Working SMOT ramp from Tom Ferko ?
Started by hartiberlin, July 12, 2006, 10:42:03 AM
magnetman12003
Hi,
Can anyone tell me if overunity is possible?
I am going to power a small electromagnet with 12 volts Dc and have it do only one thing- Thats pulse tip the See Saw balance setup I have described in my last posting.
Now the small very powerfull permanent magnet at the other end of this see saw setup will be synchro pulsed bounced at the precise time into the turntable  magnetic field.  That action will keep the turntable spinning rapidly.
My hope is that whatever output energy I can extract from the rotating turntable will be greater than the energy consumed by the small electromagnet pulsing/timing circuit.
Keep in mind that the electromagnet has a very weak field and its action in turn introduces "synchronized bouncing".  Directing a very powerfull bar magnet field off the huge magnetic field of a rotating 21 pound turntable.  That simulates hand pumping.
With all that said ---  Is overunity possible to acheive this way?   Open for discussion.
Remember it takes an chemical exposion blast to trigger an atomic blast that in turn triggers the blast from a hydrogen bomb.       Weak to strong.             Tom
Thaelin
Been watching where you are going here. A smot will travel out the end and then stop in the stickey point. Proven thing. OK, now if you had that track on the outside of the rotor with say three "vehicles" at staggered points with three seperate tracks. One of the vehicles will hit the end of the track while the others are on the way. Stands to reason that this will bump it over the end point and into the next track. Put multiple of these, and stagger them, should motor over nicely. This thing has merit but just has a problem to be overcome.
sugra
magnetman12003
Hi all,
I have been working at this for a long time now and I believe I have come up with something that actually works.  I am putting it together now.  You will need many magnets and time.
If you have a larger than 6 inch diameter ring magnet check out this simple experiment.  IT ONLY WORKS WITH LARGE RING MAGNETS.
Stack many disk magnets together and make a long rod out of them. The lenght of that rod is important as it should be the same size as the diameter of your ring magnet AFTER IT IS PLACED AT A 45 DEGREE ANGLE.  See below.
Take that long rod of stacked disk magnets in your right hand while your left hand is holding the large ring magnet up on its side on a table. (The ring magnet will not be laying flat).
Face the NORTH SIDE of the ring magnet towards you.
Now take the long stacked rod of disk magnets you made and hold it at a 45 DEGREE ANGLE with respect to the ring magnets lowest center point.  The ring magnets north pole and the rod magnets south pole should touch the table at the same bottom center point close to one another.
If you construct many of these stacked rods and angle them exactly as above you will find --after spacing them apart somewhat that the huge ring magnet will start rotating strongly in one direction.  The ring magnet will try to crab sideways also so it should be securely mounted as suggested below for maximum effect.
The 45 degree mounted rods all have the south poles on the ( bottom) lower end.  The huge ring magnets north pole side facing the stacked rod magnets will always pull towards any south pole and is pushed continuosly by the (top) south pole of the rod magnets. >>>>>>  <Take the lower half off these sideway vees and you have a 45 degree staggered track.   Form a circle with that staggered track and the large ring magnet and try it out.
You will have to construct a center point and arm that swings around it.  The ring magnet(s) will have to be securely mounted to the swinging arms ends.
A circle of 45 degree mounted magnet rods will be placed in a circular staggered track fashion around the outside of the swinging pivot arms.
Let me know if anyone trys it.  No Sticky spots at all !!    Thats what I am working on.    Tom
FreeEnergy
Quote from: magnetman12003 on October 30, 2006, 01:21:57 AM
Hi all,
please post pictures/drawings/videos if possible.
thevorlon
That sounds really unique. Please post more information if you can.
