Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
Dingus Mungus
Here, this might help your calculations:
-Voltage represents e-field generated along a conductor. (like magnetism but NOT!)
Think of voltage as the hill, the higher the voltage the taller the hill.
-Amperage represents the ammount of electrons passing a point on a conductor per second.
Think of amperage as stones to roll down your voltage hill. The more stones you roll per second the
more work you can do. The work is done with the momentum added by rolling down the voltage hill.
Interesting fact: amps are actually coulumbs, and a coulumb is
6,250,000,000,000,000,000 electrons per second.
-Wattage is volts*amp thats it... (W=A*V)
I really do hope this was helpful and not patronizing...
Sorry in advance if it was.
~Dingus
Bill, let me put it into easy words:
In this current state of mode you might have overunity, but you can not do much useful work with it.
You can only let it run for months but you can not connect an additional load, otherwise your battery will run down.
So better first try to upscale the power output from the pendulum, so you can at least drive a 10 Watts load constantly with it.
Regards, Stefan.
Grumpy
Bill,
A method of using a pulsed force and a pendulum to generate electricity was posted on several sites a few months ago by Lawrence Tseung of China.  He explained the phenomenon in detail and provided the theory and math to support it.
In short, you can create OU from a pendulum, a magnet, a couple of coils, and a bat or cap.
See attached:
        -Frank Edwards
billmehess
The goal in the first phase of this project is to simply show that it would be possible to "rewind" the device
and keep it going continously from its own power.Also I am not using the weight. The clock wind up has a sproket connected past an idler directly to the motor.  Of course the next step is to construct a larger unit that will by bypass the capacitor storeage concept all together and charge the battery direct. Even with the small permanent magnets I am using I am getting a
nice 400-600 ma pulse on each swing.
A larger unit  producing 15-16 volts at a decent amperage and then run thru a diode to get a forward plus voltage would keep a bank of batteries full charged. Connect these batteries thru a inverter and you have a
completely closed whole house system.
I have sufficient resources to build this system and I am going to do so.
In my building of the unit I have solved numerous problems in its design, there are so many little things that have to be working just right to get the desired results.
                                                 The journey continues
billmehess
I will be out of town and back on Monday. Have enjoyed the bantering back and forth with your emials. Will answer any new ones posted on Monday.
