Knitel's InfinityPump
Started by wizkycho, February 16, 2009, 07:55:05 AM
sushimoto
Quote from: wizkycho on February 19, 2009, 09:31:20 AM
<SNIP>
So it is called Knitel's InfinityPump...because 60%-70% and closing the loop is done by that fabulous, wonderfull, brilliant, careing, goodlooking, civilized, magicall, explorer, brain stormer, extraordinary mind, protector of weak, justfull, leader, strong carrisma,with prodigy, dexterity, agility,...what to say then perfect...
the very same Knitel Igor
Wiz
Come on Wiz,
As I mentioned before; I love this.... learning curve.
And you for always bringing in such brain-jogging.
;D
Thought about Capilar tubes?
A Tree does not need any pump to lift its water
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
brian334
any idea on how to make this negative preassure for suction smaller...elastic fluid, differently shaped entrance from input pipe
by introducing helium or vacuum to make it able to float with smaller volume...
I suggest this - put rocket engines on the bottom of the 100 kg weigh so it will go back up.
wizkycho
Quote from: brian334 on February 19, 2009, 05:05:29 PM
My allmost public embarresment seems to amuze You.
no meaningfull ideas whatsoever... so i must make You sad again
principle of work changing media Air/Fluid(water) and making therefore heavier/lighter floater works and unlike You guys Knitel's infinity pump
has only one and very noneconvincing flaw. are You convinced in this flaw ? and that is unworkable ?
This is strong workable principle to further build on. but I see you stopped on some minor tecnicality.
Wiz
brian334
If you can’ t take the heat, stay out of the kitchen.
hansvonlieven
G'day all,
This is the first in a series that shows why devices such as the Knitel device cannot work. The first segment explains the hydrostatic paradox, which is fundamental to the understanding of any hydrostatic and hydraulic system.
Since I can no longer embed my graphics here I was forced to use Microsoft word for the paper as the graphics need to be in their correct places. I apologise for this. I will later put the whole paper on my website in HTML form since it appears to be a popular subject.
I hope you guys appreciate this, this is a lot of work.  ;D
Hans von Lieven
