Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
jas_bir77
@ nrg in your video you share a circuit (attached ) which you say can be used to extract cold electricity & can be used to charge the battery.
i have 3 questions
1.what component are you using in  circle marked red is it a reed switch,hall switch or an op-to?
2. can you draw the wires clearly, which wire is going where.?
3. gauge or size of the wire you had winded.?
i know you are very busy, but if you don't share the information it becomes difficult for normal lay man to replicate the experiments.
thanks in advance.
yoyo
Quote from: NRGFromTheVacuum on March 07, 2009, 02:36:33 PM
My statements in the video where misleading, that was my mistake for which I apologize.
from dictionary.com
Misleading:
Definition - deceptive; tending to mislead
Synoyms - deceitful, deceptive, false, fradulent
Antonyms - honest, truthful
u show a process and videos that show how to produce more energy out than in
now u say its not true its deceitful videos
u should be honest and change the videos to clearly state that
maybe u should get your buddies at nasa to help u build a $10 switching circuit giggle snort
NRGFromTheVacuum
Quote from: yoyo on March 07, 2009, 03:30:00 PM
from dictionary.com
Misleading:
From dictionary.com - Energy: the capacity to do work
Until the energy stored in the secondary capacitor actually does preform work. Then nobody here has any idea how much work it can preform.
So when I state that the secondary capacitor has MORE energy then the energy used to generate (which should say gather) that electricity.
It should be interpreted as: "The secondary capacitor has a larger capacity to do work then the energy used from the source capacitor that gathered that capacity to do work."
I am human, so I'm entitled to make some grammar mistakes time to time..  ;)
PaulLowrance
All of this talk still doesn't answer any of the important questions. I'm guessing you don't have access to the capacitor meter for your experiments. That's fine, and in fact for this case it's better to do the capacitance measurement with a simple RC time constant test. The RC time constant test does not require the cap to be first discharged before taking the test. In fact, you could use whatever charge happens to be on the cap to do the RC test.
If you could please do a quick RC test on both caps immediately before and after your experiment then that would help a lot.
If it's still a thumbs up, then all I can say is to build another bifilar coil and see if it works. If it were me, I would use other caps on the original bifilar coil before building another just to make sure it's not something special with the cap.
PL
NRGFromTheVacuum
Quote from: jas_bir77 on March 07, 2009, 03:16:39 PM
i have 3 questions
thanks in advance.
YouTube really makes that picture look bad, here is a better one.
