xee
@ callanan,
Did you remove the resistor from the spark plug? It is hard to believe that the resistor would not get hot and heat up the plug. Great documentation. Thanks.
nightlife
sigmaX, page 42 of the following link gives us results from testing done. It shows ocean water having the highest BTU rating and lake/reservoir having the second highest.
It also shows the break down % of oxygen, nitrogen and hydrogen of each of the different waters tested.
bigblue
Luc,
        I was still searching on the firestorm plasma sparkplugs and come up with this link, at sounds like Robert Krupa has tried the plasma spark in the chamber with water. Here is his email----interesting choice in words   flamefromwater@yahoo.com  and here is a link from a gentleman that was working with Robert last fall,   http://www.worldwidescam.info/rattewater.htm        May the  GOD of Abraham bless this project........jeff
xbox hacker
Luc: i saw you new diagram. That is much more like S1r's. But i saw something that didnt look right to me, i made a change on your image, let me know if i am right  ;)
tishatang
@Callanan
You are really on top of this.  I commend you on your work.
From my point of view, there are two possibilities for the plug to be cold:
It is an implosion, not an explosion.
It is negative (cold) electricity.
It may be both.  The implosion leads to the negative electricity being generated.
In reading the PDF file you posted on the s1r, no one seems to have caught on that there is a power amplification here.  The "Effective Circuit" diagram shows the high voltage coil with 34,000 volts @ .38 amps = 12,920 VA.  But, going to the plug we have 24,000 volts @ 6.3 amps = 151,200 VA.  This gives us a gain factor of 11.7 times.  The magic of the spark gap has allowed the high voltage source to piggyback the amps of the low voltage source.  Is this the secret of the Gray engine?  His spark gap with clever circuits is allowing the same thing to happen?  Is the secret of cold electricity the combining of High voltage low amps with low voltage high amps by use of a spark gap?
After we get our cars running on water, we should be thinking of making pulse motors to drive the car like Gray did and do away with the ICE forever?
As long as I am dreaming, dream big!
To see if there really is a power factor gain, you could run some wires from your plug to a large neon sign transformer in reverse.  In other words, the high voltage will be the input and it will drop the voltage down to a usable level.  If you could run it at 50 or 60 cycles per second, we can test with motors or light bulbs and see what we get.  If you could put a capacitor inline as a series resonant circuit, it will help generate a good sine wave from the pulses.  A large cap at these voltages would be really dangerous and I don't know if you want to do this?   Maybe this will lead to a home power plant?
I Hope I am not grasping at straws and there is something here.
Good luck to all
Chris
