling might have been caused by a blood pressure increase, that would mean, the pyramid field kind of activated my body to work harder. Possible outcome of this higher activity could be the healing of diseases and even rejuvenation. That would be inline with the tiredness I felt afterwards - after a sudden increase in body activity you are tired. But strange, that activity wasn?t caused by some physical exercise, since I was seated on the ground all the time, but by the pyramid field.
I encourage you to build such a pyramid, it is well worth the money! I?m planning some experimenting in the pyramid, I?ll keep you updated.
Best,
Spacetrax
hi ,
michael ;)
I can not talk to the Creator, only the "half-god" speaks to me when he wants to.
He seems to be aware of my activity here and he also knows your questions, so he said that we can use brown gas very easily in our engines, it will cut the gasoline consumption.
Gravity as a power generator is not easy to use unless you have an antigravity device to disturb the ballance into a gravity engine.
Earth batteries are too weak so they are of little use if not installed on a very big surface. Crystal batteries are ok, the pyramid is also a kind of crystal battery.
The Great Pyramid was built by the Creators by decreasing the mass of the stone blocks by some 90%. It is the most powerful crystal battery when put to work. When this pyramid works hard and transforms the gravity into useful energy its mass decreases. This is how so called antigravity is generated.
He said you should not worry about laws and taxes, next year they will not exist anymore. Do not let other humans dictate you what to do, they have no right to do that since they did not create the Universe and you other people.
@PYRAman
helmut
Yes the power of the pyramids was used by the oldest pharaos to justify their power over the people by making them appear as having supernatural powers. But only the most old pharaos knew how to use the Great Pyramid, sometime in the history they closed it hermetically. The power of the newer pharaos was given only by tradition, that is why it finally collapsed. They could not demonstrate their supposed powers to the people.
Nice work, my healing pyramid looks like yours, but I did not paint it.
Quote from: spacetrax on February 29, 2008, 01:01:10 AM
Hi@all,
Best,
Spacetrax
Hi Pyraman,
Have you done any more tests on your pyramid?
To calculate the power output from your pyramid you need to wrap a plastic tube around the copper pipe and pump this around and into a large reservoir tank with say 1 litre of water, then measure the temperature rise over time to calculate the Joules of energy required to heat the water.
I do not know if extracting heat away will effect the operation of the setup, certainly the plastic tubing may dull the accoustics.
You could trickle water over the pipe into your collector using a small pump or a bucket with a small hole in it and fill it using a plastic jug.
4,186 Joules to raise the temperature of 1kg of water by one degree C
1Ltr = 1Kg of water
So if you can heat 1 L of water from 20C to 50C then you have done 30C x 1L x 4186 J = 125580 Joules
If you plot time against temperature we can work out the power in watts too.
1 Watt = 1 Joule per second.
So if you raise 20C to 50C in 600 seconds (10 minutes) then 125580 J / 600 Secs = 209 watts
If you want to be really accurate you need to put your containers in polystyrene insulated containers.
Rob
Hello Pyraman !
Thanks for your posts.
I build two resonators, but I donââ,¬â,,¢t know where I have to put them in the pyramid because the section of the giza pyramid does not correspond (from mine viewpoint) with your picture that you posted. The horizontal red lineââ,¬â,,¢s are on the heights of the the kings and queens chambers. And the resonators they connect the two red lineââ,¬â,,¢s but it does not correspond with your picture that you took of your pyramid.
Can you help me out? I already have the pyramid and the rest, i only need some good dimensions. And are the copper tubeââ,¬â,,¢s connected in the center of the resonators?
Thanks,
Olivier
Here are the other pictures
Thanks,
Olivier
PYRAman,
Thanks for the responses from your friend, I am just not sure what is he telling us. Should we just sit down, cross our hands and wait till the next year for whoever to appear?!?
To me that sounds pretty silly because if we don't at least give it an effort and try to help ourselves no one will come to our aid later. Therefore if he is offering help, could he please provide us with some concrete and useful information that one of us here can hopefully put to a practical use. So, no mambo-jumbo tales of ancient devices or folk stories you can read on the Web from the turn of the last century, but a real honest to God primer of an energy producing device, a proof of principle that we can build, test and show it works without a shadow of a doubt.
Just my 2c...
Hi,
besides technical information, something still bothers me ... and that is the picture of the supposed Creator. It looks pretty earthly, there is nothing special and alienlike at this supposed Creator.
So Pyraman, how do you explain this?
Best,
Spacetrax
Quote from: amigo on March 03, 2008, 07:39:20 PM
PYRAman,
Just my 2c...
Quote from: spacetrax on March 04, 2008, 12:02:18 AM
Hi,
Best,
Spacetrax
PYRAman,
Just my 2c...
As i read your replay i like to show you that Pyraman told us,how to see it.
