ronotte
Hi IdentFlyObj, in fact I thought to use Litz wire (64 wire) for the Antenna in order to increase voltage...again I don't know the magnetic antenna Q I will obtain...the goal is just to break the 0,3 voltage limit or use a microwave diode. Any suggestion is welcome.
c0mster
With regards to a possible mixing of frequency.
Beat frequency experiment:
http://cmnet.ca/projects/sm/beat1.wmv
C0mster
Grumpy
Did SM ever actually state that the TPU had a "rotating magnetic field"?
For all we know the four coils are chokes, spaced a quarter wave apart, to dampen the kicks.
        -Frank Edwards
otto
Hello all,
for a long time I was thinking about 22 turns I read somewhere. Mr. Mannix said a long time ago the collectors have 22 turns.
Then in a post he said in the cutted TPU we can see 3 hollows.
This hollows had no sence to me but I was thinking about it until I understand.
This 3 hollows are from 3 collectors!!
Then I remembered J:L:Naudin and the
          RODIN COIL
so I builded one.
The rotational magnetic field in this coil is much stronger then in an Oridinary coil!!!
At low frequencies the Rodin coil vibrates. It is a very strong vibration!!
I will in the next days build a TPU with Rodincoils as collector coils just to see what will happen.
If you are interested in Rodin coils just google it.
Otto
Grumpy
Looking over previous posts, here is a summary of features:
1. 3 seperate coils of stout stranded wire - three is important - why?
2. The control wiring is vertically wound in several segments around each of the horizontal collector coils (as in individually). Other control wires are wound around all of the horizontal collector coils together.
3. If you know how to find the circuit potential, you tune into the frequency and if you have enough short pieces of wire, you can convert as much power as you want in a given space.
4. - You create several frequencies within a space of the collector coil's circumference.  The frequencies are directly related to the circumference of the collector coil.
5. Many wires are perpindicular to the main collector.  This is NECESSARY.
6. The source for the signal becomes the feed, so no amplification of power is needed.
At one moment it sounds like an antenna with loading coils - next moment it sounds like you just create pulses and collect the radiant energy.
        -Frank Edwards
