New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
spoondini
you are right, all the sciences are same if some thing happening in physical world say we through a ball on the wall it will back fall.
this is also happening in molecular /atomic world but we can't see it ,mankind blessed with wisdom and vision developed sensor to see those activities
like wise siphon is possible , like my device
mechanical advantage (chain pulley system) like i created extended back time UPS using hysteresis curve as an advantage and switch the system only at right times
Tesla is my mentor a genuine thinker
we need to think out off box , if you can explain electricity mechanically you can treat it like that , just think
one thing more i have developed many more things, coz you are a genuine thinker i can give you a a clue i have developed a machine that works with 2 dimensional forces X and Y and your result is Z
the Y force is gravity going towards earth
the X force is earth magnetic force around the earth
use it together and you will be able to wonders
i am not saying i am perfect but trying to do things, if any forum member is looking to develop something i can do that for him as a project
Ali
robbie47
Quote from: winsonali on September 11, 2009, 10:25:43 AM
Ali
@Ali,
I don't want to be rude, but aren't we trying to participate in your Genie project already?
It seems that you keep the doors shut on that one.
You are perfectly entitled to do that, but why are you now challenging forum member to do projects with you?
Hi Ali,
can you please let us know, how many capacitors you are using
in your switching circuit ?
Are you only using these visible 3 big caps or do you also have smaller
caps that you use to switch back and forth for the principle to work ?
Are there really no coils at all also no chokes inside your circuit ?
Many thanks.
Regards, Stefan.
spoondini
Ali,
  Going to take a logical leap from your clue:
Since gravity (X) is moving in one direction, and the earth's magnetic field is moving in another direction (Y), the sum X+Y is Z.
If I use a purely mechanical analogy, a ball thrown in a vaccum is moving horizontally at 5 m/s (electrical energy) and accelerating towards the ground at 9.8 m/s^2 (gravity).  Utilizing only the electical potential energy  (horizontal movement) would limit us to collecting the energy of decelerating the ball by 5 m/s * mass of the ball.  The real total potential energy of the moving ball is both the horizontal deceleration potential, and the ball's height from earth * 9.8.
Are you implying that in typical circuits, we only collect the kinetic energy of moving electrons (horizontal movement) without collecting the potential energy of the electrons gravitational pull towards the earth?
If that's the case, it can't be very much energy we're missing out on.  I can't recite the math accurately, but in high school physics we did some calculations showing the relative weightings of electrostatic vs gravitational forces inside an atom, and with various electrostatic reactions.  Gravity was always a negligible force in comparison with electrostatic forces.  That's why it's often referred to as the weakest of the three forces, and not really taken into account.
Even if you harnessed the entire gravitational potential of the electrons passing through your genie - I would not expect to get measurable OU as you have demonstrated.
Can you please elaborate?
Hi All,
just had a Skype call with Ali and the Genie circuit is really
much more complicated than I thought.
He is using a DSP for the processing and makes several
computations between taking samples from the input dimmer output.
So it is all pretty complicated and he will soon make a new
video and explain more and I will let him explain it.
I also had a bad WLAN connection, cause I am not at home right now and only
understood each 2nd word only.
So I hope Ali will soon share more knowledge of his device.
He also has 2 more interesting devices and I will let give him
the honour to introduce them.
Many thanks again to Ali and I am looking forward to see his
groundbraking devices.
Regards, Stefan.