I guess this makes a big difference.
He Wrote:"I can not talk to the Creator, only the "half-god" speaks to me when he wants to. "
helmut
@Pyraman
Please ask your Contaktman from Lebanon,if he will supply us with a instruction ,how to build
a device,that make free electricity .
Or he can give advice to the Builders of the Traw?ger Pyramide,to mahe their Builings working.
Since Thomas will not show up and is missing in the group,they are without chance to develop the
missing structures by themselves.
i like to ask you,how offen you get in talk to him.
Regards to you and to him
helmut
I'm really hoping (for PYRAman's sake) this isn't one of those psy-ops where they would beam stuff into people's heads and they would think they are talking to god (g purposely small, the real God with G is something incomprehensible to us amoebas and therefore cannot have a conversation with)...
We all probably get spoken to by the 1/2 gods when we sleep. 8hz frequency transmitter of some sort. Pyraman is just sleep typing. ;D
Hi Pyraman
I am a very open to anything in life and have very deep rooted spiritual believes and have studied many mediumystic avenues while on this jourmey of life.
I know it is possible too communicate with different energies in different dimensions, so cool if you have tapped into a energy that you believe to be who you say he is, that is your freewill to beleive this.
But one thing I do not understand is what you see in this picture? .
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.overunity.org.uk%2Fcrea3.jpg&hash=45c5e6473b8dcfe0820aa8b80af324fffc24c05a)
As I cannot make out anything but a piece of material?
Sean.
Hi@all,
Jerry Bayles, owner of the website http://www.electrogravity.com just posted this message on his Yahoo Group:
Calculated Age of the Great Pyramid
Mar. 04, 2008
Based on the slowdown of the Earth at .0018 seconds per century, I
calculate that the Great Pyramid is slightly less than 400 million
years old. (This is based on the necessary changes in velocity based on
4/pi being exact related to rotational energy being compared to
inertial energy.)
Further, based on that calculation, I propose that the Great Pyramid
was used as a microwave Generator in the manner of HAARP to terraform
the planet for suitable species by offworlders.
Humans may be engineered by offworlders as well as species in general
on this planet. As such, our seed or DNA may be taken at will for use
on other worlds. We are harvested as an ongoing project to improve and
propagate other worlds which are also being terraformed.
I see no conflict with being a Christian according to the above
concept. Jesus was a human as well as is a supernatural being. The
conncept of using physical means to acheive a supernatural purpose has
already been established many times over in the bible.
In computer terms, the physical world for humans and creation in
general must step along in serial fashion and is thus limited to a rate
of progress while the supernatural occurs in parallel fashion and is
not constrained by time past or future.
In slices of time, many worlds may thus exist side by side.
Respectfully,
Jerry E. Bayles
jebayles2001@yahoo.com
ElectrogravityWorks
PS: Jerry, if you read this, I hope you won?t be upset because I posted your message here, but it is of high interest in this thread.
The resonators must be fully closed, glass plated and air tight. This way it will not work. If you dont have singing sand it will not work, too. But good luck.
Quote from: olivier on March 03, 2008, 07:24:06 PM
Hello Pyraman !
I build two resonators, but I don?t know where I have to put them in the pyramid because the section of the giza pyramid does not correspond (from mine viewpoint) with your picture that you posted. The horizontal red line?s are on the heights of the the kings and queens chambers. And the resonators they connect the two red line?s but it does not correspond with your picture that you took of your pyramid.
Can you help me out? I already have the pyramid and the rest, i only need some good dimensions. And are the copper tube?s connected in the center of the resonators?
Thanks,
Olivier
No, we must build clean energy devices and use them exclusively.
PYRAman,
Just my 2c...
I will aks him next time we speak.
Quote from: helmut on March 04, 2008, 11:56:52 AM
@Pyraman
helmut
No, I am not in such a case.
Quote from: amigo on March 04, 2008, 08:44:29 PM
The half-god told me that the Creator did not want himself to be seen until next year, because a certain religion has very old pictures of them and by showing himself now, their priests and believers will say that their Mesiah has arrived and a lot of turmoil will be on in the world. The Creators dont care about leaders and armies, but about what is in the peoples minds and hearts.
So, the Creator wanted only the people to know that he is here and that he is a giant, nothing else. So the half-god put two big pieces of cloth on him, his servant and apprentice took a picture and wrote the text on the back.
Hi,
Best,
Spacetrax
PYRAman,
Just my 2c...
The half-god said that the Creator is standing and photographed from the left back. He carries something on his back.
You should be not so doubtful, the half god said that you are all quite special people since you got interested in this. In his community he is known as a wizard and has even a few pupils, but the people there dont know that he is so old and who he really is. He has supernormal powers and kind of scanned your minds and bodies since we are on this track. He said, there is somebody there who is really special, nickname spacetrax, he has some special DNA but it needs environmental rest in a pyramide a couple of hours daily for this DNA to come to expression.
