Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
PLUTOSBONE
@ Hoppy
The extra power comes from the Ethron flux field.
posative and negative flowing through a wire creates a magnetic field at 90 Degrease around that wire and in the center of the wire. The Ethron Flux field flows between the outer magnetic field and the inner field at 45 degrease straight through the electrical pulsing. Everything right hand twist.
MAYBEE :-X
sacred geometry knowledge of the ancients
giantkiller
Sure does pay to strip old tvs. Heatsinks galore. Stripping flybacks next.
--giantkiller. Things are too quiet around here. ???
zerotensor
Quote from: giantkiller on June 13, 2008, 11:38:48 PM
Yup.  There's been a bounty of old tvs in the trash lately here in the US, since everybody is getting new flatscreens.  I pulled a couple of old crt projection units out of the trash a couple of months ago (it was the semi-annual "trash amnesty" day when people can put anything out to the curb).  I passed-up literally hundreds of old tvs.
giantkiller
Way cool!
Replace the optical guns with inductors of primary, secondary, trinary windings with graduating mass or turns. Most here should see what that does.
Cleaning up after another bench fire.
My foremost ability is visual creativity. I get an idea and slam it on the bench. It works. Then add to it, then the next, then the next. It builds up real fast into a rat's nest. When I get a problem it is hard to locate. Sloppy work to boot. Then I clean up and backtrack. Not a problem though. I get results whether big or small. Can get dangerous at times.
After all the experiences and information gained here now things become a bit dicey. Anybody that has built has gotten hurt. And I don't mean just electrocution. That just means your in the club. So I take longer steps now. I can only create so much potential built up between my coils and the environment at 12v. The next level is to up the potential to make a greater impress on the aether. These are the only 2 levels I have taken notice of from Keely and Tesla. Crack stabilty of matter at any level for differing results. Schaumberger, Keely, Tesla and on up the chain of power to include Hutchison. Schamberger found controlled interference with water. Keely found controlled interference using frequencies against water, but at a higher inteference. Tesla could crack distances. Any! Hutchison can crack matter. Any! Nothing is impossible.
I post this again: Watch his hands and how he sets things down. http://www.flixxy.com/helicopter-cable-inspector.htm
He constantly balances the potential. Obviously the sweeping blades of the heli bring up a charge. The line poles are very high to avoid the field of any motorized vehicle below. ;)
--giantkiller. If you can't dream then you are living a nightmare.
giantkiller
