Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
0 Members and 27 Guests are viewing this topic.
Groundloop
@synchro1,
Said:
>>Bad news for grounloops new project.
Please explain in more detail why you think this setup won't work.
Do you have a magnetic simulator program? If yes, is it possible to
simulate this circuit?
Anybody with a magnetic simulator program out there?
Alex.
Bruce_TPU
Quote from: synchro1 on January 18, 2010, 04:18:25 PM
@Bruce,
Nice work! I realized that all one need to do is to increase the diameter of the middle disk neos between the toroids, to equal the strength of two stacks on each side and allow for the space needed to fit the toroids in between. Also, based on Paul Noel's idea of "Backdraft", it would be possible for the first air gaped armature to act as a middle magnet for a second larger parallel path apparatus, now coupled to a T shape, providing over ten times the flux force in the larger armature coil to one side. I also noticed your schematic has the second unwound armature on the other side. That one has to leave. The amplification of force by this kind of coupling presents a real solid chance to go overunity.
@Luc
Based on a study of Wesley Gary's analysis of the neutral zone and his application to the fluctuating armature on his pole shifting generator, there is one current generated when the armature is polarized, and another when the magnetic field colapses. There seems to be no advantage to re polarizing in the opposite direction, as the current generated the other way is the same as the first. Bad news for grounloop's new project. One way to zero is as good as pole reversal. With the coupling approach, half the pulses would yield five times the force to one side and save some burned out DPDT switches at the very least. One can see how a nano watt IC could switch giga Gauss of magnet force with enlargement and reduction of the bridge couplings scale. Perhaps a good power plant for a high voltage lifter. Also I believe the switching of the toroids would encounter less eddy interference then the standard Flynn magnetic wraps switched back and forth.
I plan to build and test this.  I have the pickup coil (Brooks coil) and will source out my steel, once I size everything out.  Cores are already on order, Metglas.  Magnets are on order, lot of them...LOL
I will post videos on youtube as I build it, as I am doing with my Steorn magnet motor.
Cheers,
Bruce
Bruce_TPU
Quote from: Groundloop on January 18, 2010, 06:31:41 PM
@synchro1,
Alex.
Hi Alex,
I actually like your drawing a lot.  It may indeed work.  We were simply discussing the "parallel Flux" path idea.  Supposedly, there is a "Flux magnification process" that happens.  This would be good news!
EDIT:
Is that a standing wave set up, having an inverted phase, that I see?   :D
Cheers,
Bruce
Groundloop
Bruce,
Yes. I already have the micro controller switch ready to go.
Need to wind the four new toroids. Will probably make this
circuit this weekend.
Alex.
synchro1
Groundloop,
Your schematic looks great. I don't have the program your talking about. I believe your MEG would generate the same amount of power if the magnets were unidirectional. It appears to me that your design would generate low ripple AC and require a full wave bridge rectifier to store. It also includes unnecessarily complex circuitry that would eat up power. I didn't say it wouldn't work. I'm merely pointing out that it might work more simply. Please move forward with your design, though, there are usefull applications for AC.