Quote from: CLaNZeR on March 05, 2008, 03:37:13 PM
Hi Pyraman
Sean.
Quote from: PYRAman on March 06, 2008, 02:23:18 AM
Hi Pyraman
I would say you should always be dougtfull and should always question information you receive from Spirit (Energies) .
Any good medium will tell you this.
It is mental mediumship you are experiencing, not physical which means that your conciousness can interfere and interpret different to the message.
So always question information you receive to get clarification and also learn to ground and show intent to receive only the higher thoughts. With a little practice anyone can raise their conciousness and pickup information. It is the intent on your behalf to receive the truth that makes a difference.
There are plenty of mischevious spirits/energies that will tell you anything you want to hear if you allow them!.
So I would always say dought and always say question information you receive.
Cheers
Sean.
P.S Everyones DNA is changing at this time, it is part of the changes going on.
spacetrax, you read that what PYRAman wrote above?
I hope you are building yourself a small pyramid to meditate in for couple of hours a day. Just don't let it get into your head... :)
Is he mad? :o I am the most normal person, there is nothing special about me.
Quote from: amigo on March 06, 2008, 04:29:52 PM
Hi Folks,
The 'squeeky sand' can also be found in the UK, i believe it's one of the few places in the world where this shape of sand can be found. It makes the squeek if you shuffle your feet in it & It also sounds 'hollow' if you bang on it with your fist.
See here:
http://www.ukattraction.com/north-wales/whistling-sands.htm.
Tomorrow I'm going to the beach. It's Baltic sea Gulf of Riga. I know that there definitely is this type of the sand in some places, but... I don't know if I will succeed in finding it, because sand is wet and maybe frozen. I will take 10 or maybe more samples from different places and then will see when it will be dry.
Quote from: johnjety on March 07, 2008, 11:55:59 AM
Hi Folks,
See here:
Perhaps you and mxt become sand dealers?
helmut
Hi Johnjety,
thanks for the heads up on that, I have been weekend camping near Barmouth in the past so this is just around the corner so to speak.
I wonder if they will notice someone taking a bucket of the stuff home with them. ;)
Is there any chance of you getting a sample of it and sticking it under a microscope?
Another way may be to get some pure quartz pebbles and smash them with a hammer or heat them cherry red and drop them in water.
The put the crushed grit into a stone tumbler with more quartz pebbles to smooth them down.
Using a crude stone age hammer made of a large quartz stone bash the grit into sand (wearing appropriate safety goggles and dust mask of coarse!), may take a while but at least you will know its all quartz.
One of the other discussions in this forum is related to crystal batteries where they are crushing minerals in various ways to get fine grit.
Quartz (Silicon Dioxide) has some odd properties, six sided prism with a six sided pyramid at each end, its piezoelectric and if you apply a voltage across the crystal it will vibrate(I presume they mean pulsed potential) , very ubundant 98% of the earth minerals are composed of it.
Tourmaline (quartz family) is used to treat water by removing cholorine and ion components
Cheers
Rob
The inside of a pyramid forms a lattice whereby a vibration either is absorbed by the walls of the mass or reflected at an angle that sets it into a decreasing length lattice network effectively increasing it's frequency as the wave travels towards the top of the pyramid. . If the nile has or had an underground flow at one time the Pyramids could easily draw power from it's rumbling. Or maybe pressure waves of a migrating tectonic plate amplified.
Google "Brown Mountain Lights" This vibrating mountain geology creates plasmic energy balls.
Pyraman's configuration is cool. Loudspeaker pressure waves being converted to high frequency vibrations in the salt water via the sound sand crystals. The highly ionized dissolved salt generating voltage in the water. Then the copper pyramid antennae. You could probably listen to you pyramid vibrate on an am radio.
Hi@all,
I guess I?m gonna try this configuration if somebody can deliver singing sand to us. Who`s interested in doing the same for verifying the information?
Best,
Spacetrax
Quote from: sparks on March 07, 2008, 08:42:08 PM
Hello Pyraman
I have posted three images.
Nobody can reproduce it with the dimension that we have got. We need the dimension on the third image.
-1 In the first image the heights of the kings and queens chambers are clear (green). The resonator is red.
- 2 In the second image i put your image under the section of the pyramid andââ,¬Â¦Ã¢â,¬Â¦ You can see that they have a different angle (yellow surface) . And so there is some space between the heights of the kings room and the resonator.
-3 In the third picture, I marked the dimensions (with one angle) that we need.
Can you give us the needed dimensions, so i ( and others) can reproduce it.
Thanks,
Olivier
Hello PYRAman! Do you have any new information for us? Or have you lost your contact? If not can you ask how the Creators will arrive to earth? Thanks!
