Thane Heins Perepiteia.
i_ron
Quote from: JustMe on June 14, 2008, 04:50:58 PM
Holy smack. Sometimes a cigar shaped UFO is just a cigar shaped UFO...
but what if it leaves a calling card?
LarryC
Quote from: aether22 on June 14, 2008, 06:21:36 PM
This smacks down the 'shorted coils reduce drag' theory.
Not really, it should be stated as the 'shorted HV coil above a critical rpm reduces drag' theory. Below that critical rpm a shorted HV coil has a slow down effect like a shorted HC coil.
L
aether22
Quote from: LarryC on June 14, 2008, 07:17:50 PM
L
I meant the 'any shorted coil reduces hysteresis and eddy current and other conventional losses' theory, not the 'hv coils are awesome' theory.
And he did stop the tests before the speed got especially low, something I didn't try to do since I had decided to count total revolutions so my tacho was in use.
CRANKYpants
QuoteIt's a good thing I'm not here, because if I was I'd ask you if maybe you are ready to reconsider your position that the acceleration comes from the generator and not the motor.
I AM READY TO CONSIDER THAT A ROTATING MAGNETIC FIELD PRODUCES A MAGNETIC VORTEX (LIKE WATER OR AIR ETC) AND THAT AN  EXTERNALLY APPLIED MAGNETIC FIELD (HV COIL) AT THE CORRECT MAGNITUDE / ANGLE / PHASE / PULSE FREQUENCY ??? CAN INCREASE THE SPEED OF THE VORTEX WHICH IN TURN INCREASES THE SPEED OF THE ROTOR.
ALSO IT IS IMPORTANT NOT TO IGNORE INFORMATION WHILE WISHING TO BE TAKEN SERIOUSLY -
FOR MY POSTS TO BE VALID THEY OUGHT TO BE VALIDATED BY SOMEONE ELSE - THAT IS WHY I POST THEM HERE.
IT IS SIMPLY NOT SCIENTIFIC NOR DICIPLINED TO IGNORE ANY INFORMATION WHEN HIGHLIGHTED AS I HAVE DONE
QuoteIf someone else could redo these tests it would be great - I may have got these numbers inverted?
I DON'T BELIEVE ANYTHING POSTED HERE (AND NOR SHOULD ANYONE ELSE) UNTIL I SEE IT FOR MYSELF AND OFTEN NOT EVEN THEN UNTIL I HAVE REPEATED IT 100 TIMES OR MORE.
SO I_RONARRYTHER22 - IF MY POST IS RELEVANT PLEASE REPEAT.
THANKS
T
PS HOW WAS INDY?
LarryC
Quote from: CRANKYpants on June 14, 2008, 07:56:30 PM
Sure, will test tommorrow afternoon. Saturday evening, Sunday morning not a good time. And my situation is such that I can not leave my test system setup handily outside as the environment here can cause plastic to rust.
L
