The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Michelinho
Re: Oscillating coil in cell.
I talked with my son-in-law and we may have an explanation for the oscillating coil. Since I was pulsing it, electrolysis was happening between the tight coil. HHO in (hydrogen or para-hydrogen was formed) the compressed space started dissociating and reassociating creating a pulse sustained by the magnetic field of the steel strap.
Could be the simple explanation.
Michel
giantkiller
Grumpy posted this in another thread. We have another winner.
http://www.panacea-bocaf.org/rotoverter.htm
page 7.
The shifting of atomic components electron spin to magnetic alignment being so as to transfer energy from
thermal ambient background energy by means of magnetic LATCHING or stochastic linear amplification.
As such making possible the collapse of it to attain energy from the thermal region of such core & summing
it to the energy released in the collapse of the field into another load being a capacitor or recovery means,
electronic, mechanic or thermal, whatever.
C charge in X resistance determines power in N time, leading to saturation of Z core and LC in any given
circuit, opto trigger, non-coupled. It?s the Hypersignal modulation that extracts power from "ZP" (stochastic
resonance applies). It?s a very different ballgame, which requires a total rethinking of normal electric
concepts, seeking to do the reverse of what standard engineering does in many applications.
This is answer of the process. Just analyse any of the devices you've seen.
--giantkiller.
giantkiller
Read this...
QuoteIt is well known that, to get the maximum power transfer from a source to a load, the source impedance must
equal the complex conjugate of the load impedance, or: Rs + jXs = RL - jXL. In addition, for efficient power
transfer, this condition is required to avoid the reflection of energy from the load back to the source. This is
particularly true for high-frequency environments like video lines and RF and microwave networks (RF
engineering practice).
Hector is correct in saying that this is a resonant effect in the three phase rotory system and will demonstrate
O/U effects when fine tuned so that XC = XL with very low overall resistance (R) so as to produce a very sharp
resonant curve with very high "Q" (Q determines the time decay; Hi Q = low time decay per oscillation). When
operating at ultra high "Q", the circuit is "lossless" and operates as a magnetic amplifier. Find "Electrical
Engineering" by Terman, PhD, Dean of Engineering, Stanford University, 1955. This is one of the only text
books that go into detail regarding the resonance phenomenon. It is well worth your library search for you will
become highly enlightened and informed. The most important factor to consider is the circuit resistance, for this
is how resonant curves are flattened or widened to establish "band width". Lump resistance inserted into a
resonant circuit will reduce the "Q" and cause the resonant curve to loose the sharp tuned peak under which is
the "lossless" region of the curve.
Every page has descriptions concerning this technology from every day experiences. And then some.
--giantkiller.
giantkiller
Tight resonance results in magnetic amplification from the medium, stochastic amplification and thermomagnetic
energy transfer, resulting in APPARENT overunity (in true sense is OVERUNITY due to transform).
Read that document!
--goatskinner.
sparks
    Grumpy has been shouting about the tempic energy field all along.  Tesla once said he doesn't know where the scource of energy is but it is all around us and man should be thankful for it's existence.  Direct conversion of heat to electricity can not be a bad thing.  Look at generating plants now.  They take the emwaves from the heat released by neuclear decay and heat water to create pressure to spin turbines to spin magnets by iron transformer cores to create a 60hertz wave that fights the natural em field of the Earth to heat up a piece of carbon that emits infrared em that excites argon gas to convert infra-red em into visible em wavelengths.  For man's sake enough of this shit. If the energy giants are so frigging powerful why don't they spend a few bucks on R&D and be heroes instead of assholes?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