Quote from: polarman on March 16, 2008, 12:39:25 PM
After i saw the video from or with "William Cooper" i am afraid that some dark forces took him away.
I hope,that i am wrong.
helmut
Hi mxt,
have you got the squeeky sand?
@Pyraman: what is actually "environmental rest"?
Thanks,
Spacetrax
Quote from: mxt on March 07, 2008, 12:50:22 PM
Quote from: spacetrax on March 18, 2008, 08:04:45 AM
Hi mxt,
Hi,
I got the sand from here:
http://maps.google.com/maps/ms?hl=en&ie=UTF8&oe=UTF8&msa=0&msid=105877683972369186377.000448b6cb6103661d8c2&ll=57.122497,24.206577&spn=0.002006,0.005021&t=h&z=18
(http://maps.google.com/maps/ms?hl=en&ie=UTF8&oe=UTF8&msa=0&msid=105877683972369186377.000448b6cb6103661d8c2&ll=57.122497,24.206577&spn=0.002006,0.005021&t=h&z=18), but I don't know exactly if this sand is squeeky or not. It was wet when I collected it. I took the samples based on my intuition. So, I'm not sure is this the right sand we are looking for.
Here are a few images from location where I got the sand
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2F85.15.246.98%3A8000%2Fimg%2FIMG_1269.JPG&hash=fdde44e6abb10a4acda5738d789b58eaa3f70bf7)
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2F85.15.246.98%3A8000%2Fimg%2FIMG_1272.JPG&hash=9959b318fd9573608074df4cd6759ed1b140ebda)
The sand drying process:
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2F85.15.246.98%3A8000%2Fimg%2FIMG_1360s.JPG&hash=37a97094190dd7b3d36cfe40220463d3d92de803)
When the sand was dry I tried to get some squeeky sound out of it, but... nothing. Possibly, at home I don't have the right conditions for this sand to make a sound or much larger amounts of sand are needed to hear the specific sound.
The sand on the A4 size page:
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2F85.15.246.98%3A8000%2Fimg%2FIMG_1369s.JPG&hash=984c1218efb744326f12098c8246d35552f1a67a)
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2F85.15.246.98%3A8000%2Fimg%2FIMG_1367s.JPG&hash=925f04b1efce75d6a049bd08f3b5e31910d7c42b)
Enlarged previous image to see the sand grains:
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2F85.15.246.98%3A8000%2Fimg%2FIMG_1367ls.JPG&hash=b34c498eea995aeefa6f4ed9a1cf8f84e27e20b7)
The sand grains in details. Here we can see that these sand grains are with round corners:
SAND1 (http://85.15.246.98:8000/img/IMG_1376.JPG)
I had to update this post with one more important image where you could see how actually tiny these sand grains are.
SAND2 (http://85.15.246.98:8000/img/IMG_1394.JPG)
In the summer time it's easy to find the squeeky sand. Now it's a blind action.
mxt
Good report
At least we see the things moving vorward
helmut
Yes, thank you mxt for the pictures.
I?ve read that the right grains of sand are sorted out by the wind, so you must wait for the sommer. When the sand is wet the wind does not its job.
Best,
Spacetrax
Quote from: helmut on March 18, 2008, 01:45:09 PM
Good report
helmut
Hey, mxt.
Another fellow Latvian over here? Nice to know.
When jumping through this thread a couple of weeks ago and reading about the squeeky sand: Saulkrasti was the first location which jumped into my mind. I have a summer house over there :)
Hi aiks,
Yes. It's nice to know for me too. :)
I had actually two locations in my mind - Jurmala and Saulkrasti.
I did choose Garciems as that day I had to go to Riga.
I think, the squeeky sand can be found everywhere between Kolka and Saulkrasti.
I don't know about Ventspils region. In Liepaja there is very specific sand. You will not find like that anywhere else. I don't know if Liepajas sand is squeeky.
The two best cases of squeeking sand I can recall have been in:
a) InÃ,,Âupe (The very begining of Saulkrasti ) - right in the middle between the petrol station (nude beach) and "BaltÃ,, kÃ,,Âpa".
b) Few kilometers after TÃ...«ja - right where the VÃ,,«trupe enters the sea.
this sand can bee found in mangalsala were daugava enters the sea. i renember ewery times i bee there sand was strange sounds vhen walk on it.
mangaljsala pie mola tuvak ... vinja tada bruna rupjaka nekaa citur ejot chikst un tada tirpstosha sajuta druscinj pedai .
sveicieni latvijai :)
Singing Sands Beach PEI, Canada
http://www.youtube.com/watch?v=jYzghimHrLY
so singing sand can be found almost everywhere around the world
Hi guys what happened to pyraman?
