Paul-R
Quote from: greendoor on June 26, 2008, 01:49:16 AM
Can somebody please explain to me how anyone with even a brain for physics can think that the "flashlight" expermiment proves power output?
Yes. What is needed is an Avometer.
Paul.
bradpitt
Greendor,
I am not saying that the flashlight is a real example but all I was asking is what I have done ....is it doing extra work??
I am attaching a hand crank (like the hand drills) to a AC generator and seeing what I can get it out of it and then running that to a small motor that will run a flywheel that I am hoping to attach back into the crank...because the crank only needs a small amount of power to keep running too??
I'm curious why noone has tried the following simple setup already...
Maybe it's not the best setup for an electrical setup but the point is having a pulsing input and continuous ouput and measuring the differential.
hansvonlieven
G'day Broli and all,
This has been done many times. Brian Berrett and Ron Pugh have used similar arrangements. This is all documented. All have walked away from it since there is NO energy gain in the device!
Hans von Lieven
allcanadian
@greendoor
QuoteIt's just like a swinging pendulum.  Potential energy is converted into kinetic energy, and then converted back into potential energy - it does this a few times until friction has consumed it all.  Net result: 0.
We are fooled into thinking that this is overunity - but it is simply a series of energy conversions, each a little lossy.
A bunch of genius types at MIT once said they would need 1000X more computing power to solve the inertial moments of a simple fluid filled pendulum and even then they conceeded that the accuracy would be too low to matter. Now put a pendulum on a lever weighted AND loaded on the other end---- the inertial,velocity,time variables are near infinite and yet you presume to understand what the boys at MIT admitted could never be calculated. When I built this machine I understood no simulator would solve this and that it could take years to get all the variables correct to produce the desired effects so I moved on to easier projects. Can you imagine an engineer of 20 years having operated 10,000HP turbines in a 160MW power plant intimidated by a simple pendulum as you say.
Go back to school you have no idea what your talking about ;D
