0 Members and 34 Guests are viewing this topic.
supersam
do the math guys!
i keep seeing 5's and 6's popping up everywhere!  there are also the musical variences of 8's and 13's: talk about placements of your control wires?
has anbody tested these placements of phi and pi?
look at these numbers and you should find in every case they are divisible to whole numbers, they are divisible to infinite numbers, and they are divisible to repeating numbers!
what does this mean, i havn't got a clue?  just thought it must be important since my mind came to it in a dream.
stranger things have happened to me before.
maybe putting the control wires at the 5 and 6 points on the circle and slightly offsetting them on the third with the 8 and 13 points will get the best effect because it seems to be where the "kicks" ARE occuring.
hmm ;D
Jason, if you get 70 volts at 35 mA already out, that is already about 2,45 Watts. Do your LEDs also suggest, that it is this much of power ? Can you already run a small inc. bulb with it ?
How much is then the input power? if you don?t connect the earth from your function generator, you probably still draw current capacitively from the function generator. Try to insolate him from the groundline and try again. At high frequencies you already have RF effects playing a role!
Jdo300
Hi Otto,
I saw the image of your circuit setup. I just wanted to verify a couple of details in the diagram.
1.From what I see, you have the collector of your transistor connected to the positive terminal of your DC voltage source, and the negative terminal of the voltage source is grounded? Or just disconnected?
2. The piece of wire pictured that goes from +12V to the transistor, is that a resister, a coil, or just a straight piece of wire?
Thanks!
God Bless,
Jason O
When Steven said, 3 output coils are important and he said it will spin like a jet engine, then I think we have a vortex here, as the 3 coils are ontop of each other and are probably 120 degrees out of phase, so the magnetic field will go up and down in them.
Now if the 3 control coils around them are also all 120 degres out of phase, we have a magnet field which rotates in a circle. Now if you superimpose that all, you will get a vortex field. Now the question is, for what reason is there the oter last coil, wrapped around all the other coils ?
Is it there to give the vortex the right direction or be any feedback coil ?
gn0stik
Here's another "blast from the past"
Earlier in this thread mannix posted a parable or "bed time story" for us to elucidate upon.
QuoteHi all,
Just a part of "the master of magnetics" That i thought I would share ...just for fun and entertainment purposes  a bed time story!
Wunce upon a time in a microsecond far away in a land under the noses of all, there were some electrons which were sent on a trip around the world by their king. Their destination was a place near their home but they were sent the longest way possible. Their king told them that it was  so that they could meet as many friends as possible on the way . They were told  that if they were lucky enough to meet some friends they could have a big party and celebrate with them and invite a few back for a visit. So their king gave them a big kick to send them on their way and arranged to meet them back where they started, he showed them the other end of the wire just behind them. "See you at the arranged time, back here" he said and off they went!
Some short time later the king sent some more groups of his favourite electrons on a similar journey,down another wire . He did this a few times . After a while he lost track of how many he had sent and was worried that they all might arrive back at his castle together and crash int each other. The king was worried about this  so he disconnected the return wires before any of them arrived home ..he wondered wether they might get lost but was more worried about them colliding with each other in his castle on their return home "Oh dear!.. What Have I done?" he said.
