Tesla Cube
Started by time_travel01, April 25, 2009, 10:13:38 PM
wattsup
@time_travel01
Guys are right.
You can't say more out just because your meter spikes.
We've all been there and done that. lol
Putting the output into a dioded capacitor that is also connected to a load will tell you the true story. You can then put your meter on the capacitor and put an ammeter on the load.
Try this. Put your meter on one of your batteries and then spark the battery terminals. What do you see.
Your 200watts input is considerable to start with and one would expect that kind of sparking.
Very good idea to wear gloves. lol
amigo
@time_travel01,
It looks interesting but what's stopping you from making a simple brush set for your motor rather than using DMM electrodes to connect with?
Stranded copper wire pressed against the rotor at the top will do, and you could mount it on your stator with hot glue. It is easiest to do without making major modifications, and good for short runs.
Though I would somehow secure that top part of the rotor so it does not wobble as much but stays on the axis.
time_travel01
 ive made a few of these babys before.. sum alot more stable and small..Ive used many diffrent MM's.... this is just a place im going to post updates. show how shes working( this new one im building 30 kw :-D.. i just saw the upper head lines of tommy reeds pluse motor.. hes got the same thing i do... more or less. alittle more bloatware thats not needed on his but he really does have sum nice toys....  ill keep ya posted
time_travel01
 ive used brush's and slip rings b4 and probly will again...  that connection rod is only temp. :-)
time_travel01
 ive used brush's and slip rings b4 and probly will again...  that connection rod is only temp. :-) im going to build small but poweriful tesla coil to give me a wireless connection from the moving stator to my bridge.
