Anti-gravity Motor! (Everyone please read, very important)
Started by gravityblock, February 21, 2009, 12:42:26 PM
gravityblock
Quote from: cameron sydenham on February 21, 2009, 09:18:49 PM
We simply want to develop the technology we believe we have stumbled into, prove it, (proof of concept) than allow any and all manufacturers, builders, whomever to make the products.
The above is what I'm talking about not being able to patent an idea. You haven't been able to prove it yet. You are here for us to prove it for you so then you can claim patent infringement after this technology has been distributed. You're previous post said you have built 3 of these motors. Is that not proof of concept? What are you waiting for?
You don't have all the information for this device yet or don't have all the funding to bring it to proof of concept or to the market. As far as I'm concerned your patents are invalid and will always remain invalid, unless you can get this to market before anyone else. I mean you no disrespect. I understand what you're doing. As far as your investors are concerned, let them invest in the companies that will be building these open-sourced motors. There are more than one way to make money where all can benefit and not just a select few.
I'm not upset with you. You and your investors are truly in a pickle. There are advantages and disadvantages to both patenting or to open-sourcing. This has been discussed many times. There is no need in repeating this discussion.
I just hope we're all on the same side regardless of the decision you and your investors decide to make. I believe you have good intentions. The bottom line is I don't really care who brings this to the market. I don't care if it is patented or open-sourced. All I care about is it being released to the public.
May you be blessed.
gravityblock
Quote from: X00013 on February 21, 2009, 09:49:21 PM
String theory and parabolic motion around the gate, I understand , our planets circle the sun, why dont they lock up at the magnetic gate?  How do they get past it and keep going? Thats what i wanna know.
There is no magnetic gate. The reason for the sticky point is because the object is in a fixed position that opposes the magnetic forces. When the object is not in a fixed position then it gets pulled into the magnet or pushed outside the force of the magnet.
The sun causes the planets to divide into two different forces. One force wants to go straight and the other force wants to go towards the sun. The force that wants to go straight pulls on the force that wants to go towards the sun. This causes it to lose forward momentum and causes it to have an axial spin momentum until the forces are equalized. After the forces are equalized then the planets will have a forward momentum and an axial spin momentum. Both momentums will add up to the momentum the planet had prior to the influence of the sun. These two opposition forces cause the planets to stay in orbit around the sun and to tilt on it's axis.
gravityblock
A simplified view of gravity is nothing more than 2 momentum forces pulling or in opposition to each other. When you throw a ball into the air going 70 mph, the earth's momentum (speed) is faster than the ball and catches up to the ball. After the ball has lost it's momentum (relative to the earth) due to the earth catching up to it, then it starts to fall towards the earth. Now the ball is no longer in opposition with the earth and the 2 objects will accelerate towards each other (relatively speaking). Einstein even said, "if acceleration feels like gravity, then they may be the same" (I didn't look the exact quote up). We have been bamboozled and hoodwinked for long enough.
Edit:  @cameron - Keep up the good work.
gravityblock
I believe we need a device that is similar to the gyroscope that puts the orbital spin into its axial spin. The gyroscope in the wikipedia link below should have a 2 spin axis perpendicular to each other instead of 1 in order for us to get the right results. The question is, how can this have a 2 spin axis that are perpindiclar to each other?
http://en.wikipedia.org/wiki/Gyroscope
infringer
You have it the chase is on ...
If you defy gravity you achieve overunity ...
Technically it may take a massive amount of energy to defy gravity in which case OU would be possible but in order to create the conditions for OU it will cost energy...
It is not an easy task this overunity ...
Magnetic Flux seems to play a role in gravity and spin seems to play a role.
Simple observation :
Put something on a round surface eg. a ball and spin it ... What happens the object is flung off...
Now if you take a full glass of water and you make a long spin you will notice you can spin it upside down without the water falling out...
Now take that same glass of water and try to spin it without closing your hand you will have to spin it that much faster because not only do you have to keep the water in your cup but you need enough force to keep your cup stuck to your hand...
Its almost as all the rest of the planets act as hands easing the burden of keeping the people in the container we call earth.
Without the earths atmosphere I assume that we would all be flung off the face of  the earth but then again you look at the moon walks... And there is a degree of gravity there as well...
I don't believe that anyone understands gravity they just know it is there but the full working of gravity is without understanding otherwise we would be manipulating it without problem.
The rest is just assumption!
EDIT:
Anyone know what would happen if you took a ball and encased it in clear plastic then pressurized the air inside of the plastic and placed an object on its surface and spun it if the object would fly off just as quickly?
I dunno this is a very profound topic I commend someone for being ballsy enough to start this thing up.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
