Magnetic Permeability ... I can't find anyone talking about this !!!!!
Started by The Observer, June 02, 2008, 02:38:15 AM
TechStuf
QuoteSecondly, the magnetic field lines are not the way he draws them, conventional science is correct, Howard is wrong.
Conventional science is a shadow of it's former self.  Or, more accurately, a silhouette of a cobweb of a shadow....
HJ attempted to peel back but one of the myriad layers of our reality.  He was a bit ahead of his time.  He discovered that a magnetic field looks very different from the inside than out.  He also discovered, though only related such fact in so many words, that the 'skin of the onion' was very thin indeed, and that once penetrated, a magnetic field has a way of bursting out.....and changing itself to fit one's perspective.
HJ admirably maintained quite a balancing act while on the right track.  Problem was, he was never allowed to see the half of it.
God does not play dice with the universe.  He does however allow man to do so, which is why man is always rolling 'craps' for himself.  He has loved playing dice, when all he had to do the whole time was play NICE instead.
Blessings in Yeshua
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Xaverius
Hi Observer, I too have researched extensively the concept of permeability.  Like most of the posts here, I've found that a magnetic coil in a closed system such as a transformer or inductor is restricted in magnetic strength by CEMF or negative feedback.  I've found that it isn't really necessary to use exotic and expensive materials(Metglas, SuperMalloy, Hyperco, etc.) as long as the magnetic circuit is in a closed loop such as in a reluctance motor.  Most applications only require ur of about 200 which can be obtained at the local hardware store with ordinary steel such as 1010 or 1018.  It seems an electro-mechanical system produces the best efficiency such as is found in an electric motor. I have some facts and figures to illustrate this claim if you might be interested.  Just let me know.
nueview
Please do i am always interested as i may have missed something and could learn.
Martin
The Observer
Xaver,
Thanks for you comment.
You probably have done more experiments than me.
It would be great if you could post a simple synopsis of your findings here.
This is where I am currently at...
RISE TIME OF AIR CORE  vs.  RISE TIME OF FERRO CORE
                                     I know    t=L/R
                             And L of a coil = L*ur
   So for a Magnetic Permeability(ur) of say 10,000..
                                                               this means the rise time is 10,000 times longer !
             This really true?
I am going to get a signal generator in the near future to do some tests myself.
               The Observer
nueview
From what i have seen it can all be adjusted with the plate thickness and the plate gaping as well as the material used that is what saturable reactors are all about altering the B-H curve i have a good book on this from the 1930's and it goes into allot of detail.
Martin
