aussepom
Hi Guys
If you are interested I could try and fine that modified HT circuit using the 'Jacobs ladder' for your spark plug experiment, this has been done before using a plug that I have been trying to get the number of for quite a while, I do know that one plug is a NGK. If I can find the info I will post it that’s if you are interested.
How ever the OZ Injector will be using high energy 'plasma arc', but you can modify this plug to feed water mist though it and produce a very large blue flash as the water 'burns', the only problem with this it is not very stable using high voltage.
this one  is a Champion Industrial Spark Plug w/non-fouler from a auto-parts store.
Champion  Industrial plug  220  FI21501  $8.02 from the USA
aussepom
gotoluc
@everyone,
today was a sunny day in Ottawa, so I did my timing switch mod and tested the engine just to find more problems with my ignition switching causing too many spark misses, so I failed to get the engine started today.
I did do a video of the test even though it failed :-[  If anyone is interested in seeing the setup. It is uploaded on the new Energetic Forum video hosting service called EnergeticTube: http://www.energetictube.com/play/Energy__Unsorted/Half_GEET_Plasma_Engine_Test
Luc
ramset
LUC  Nice settup!!! can't wait for results
STEPHAN how come we don't have overunity tube ?
                   Chet
Thanks Grandma
UncleFester
Quote from: gotoluc on September 10, 2008, 10:35:43 AM
Thank you once again UncleFester for taking the time to explain what you and Bob know about these coils. I have some HV 1uf caps!... do you think a 1uf charged to 450vdc would still too much to drive the coil?
I haven't yet tried it with the diode setup and find it strange that it would just stop working ???
I did not get some SCR's yet since the local electronic store I use only had 2 models in stock and neither were the model of Groundloop's schematic. So I though I would wait till I see feedback from users as which SCR works best but no one has posted any info. Since you are doing very serious switching, may I ask you what you have found that works best for this application?  is it an SCR's or Power MOSFET? and what would be the part number?
Thank you UncleFester for your help and sharing the experiment you are doing at this time.
Luc
SCR's are the only devices I've been able to get to work reliably up to 1000 volts @ 25 amp. The one I fried was 1200V @ 300A I believe, but you can find NTE parts that are available and rated for 1200V @ 25A and cost about $12 a piece. I will go grab the part number from them. The one in GroundLoops circuit is way, way too small, those pop like popcorn even at 2 joules. The mosfet for the ignition driver that would run off a car electronic system would be similar to this one: http://ixdev.ixys.com/DataSheet/99477.pdf
That would be for the charging side to drive a step-up coil to charge a 50uF @ 800V cap. Then the charged cap could be discharged through an SCR and give us around 5 joules. I already have the charging side designed, and I have a processor controlled version already built except for the discharge portion of the circuit. It uses a PIC 12F683 (8 pin) processor, has two snubbers across the step-up coil and appears to work well so far. The discharge side would be fired once the processor see's the cap at full charge for bench testing, and the same input can be used for a crank trigger signal from a very simple coil sitting above the crank magnet.
Groundloop
UncleFester,
The TIC106 used in my circuit is good enough to make the initial spark on a spark plug.
It is rated 5 ampere (much higher when pulsed) and with the CDI capacitor at 2uF2 the drive is plenty to start the spark.
The main power to get plasma then comes from the capacitor before the diode chain. The proposed
diodes is LT10A07. Those diodes can take 10 ampere (much higher when pulsed). I have built and tested my circuit as
a CDI system. It works just fine. That said, there is no problem with using a bigger SCR and a bigger CDI capacitor.
I have started a research project converting a 1,5HP water pump. My main goal is first is to add a CDI circuit and plasma
enhancer to the motor. I will replace the water pump with a generator. Then I will add a water injector and try to run
the motor with brown gas (HHO) and water as cooling. Attached is my design so far.
Groundloop.