He was a very interesting guy.Any info about him?
as many inventors, he disappeared suddenly, by chance we got all we need to replicate that resonating heating pyramid
this forum is full of paid conspiracy agents, when someone show somethig new and real, they take care of it with all the power of the NWO
Hi Drannom did you manage to do that pyramid?How much power did you acquire in amps and volts?
The interesting thing is that once I saw a german documentary film of close ecounters with aliens and one of these aliens gave a small gadget to this lady.
You know what this was?
A small crystal pyramid with 1inch square base with a circuit in it.
After analysing this pyramid it was found that it was a very strong transmitter and reciever.
Interesting about these pyramids cause it brought my memory back.
Drannom or any of you guys if you have the whole info how to replicate a pyramid which can produce great power in watts please send it to me.
Thanks guys.
Hello guruji
i am not working on that pyramid, we have to find some singing sand first, that sand has the hability to resonnate, then all the pyramid can resonate
ordinary sand can sing too, not the same sound, a very grave sound, i have view many youtube showing that, many people going down a dune on their back, all in the same time, and the sound look like and earthquake
for the moment i have only find this one
http://www.youtube.com/watch?v=Smk4BI8MVdQ it sound like a trumpet !
you'll find others if need
it make me think that the only difference between the two sands could be only in the form of each grain of sand
singing sand probably all spheric
other probably be almost sphere
we may be able to do it with mechanical erosion, and it will be not easy
Hi Drammon you should use that sand man it really makes good sound hahahahahah.
But that's not singing sound it's more grumbling sound :)
Ok ok bye bye.
the illuminati are extremely weak. most of their manpower and resources have left them, since 9/11/2001.
the illuminati will not be with us for much longer. they will be replaced with a wise, benevolent leadership.
i have plans to release what i know. and if whats his name doesn't complete my pyramid design, than i eventually will.
what is left of the TOOTHLESS illuminati, cannot touch me. and i laugh at the burning ruins of their backbone.
Hi guys the long pyramid is really powerful I did about four and a big one with cartoon and felt different energy.
I do meditation and am sensitive to energy guys it's true.
Nittinun let us know what you know about them as a generator please.
i posted about this in the news forum. but type about it here too:
* the pyramids magnetic field moves in one direction. from peak to base.
this is current. and current can charge up a capacitor!
to make the magnetic current strong enough to be useful, you must do a few things first!
* add a copper peak is added to the pyramid.
this will increase the capacity of the positive half of the pyramids magnetic field.
the copper peak will also force more "magnetic current" to flow through the pyramid.
* never allow the copper peak, to electrically touch the ground!
if the copper peak is grounded, than all of the positive magnetic energy will drain out of it and into the ground.
* you may wrap the base of the pyramid in aluminum foil. to increase the capacity of the negative half of the pyramids magnetic field. but this is not as neccessary as the copper peak.
* stick an "antenna" inside the pyramids peak. attach it to the positive half of a capacitor.
* stick another "antenna" inside the pyramids base. attach it to the negative half of a capacitor.
you could also stick the base-antenna into the dirt. so long as the base antenna is within the negative half of the pyramids magnetic field!
* the positive magnetic current should dump into the peak-antenna.
* the negative magnetic current should suck energy out of the negative half of the capacitor.
creating a negative energy debt, inside the negative half of the capacitor (this is how a normal capacitor works).
I don't know if this helps but the below diagram shows the relationship between the elementary geometric shape (the triangle) and segments and circles.
Sorry for my long absence. I was brought, but not abducted, in a deep underground facility that belongs to the old Creators. Please read the whole thread for details. Now I am back in my home country for two days, to bring with me a friend whom I fully trust. We are to become teachers of the mankind, a kind of interface between humans and Creators. I have learnt the language of the Creators, their history and technology. To make it short...The planetoid of the Creators is already at the outskirts of the solar system. The few Creators which are already on Earth have discussed with leaders of religions and only the Vatican wanted to recognise them. You know that the Vatican recognised the existence of extraterrestrial life earlier last year, as a surprising move. That was because the Church wants to survive as an institution after the coming back of the Creators. But no institution will survive as such, since they are all instruments of controll by which humans are made to obey to other humans. That situation will not last after the coming back of the Creators. Political powers are determined to prevent the coming back of the Creators and will announce their coming in mass media only one day before, so that the billions of people do not have time to be correctly informed and think for themselves. So it is now your time to help spreading this information, so that the people of the Earth will be not hostile to the Creators. Please translate my messeges into all languages and spread them. Of course I am not the only one to do so, they are many other people that have been contacted and entrusted with the same message. The Creators will gratify every human that contributes to the spreading of truth about them,. They can read your minds, so no other proof will be needed. Learn everything you can about pyramid technology as it is the main proof of the existence of the Creators earlier in the history of Earth. Spread the knowledge about pyramids ans Creators, so that at the time of their arriving most people on Earth will know the truth about them, and will NOT be deluded by the stories of the very rich humans who want to keep their power and immense wealth by preventing the coming back of the Creators.
