user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
Groundloop
otto
Hello,
@ Alex,
you have my promise I will tomorrow have all my papers with me and then I can post details.
I have this all posted earlier here and I think all you need is to surch a little. I posted pictures how I connected the cotrol coils, the diameter of my control coils...
Otto
otto
@Alex,
found it at Master of magnetics... site 107 there are my posts about the control coils and diameters of wire...
Otto
aether22
Try an analog volt meter then, see what you get.
And while you aren't getting as good results I do suggest you run the following:
A collector coil in the top one should be connected by both ends to a (if the rest are in use even a new one) control coil in the middle one, with a collector coil in the middle one should be connected to a control coil around the top one, this should provide feedback.
Then in the bottom one a collector (perhaps the only collector in the bottom one) should be connected to a volt meter (try analog and digital and try scope) and nothing else (no bulb) and see if you have ANY DC, even a small (millivolt) result is OK as that's real unexplainable by anything conventional, and while it might not look flash as having a few hundred volts at least you know you've got an anomaly.
This is pretty neat, basically a small coil of wire (or any continuous wire) connected to a volt meter is a weirdness detector, if it gives a reading that doesn't immediately vanish (which could otherwise be a low frequency induction) you've got an aether flow as nothing else known to science should be able to create a reading.
I can think of two ways thus far which may create a false positive that could be looked out for, one is that it might be that if you have AC which has more power behind it in one direction than the other, then maybe you will get a DC reading, I'm unsure.
The answer to this is not to pull any power. (no bulb)
The other other thought is that a diode in series or parallel or cap in parallel could give a false positive, so it might be best to stick to just wire and meter.
Groundloop