Meanwhile the electrons were still on their merry way twisting and turning ..round and round when they noticed that their end connection was somehow ,gone ...What had happened? they also saw some other electrons nearby that they recognised and so they met up and had a party. What big party it was. They all met and danced and sang and in the process many more electrons joined in the party, even ones that were not sent by the king. this created a few fights and some confusion but all the other electrons from all around heard about the party and sent messages to all their friends. Obviouisly the place was not big enough, but as it happened ,just nearby there was a wonderful piece of wire which seemed to have an even better way home and it was a bigger wire with much more room . They told their friends and  almost the whole party jumped over to the other piece of wire so that they might get home the short way. The uninvited guests were really getting out of hand at this point so It really was a case of either jump or be pushed so they jumped..the only trouble was that all the uninvited guests followed them and their friends and their friends as well, and they just kept on  comming .Nobody told any one that the party was over and not to come. . When all the kings electrons came rushing home thru the other big wire that was not for his travellers. the king was  relieved that they had taken the shortcut  ..but when he saw all he other uninvited guests he realised that disconnecting the main return wire was a bad mistake. He grabbed a few of them and put them to work ...he was able to send some of the  others back down the origional wire in the hope that they would find another king to annoy But there were too many of them so he quickly found another big wire that led somewhhere else and joined them together. he managed to get most othe uninvited guest to go down that one, away form his kingdom.. told them tell the others that the party was over but they were having such fun ,weaving and winding ..jumpung and pushing.  It did not take long for the king to have so many electrons passing by  that he had no way of dealing with them  so he would sometimes go down to the big wire and watch all the free loaders whizz by . He would tell some of them that the pary was over but they just kept whizzing by faster and faster.  He even sent some of them down the bing weavy wire to let the others know that the party was over, but it didn't work. He gave up after a while and  left them to it and went off somewhere else hoping that nobody would notice ..Im told that he went to a power generator where none of this sillynes could happen to him again an all the electrons had things to stop them from being so silly.
One day in a land under the noses of all the kings there were some electrons which were sent on a trip around the world by their king. Their destination was a place near their home but they were sent the longest way possible ,it was so that they could meet as many friends as possible on the way . They were told  that if they were lucky enough to meet some friends they could have a big party and celebrate with them and invite a few back for a visit. So their king gave them a big kick and arranged to meet them back where they started, he showed them the other end of the wire just behind them. See you at the arranged time back here he said and off they went!
Some short time later the king sent some more groups of his favourite electrons on a similar journey.down another wire . After a while he lost track of how many he had sent and was worried that they all might arrive back at his castle together  so he disconnected the return wire before any of them arrived home ..he wondered wether they might get lost but was more worried about them colliding with each other in his castle on their return home "Oh dear!.. What Have I done?" he said.
Meanwhile the electrons were on their merry way twisting and turning ..round and round when they noticed that their end connection was somehow ,gone ...What had happened? they also saw some other electrons nearby that they recognised and so they met up and had a party. What big party it was. They all met and danced and sang and in the process many more electrons joined in the party, even ones that were not sent by the king. this created a few fights and some confusion but all the other electrons from all around heard about the party and sent messages to all their friends. Obviouisly the place was not big enough, but as it happened ,just nearby there was a wonderful piece of wire which seemed to have an even better way home and it was a bigger wire with much for room . They told their friends and  almost the whole party jumped over to the other piece of wire so that they might get home.The uninvited guests were really getting out of hand at this point so It really was a case of either jump or be pushed so they jumped..the only trouble was that all the uninvited guests followed them and they just kept on  comming .Nobody told any one that the party was over and not to come. . When all the kings electrons came rushing home thru the other.new found wire that was not for his travellers. the king was  relieved ..but when he saw all he other uninvited guests he realised that disconnecting the return wire was a bad mistake. He grabbed a few of them and put them to work ...he was able to send some of the  others back down the origional wire in the hope that they would find another king to annoy But there were too many of them so he quickly found another big wire that led somewhhere else and joined them together managed to get most othe uninvited guest to go down that one, away form his kingdom.. told them tell the others that the party was over but they were having such fun ,weaving and winding ..jumpung and pushing.  It did not take long for the king to have so many electrons passing by  that he had no way of dealing with them  so he would sometimes go down to the big wire and watch all the free loaders whizz by . He would tell some of them that the pary was over but they just kept whizzing by faster and faster.  He even sent some of them down the ling weavy wire to let the others know that the party was over but it didn't work. He gave up after a while and  left them to it and went off somewhere else hoping that nobody would notice ..Im told that he went to a power generator where none of this sillynes could happen to him again an all the electrons had things to stop them from being so silly.
There you go.