Sparks that is truly fascinating because the zig zag lines look exactly like the graff i got when trying to make a magnetic heater as the cylinder wall thickness increased it would hit nodes of high heating and drop off then rise again to a new higher level and rise again it was an interesting machine some of the things i learned and saw left me scratching my head as there didn't seem to be logical answers perhaps the answer is in this line of thought as to how do waves propogate in materials of precise thickness as with solar heated materials not all panels heat the same i have been trying to solve this problem it could be the propogation of the wave along the sheat of material by type and thickness. interesting thought.
Quote from: PYRAman on January 03, 2009, 07:25:44 AM
@PYRAMAN
Thanks for the message.
Some of us have been missing you and had been afraid, that MIBs ar taking hands on you.
Is there not a internet Terminal, that you can continue to teach us?
How ever
Have a good time and be assured, that we search to have a change.
helmut
FFS ...
Whatta motivational speech.
You really think that there is a god. Maybe ;)
But what about a half god ? hell yea !
And there are a 14 pages full of replies.
There are saying that ppl who say not possible should not bother ppl who do it. ya get the idea.
im not too proud to say it out, but ... Naaa wont work out on this situation.
There are some very reasonable excuses for other threads but, there no future for this one.
Cant you feel the situation ?
There are some facts.... you cant learn C++ without knowing C. its against " that is the way things go" ...science daa
If you are looking for some interesting stuff like .. free energy maybe, you need to work hard on it, using practical/knows facts.
just nooo !!! you do it wrong !
Huh ?!
...and those who don't will burn in hell?
In any case I'm glad you are ok PYRAman, wherever you went to and whatever you did. :)
when is this to happen? it would be nice to know whats been covered up all this time, maybe it would help to stop all these wars and bring the earth together in peace
then maybe we can make some real progress in the world :)
I need to study pyramids more, I dont have many theorys to what they were used for originally
Nobody knows anything clearly...
Quote from: Aka on January 05, 2009, 10:13:27 PM
Quote from: nitinnun on July 31, 2008, 04:25:54 PM
You said this, Nittinun.
but you ever put in practice this?
I went away with my pyramid bettery charger, but I could improve it using your 2 clues" pusted 31 July 2008 as above.
Again, please let us know if you put in practice what you shared here with all of us.
tigrotto
The east facing side of a pyramid is heated first until the noon hour. This heating of the pyramid face will produce infrared wavelengths that will become shorter at the peak of the pyramid (less mass to heat) and increase in wavelength as you get nearer the ground. Perhaps this creates a magnetic wavefield at 90degrees to the infrared waves inundating the core of the pyramid. This magnetic wavefield would align north to south. Just a thought.
Hi Sparks,
did the heating bring something usable?
Thanks!
@Tigrotto: please post a diagram or a picture of your pyramid-battery-assembly. How do you connect the battery? To the poles of the condenser, as proposed by Nittinun?
Thanks!
Quote from: sparks on January 06, 2009, 01:17:57 PM
Nice to have you back. How fast does the planetoid of the Creators fly?
Thanks!
Quote from: spacetrax on January 07, 2009, 02:27:50 AM
Hi Sparks,
Thanks!
Thanks!
I'm using a Copper frame pyramid (Gizeh like) and a 10 microF capacitor.
The pyramid( frame), because it's an opened pyramid, is not grounded!
I connected the + of the capacitor on the frame and the - at ground.
The Li battery is connected to the capacitor.
Pretty simply. no more theories.
Try it .
It looks like none of us want to share its experiments but... tons of theories.
here comes the theory when you'll attain an even low "degree" of experimental work and you nedd to go ahead , but it miss the thoretical support.
Theory without practice is something like making love with a picture of a pretty women!!!
I kindly ask you to replicate this and to share the results.
Tigrotto
Thank you! I will replicate your setup.
Just one more idea: your setup looks like it is a simple antenna gaining some radio wave energy from the air - nothing more. Maybe you should make your copper frame pyramid as the top of a greater pyramid, built like the pyramid of Keops is: without the top (pyramidion). Use your copper pyramid as a top pyramidion of a greater pyramid made of gypsum plates. I will try to do this myself, but it will take some time.
Greetings!
Quote from: Tigrotto on January 07, 2009, 02:48:11 AM
Try it .
Tigrotto
I am unexpectedly back home because my old father died - but that is another matter.
