giantkiller
Finer tuning on the LC trap circuit with a diode path after. This will catch the kicks and not let them escape. With the Dc gone the device should run cooler than above the DC potential? ;)
giantkiller
I hate to be the party pooper, but...
All of his devices were started inside near 50/60hz sources. A veritable flood of energy. Maybe this is good after all, the automobile starter is just used at the beginning of the trip. 8)
starcruiser
Quote from: ctglabs on October 05, 2006, 02:25:44 PM
Marco makes a good point.  A resonant circuit for 7.8Hz is going to require a very very large coil of many henrys and large capacitor.  More than is present in the SM device.
Logically though it is likely the 7.8Hz is the product of something, ie rather than he purposely generates 7.8Hz.  It is the result of some interaction with this natural waves.  7.8Hz is too precise a figure otherwise and I guess we are coming back to Tesla MT!
But it is possible to wire a telsa coil in reverse and extra energy from the air in this mannor as our friend posted earlier - http://www.keelynet.com/energy/device.htm
Waiting for Taos post!
Dave.
Dave,
Remember the sum/difference of signal mixing
try a 5khz mxed with a difference signal of 5.007.8khz. Those signals are far more achivable than the 7.8 directly.
Carl
Carl
gn0stik
Perhaps the coils are detuned 7.8hz so the overall rotation of the magnetic field is that. The primary frequencies have to be much higher than that. Remember there are octaves of the 7.8hz schumann into the KHz range.
giantkiller
Would this be enough milliheneries?
The white centers are PVC. Coils are air core. The coil spools just slide on and are connected together.
The gold centers are the  3 inner coils. I will use 1/2 copper pipe. This gives me twice the electron flow surface area.
The bronze cans are prewound coils interconnected center wire to outer wire. These constitute the inner containment windings for field compression.
The Green cans are prewound coils interconnected center wire to outer wire. This could be 12 gauge romex.These constitute the outter containment windings for field compression. These coils are wired in series per layer and in parallel by layer or the other way.
I connect all corresponding corners together and power this just like the SM devices. The idea here is I will not have to wind any coils. This give me an expediant production model. I can make this any size.
Totally atomic, dudes!
@Marco: I can wire this like yours.
Any comments?
