IotaYodi
It has been discovered that the frequency of the lowest electromagnetic waves is on the order of the 10-3 Hz (millihertz or mHz) and are known as micropulsations.
What I know I know!
Its what I don't know that's a problem!
dllabarre
Quote from: IotaYodi on August 22, 2009, 08:36:31 PM
Very interesting because I've seen as low as 400mHz.
So I could actually see much lower with the proper equipment.  :)
DonL
t3t4
Wow, sorry guys/gals, but I have not been notified of all these new posts. I wish I had been, all I did today is sit around. I could have been more productive had I known.
I am not prepared to answer all of the questions asked, but I'll do my best to answer some or at least reply to some.
I'm not sure where exactly this fits in to any one answer, but here we go. The ground rod is one of the most important items. "Going Deeper" is part of the solution. If you think about the core of this planet in terms of molten lava, then what elements comprise the lava? It's mostly iron as science has determined. Science also says the lava if flowing in somewhat of a circular form. So, spinning metal moving fast creates a magnetic field. (I took that from a movie--The Core) The point is, it's true. albeit for reasons I do not fully understand.
What I do understand is this, the higher you go from ground, the more potential energy you can find. I see it like this:
The core of the earth spins, but so does the earth itself. When you take into account the seemingly endless amount of magnetic potential via stars and other bodies in outer space, you can see spinning magnets all over the place, providing they do similarly as the earth itself . Well, this spinning magnet is how our current generators work today. It's a rotating magnetic field. And inductors just love to suck up this energy. So, getting deeper to the core of the earth and reaching higher to the stars will net you the best results since you are closer to the magnetic field at it's point of origin. It's not lay lines, it's not surface conditions, but rather the source of power that we might want to consider in greater discussion or depth. So that is my theory of Tesla's Wardenclif tower.
This tower was basically two coils and a capacitor, all tuned to resonate with something. It's this something that has been driving me half nuts for years now.
@jeanna:
I do use coils, I do use caps, but honestly speaking, my math is so bad that I cannot tune to frequency. I can only tune by experimentation. But to duplicate my results, well, that's easy! You, RadioShack, a hardware store and I can make that happen..  Buy the 3 pack of enamel wire they sell at RadioShack, then take the shinny copper spool of 20awg and string it up horizontally. You can run this across anything really, you can even use the rain gutters on your home instead of wire. Although the wire does seem to give better results, I don't know why.
The point is, you need some conductive material that can attract or otherwise server as an electron collector that will not allow the electrons to escape once collected. Then all you have to do is give these electrons a place to go once they have been collected. It's the where to go, that's the interesting part. The electrons can go to a coil, a capacitor, or both. Either way, they will go nowhere unless tied to ground.
Here is a basic view in PDF form which describes what I'm talking about.
http://www.geeman-headquarters.com/TeslaRadiantEnergySystem.pdf
This is another good read for those that like to read:
http://peswiki.com/index.php/OS:Radiant_Energy_Antenna_System
Here is a simple test to prove theory:
http://www.pbs.org/tesla/tt/generate_electricity.html
The schematics of the circuit I use are simple, but I have to draw it out which I have yet to do. Sorry, but had I been notified earlier, I would have been somewhat prepared for this reply.
Anyway, long story short, I'm focused on the real earth battery, not the earth so much as the earths interactions between other bodies in space. There is real magic here, but also scientifically explainable. And please, I mean no offense to all the hard work done by all of you. All I'm saying is, the true power is vertical, not horizontal.
Someone, and forgive me for not naming names, but I can't do all this at once, there are too many questions that I'm backed up on. Anyway, someone gave a link to a video on youtube that showed a guy receiving 80+ volts. Now as we all know, voltage is nothing without amperage. If you want 2000+ volts, then dry the air and rub your socks across the carpet. Then touch something grounded and you will receive a round about 2000+ volt shock. But is this real power?
NO!
It is tremendous voltage, but no current, so you don't die in the process. But it is fun to tease the wife with it. So at least you get an amusement factor out of this energy.
I have the same issue with my areal as the guy in the video. Yes I can store energy, but I can't do any real work just using capacitors. However, if I dump this energy into a battery, a man made battery that is, then I can do real work. Just my opinion here, so please take it for what it's worth: I believe you guys should use that joule thief coupled to a regulator of sorts to charge today's batteries. Then run that current through a power converter and then run anything you like as long as the converter is large enough to handle the load. This is perhaps the most inefficient use of the power, but it is also practical. Since you pay nothing for it, this power is available to do with as you see fit. Use it any way you like.
I do things this exact way, only because I have not built a Tesla coil, nor have I tuned any of my coils to the proper frequency as of yet. I got close once and burned things up. This is how I know the real power is available, not just some stupid electrostatic shock....
Anyway, that's enough for now, the questions asked in earlier posts will be answered to the best of my ability. But I have to take this one step at a time and one person at a time.
Please be patient. But also keep the question coming. Your questions cause me to think, my answers cause you to think in opposite or in like kind. But together we progress!
Thank you,
t3t4
t3t4
Here is my basic circuit. You can start with this and do amazing things if you wish. The value of the caps are not important for anything other than tuning. Just use two of the same value and you'll be fine. Super caps may be beneficial, I have not tried them as of yet.
Download pic here: http://rapidshare.com/files/270421698/Radiant_space_energy.zip.html
Sorry, but I don't know how to get this simple image into this post. At least all my attempts have not shown up in preview, so I assume the image is not present, hens the link.
Thank you,
t3t4
t3t4
Well, I guess it did show up in the post. Why could I not see this in preview?
t3t4