I am sorry that I have no time to answer personal messages from you. I have to go back today. Last time I wanted to tell you more about how Creators look like but the phone ringed and I had to go. Well, the Creators look much like Jesus Christ, especially they have big and deep looking eyes and of course beards and that is why in march 2008 the picture that I got from Lebanon was of a giant man covered in cloth. It was intended that we only see how big he is. By then it was the danger that if a certain sect which awaits the second coming of Jesus Christ would have known that the Creators look like Jesus , that sect would have suddenly gathered hundreds of millions of people as their worshippers and would have gained a lot of political power also.
Now it is all settled and it is not a problem anymore to tell that 40 million Jesus looking giants are coming to Earth. As you may know, the Vatican was the only religious power which recognised the existence of extraterrestrial life publicly and that was because the Creator who talked to them looks like Jesus. All other religious leaders rejected the Creators. Now I will tell you the real story of Jesus as I heard it in the underground facility of the Creators. Jesus was a child in which a lot of the Creators DNA was summoned, by luck only. In his childhood a halfgod from the middle east recognised him and sent him to Egypt where he got environmental rest in one of the smaller pyramids until his DNA fully expressed in neuronal connections which gave him tremendous paranormal powers. After that he went back and begun to teach people about peace and justice and made the known wonders thanks to his brain powers affecting all matter. After his death his brain energy alone healed his wounds and he came to life again. But now he is not alive anymore. I know that this all looks like science fiction to most people and I hope that you will be not too much scared when seeing the Jesus like Creators with your own eyes.
Hi, this is my first post here, and I can tell you that as an observer of alot of theories and stories, one thing makes me a little uneasy. Much literature speaks of the coming of false god's before the real ascension of the human race. All of the images I have from the info on this thread is of the giants of the annunaki. I am spiritual myself, and an experimentor, I feel that this time of confusion is upon us. take care and be mindful of what is to come.
Sorry if I sound like a doomsayer but something feels odd.
Now I am allowed to tell you the solution of the pyramid electricity because the time of the Creators is about to come.
The key word is Iron Oxide. These crystals are like tiny diodes whose signals can be collected through a copper plate or graphit electrodes. The pyramid that Trawoger built is a kind of powerful waves collector working with thousands of iron oxide diodes at the same time. Iron gets oxidized in salted water. Once you have thousands of diodes, the rest of the receiver is clear. Coils and capacitors will tune this "pyramid radio" into frequency. If you make a losen capacitor and vibrate it by sound it will make a variable capacitor being able to tune the pyramid into thousands of frequencies at the same time. This is a lot of energy. The pyramid frame must be well earthed, like Trawoger said. The energy comes from the sun and other stars and is polarized by the magnetic field of the Earth. This pyramid is much easier to make than mine, which needs singing sand to work.
I have told you the essentials, now you must imagine the rest and put it to work. You must do a little thinking work too, it is imperative for your evolution. The Creators do not give everything ready made and read to use, they want to stimulate your evolution - and mine too. At this time they only want to give hints. I am not allowed to tell you more now so please do not ask further questions. Everything else will be revealed at the right time.
welcome back :)
I was thinking about making a small solid pyramid out of stone or cement with a copper cap made with sheets of thin copper but I was thinking about how to get a bit of a connection through the stone... iron oxide may be what I was after so thanks for that
Quote from: PYRAman on March 12, 2009, 09:13:38 AM
soon this year?? well whatever happens be it help from the Creators, or help from ourselves, something has got to change soon as the world can not go on for much longer like it is... I would love to live in a self sufficient world where technology helps the planet rather than destroying it, its slowly getting better in areas but also getting worse in others... we need to do so much more to help, people are still suffering even in our own country's and we call ourselves the "developed world"
Hello people of Earth,
I am a half-god Holden Magroin, an overlord from star system ZX1-494G. I came to this planet to warn you people about things that will occur in your near future. A man with a p-enis on his back will be born somewhere in India, he will become a leader of his nation and Indians will be the first nation to transform their three-dimensional bodies to etheric beings, become one with the Spirit. All of you will follow but beware of false prophets that will try to poison you by putting some special ingredients in Coca Cola. That special ingredient will destroy some special part of your DNA and you will be forever stuck in your weak bodies and you will die at the age of 64.
Save yourselves my children! Buy as much vegetable oil as you can because you will need it to power some special spaceships that will come to Earth on Dec 12th 2012 to rescue you. They will travel by solar power but unfortunately solar cells are too weak to power those ships for takeoff so they will need vegetable oil, lots of vegetable oil. Throw in some KFC buckets while you're there. Overlords tend to be hungry from time to time, especially on such long trips as this one from Nibiru to Earth.
Everyone will be allowed to take only one person with them because the space is limited (Gallopers are old ships, they just started producing "X-Force 2000" but they're not available yet) so if you have more than one family member, we will have to kill the others. I'm sorry but it's rules. So take you favorite one. Also, no pets allowed. This one time on the planet "Band Camp" a guy took his one-eyed Triptoclaus (something like a koala but with longer neck and only one eye) to the ship and it couldn't handle the warp speed so he puked all over the ship. We had to smell the acid for 3,5 light years. So no pets, sorry.
