Knitel's InfinityPump
Started by wizkycho, February 16, 2009, 07:55:05 AM
Steven Dufresne
Quote from: hartiberlin on February 17, 2009, 09:46:13 AM
Hmm, what about valve V2 ?
Will the water really run out, when it is opened or does the external air pressure prevent this ?
V1 is open when V2 is open. There is the same external air pressure pressing down on the water in the bottom tank so air pressure is balanced. If I recall correctly, air pressure is the same at all points on a fluid, so the fact that the bottom tank has a large surface area doesn't multiply the air pressure.
-Steve
http://rimstar.org   http://wsminfo.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
Okay, I edited the GIF animation and made the animation slower
and included Igor´s name with it.
Here it is:
Quote from: Steven Dufresne on February 17, 2009, 12:36:50 PM
-Steve
Okay, you are right Steve,
I can not find any error , why this should not work !
I think this is the most brilliant and easy idea I have ever seen with
a gravity type water using converter.
I made this topic now sticky and added it under the news section.
As I am involved in some other projects right now, I hope somebody
could test it as soon as possible at least in a basic way and let us
know, how it works with real hardware.
Many thanks in advance and many thanks to Igor having it released
freely !
Regards, Stefan.
brian334
Why not put a water wheel under valve 2 so the thing will do work?
This device is functionally identical to the Sinclair Siphon.
http://www.lhup.edu/~dsimanek/museum/unwork.htm#sinclair
The 100kg weight is just a red herring. If the device was going to work, it would work without the weight. But it won't.
Don't believe me? It's a simple device. Build one, and show it working. PROVE ME WRONG.
(One problem lies with getting the weight to be buoyant and to rise up after it hits bottom.)
