gotoluc
@everyone,
I think we could do without an inverter and isolation transformer if we just use a MOT and pulse the primary with 12vdc to the frequency of choice to obtain voltage of choice from the secondary. We also would have isolation. Best however would be to use the AC (pre diodes) of the alternator to pulse the MOT primary so it would work in perfect sync. with engine revs demands.
Think about it and let me know you thoughts.
Luc
happyvalley808
Hi Luc,
Can you give us more info on your idea., how will you pulse the circuit?
Thanks,
HV
gotoluc
Quote from: happyvalley808 on October 21, 2008, 12:13:47 AM
Hi Luc,
Thanks,
HV
Hi HV,
we could pulse the MOT primary with a mosfet pulse circuit which could be sensing the coil pulses to synchronize to supply on demand but even better is to just use the AC from the alternator.
I think this is a reasonable idea and would eliminate the Inverter and Isolation Transformer.
Luc
Groundloop
Luc,
If you go back in the thread then you will see that my small power inverter is doing exactly that.
Pulsing a transformer to get the voltage we want. Also my newest circuit will do the same.
Attached is a power oscillator circuit that can be used to pulse any transformer.
Groundloop.
gotoluc
Quote from: Groundloop on October 21, 2008, 12:49:13 AM
Luc,
Groundloop.
Hi Groundloop,
yes I did think of you when I wrote it. You had and have a good solution. I would like to see if we could use a MOT's since we can get them for free and it helps to recycle stuff which is better for the environment then to buy new. I also love the idea of using the AC from the cars alternator to pulse on demand.
Thanks for Sharing your circuit
Luc