That's it good people of the Earth, please be well and wait for our arrival in peace. Care only about yourself and kill everybody that does harm to you but don't be selfish or violent.
P.S. I apologize for the bad picture, I was caught waking up. That explains the white sheet (we will kills all chinese because they copy everything and sell it for 50% the price and their products suck) and a Nazi helmet. Adios!
That`s a good one ;D :o ;D please explain further ;D we need some humor here
Quote from: half-god on March 15, 2009, 01:01:38 PM
Actually the way to tell an Alien from a normal person is they have a row of bumps down the middle of there heads.
And a large German like nose, this is why they managed to blend in with European culture so well.
And many still have one or more fingers or toes slightly webbed.
This is because they are descendants of toads.
Some still make a slight croaking sound when they speak.
They also have a tendency to torcher flies and other small bugs.
This is because they used to be a main part of there diets.
They tend to be very pessimistic about everything, always seeing the negative side of things.
They have a common tendency of hopping on peoples backs without being invited to do so as well.
And as soon as they see someone trying to get ahead they jump on them and seek to discourage them.
This is also a remnant of there toad characteristics.
They think they know everything and have no need of being taught new things.
Also just like all tadpoles look alike they tend to be copycats, always trying to look like the latest movie star.
They like to all talk the same way. act the same way, dress the same way, and move the same way.
This is also a remnant of there tadpole like characteristics.
The native people of this planet have a smooth skull.
And no webbing between there fingers or toes.
They like to joke and have fun.
They think life is to short to take things personal, and they are always curious of new things and like to learn.
They like to be there own character.
They look for convenience and usability when buying something, not the latest fad.
eg. "They don't want to buy something just because everybody else has one"
I hope this helps everyone sort out the real people from the Aliens among us.
Unfortunately the Aliens are reproducing much faster then the natives and are beginning to outnumber the natives.
Real people are becoming harder and harder to find.
Your mocking will not bring any good to the people of Earth. You don't seem to understand why we have made contact with you. You don't seem to understand the essence of the Universe and the essence of the Spirit.
I have talked to other overlords from ZX1-494G and they agree with me on the following subject. We decided to shed some light upon you Earthians, you will be given a piece of our technology and it's up to you to decide what you are going to use it for. You better not use it to fight wars because Gaylord Focker from Deep Sheep Tripili Dip galaxy will be pissed when he arrives on Earth on May 14th 2009. If you change your mentality by then, if you stop all wars and end hunger and poverty in the world you will prove that you really deserve the revelation and that's when all of half-gods will reveal themselves to people of Earth. But in case that doesn't happen, we will be forced to ride a Planet X on the I-95 wormhole highway (I-79 is under construction, Borg came, assimilated some highway workers, whole intergalactical incident...long story) and arrive somewhere between 9 - 10AM on Dec 12th 2012 and destroy the world. We will shift the poles and cause massive earthquakes, tsunamis and swam extinction and the vegetable oil will become alive and eat your kids up to the age of 5 and we will play the game "How many infants can you flush down the toilet?".
Here are the plans to the special free energy device I have been talking about. We have decoded the blueprints to prevent evil geniuses from abusing our technology so only the smartest of overunity.com board (I hear you should upgrade to vBulletin) will be able to build the device. Once you build it you will become stronger and live longer because some special parts of your DNA will be activated.
Ones you activate those special parts of your DNA you will become semi-half-gods and you will be able to recognize others like you, like the woman on this picture bellow and all the free energy will be in your hands.
P.S. Nebulassakis, Stiffmaister (maister is master in german) and Penizoid Kramer (bleep) would like to give a shout-out to PYRAman and I quote "long time no see man".
@ half-god
maister is not German for master, Meister is.
Piss poor performance from a half-god, or should I say half-wit?
Hans von Lieven
You just released a DNA curse on yourself.
"A man with a p-enis on his back will be born somewhere in India, he will become a leader of his nation"
Nevertheless, I don't expect this dicktator will have a very long reign.
It is well known the little head gets priority over the body's blood supply...so as soon as he has his first 'menage a trois', he's a dead man, as soon as the 2 little heads spring to action.
Regards...
I hope his arms are mounted back to front and he has eyes at the back of his head otherwise he might have a hard time pissing. ???
Hans von Lieven
Wood it be safe to say he's ambydicksterous ?
LOL Cap ;D ;D ;D ;D ;D
For the dubble dicker dude if he shows up.
Sardonic humor is my unconquerable 'tar baby'...and I'm here all week. :)
Regards...
jesus like is only CHUCK NORISS !!!
CHUCK CLONES ARE COMING it is the end every body get round kicked
