the_big_m_in_ok
dllabarre said:
...But what was interesting was when I added water to the ground around the steel neg rod the volts went down like others have reported but when I added water to the ground near the pos copper rod the voltage went up.   ???  Very interesting. ...
That's the first time I'd been told that.  Your system is similar to one I built years ago with steel and aluminum.  Steel was positive and aluminum was negative.  The plans I followed suggested I water both materials I was using, but at that time I just relied on rainwater like you.
--Lee
jeanna
Hi Stprue!
:D
Quote from: stprue on August 09, 2009, 06:46:40 PM
Great videos Jeanna.  How is your StubGen made?
Thanks,
The little one is made on a 3 inch bolt about 1/2 or 5/8" thick.
The other one in the video was made on an iron plumbing pipe which is hollow, of course and is ~ 1 inch pipe.
The little one is #3 and the big is #11, so while they are wound the same way, they were covered as they were wound differently. Also the little one has 19 gauge iron and 18 gauge copper wires. This was the closest I could get to a match. It is thick and works very well.
The big one is made with thinner wire 24 gauge maybe and they match... but the iron is zinc plated or steel. I might have written it down somewhere.  ;)
As far a winding them goes, I wound them as close as I could to the patent.
There is a lot of info on the 2 earth battery threads. I think from Feb to march 2008 is when we started to make them and I was still posting on localjoe's thread. I think most of it is there. I think by the time Bill started the bifilar speculations thread -this one- I was just collecting data and had finished building them.
Basically,
6 rows 60 turns each row 30 per wire on each row. Start and end at the top.
jeanna
jeanna
Hi everybody,
I am not sure where to post this pic. I made a drawing in schematic form to show the relationship of joule thief to NS generator in the posts relating to the movies about the NS generator.
It is relevant everywhere, but I am not able to decide where is best. So, here in speculations is where I am putting it!
This specifically shows the relationship between the joule thief and the NS Generator.
The scope is attached to the secondary of the NS Generator and not to the primary coils at all..
So, it is showing what the NSgen is able to pick up .
It picks up more from the joule thief than it does from the ground, or is it radiations in the air?
jeanna
Pirate88179
Jeanna:
Great post.  Feel free to post this also over on the JT topic.  There are more folks there and you will get more feedback on this circuit.  I see no problem with posting this in both topics.
Thanks.
Bill
the_big_m_in_ok
Quote from: jeanna said:
quote]
It occurs to me from my past research that you could add coils or mesh-type structures to the JT output wires in order to radiate more power to the NS generator.
I suppose there's a point of diminishing returns somewhere, though?
--Lee
