The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Grumpy
Quote from: BEP on August 01, 2008, 11:12:39 PM
Beer as horizontal sweep replacement? I suppose that depends on how much you drink. I stopped the liquid electronics repair some years ago so I can't help you there. Good Luck!
Entropy? Yes, I agree but one big problem.... In order to prove the concept you must produce at least two entropic frames of reference, one longer than the other, one for that 'point' and the load connection and another 'normal' for the source of current.
So which will you use as a test? A nuclear blast, lightning strike, EMP generator or produce a wave to push another wave beyond that 'sound barrier'?
Even though I no longer drink, a beer sounds like a better test.
That's about all the energy I have after a week of 12 hour shifts( no OU in these aging bones! )
No nuclear blast required.  Compress the tempic field and nature does the rest.  Running with gain is proof - the extra comes from "time" - so to speak - or more correctly from the different rate of entropy.  If the "big bang" ever occured - this was probably how.
Scored a replacement scope - will be back up in a week or so.   Fix the old-timer when time allows.  Sorry for the delay on the kicks.
Also got 200 feet spool of "garden wire" - with green plastic covering - and the sweet spot is in those 200 feet.
Have trimmer caps and inductors for delay as back up.
        -Frank Edwards
sparks
    Quick way to see a kick if you are using windowsxp.  Leave this window open and hit the control alt delete to bring up the end task window.  Go to cpu usage.  Now go back to this window and move the mouse up and down.
Monitor the little scrolling oscope looking deal.  Watch what happens when you move it real fast to the semiconductors trying to figure out the new intelligence of the cyper field input. ;D
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
pauldude000
@allcanadian
;D Good job!
That is the main part the point I was waiting to see if anyone noticed.
@Grumpy
What amount of amperage are we talking if that same coulomb transverses that same point in one microsecond?
;D ;D ;D
@forest
I will post the shots as soon as possible. Things are rather hectic right now. Don't worry though, I will get around to it soon. :)
@sparks
Concerning the energy storage.... I have considered the prospect, but do not think now it is necessary.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
poynt99
Quote from: poynt99 on August 01, 2008, 08:40:19 PM
@Bruce_TPU
thanks for confirming my thoughts on the spherics stuff.
i feel remiss in my invitations:
i'd like to invite you also to post a pic of your kick scope shots you've made.
thanks.
@Bruce--- are you there?
could you post your pic please?
Bruce_TPU
Quote from: poynt99 on August 03, 2008, 12:56:00 PM
No.
Actually I am building a Coil(s) and do not have the time to do anything else at this point.  Sorry, you will have to actually try this yourself.  Oh wait, I forgot, you don't build anything.   ;)  I have already had my confirmation of the kick, some time ago.
Cheers,
Bruce
