This device is the real self-running overunity?
Started by Arthurs, May 17, 2010, 03:45:15 PM
Sprocket
Quote from: Gwandau on June 15, 2010, 06:53:26 PM
So I stress again, anyone into the quest of duplicating this discovery has to keep absolutely
rigidly to the original settings, any deviation is bound to result in no effect whatsoever.
And if we don't have the exact parameters needed to construct an exact replica, any attempt will be a waste of time.
First after a successful experiment with an exact replica will there be windows available for deviation experiments.
This is my own experience as a product developer and this is also common knowledge in any type of research.
Gwandau
With respect, deviate from what?  We have almost no definite info at all on doing an exact replication!  On the surface, this 'simple' setup looks easy to either prove or disprove (as the 1'st post of this thread suggests) - that is until you start trying to replicate it!   So, lack of information is the main problem...
NickZ
   @All:
  You should be able to see the magnet spin back as you manually pass it by the coils like is shown in the video. If they don't spin back and out of the way, thus altering the effect of that magnetic kick, they aren't working. Since that is what has to happen. Besides that, yes, very interesting the speed up effect as resonace kicks in, works just like magic.
   Magnetic bearings are not an optional in the operation.  That's my feeling, the key may not be in how smooth or friction-less they run, although important, but what happens when  All the magnets get working together, in perfect harmony along with resonace. Magnetic resonance is what is making up for the friction, and making it run with gain (entropy).  Airfoil of the wings,  keeps it in place, so it won't vibrate as much, since the flat disks won't work.   If it weren't for those videos, of the working device kicking in... who would of believed it?  My question is:  HOW LONG will it Run?  Magnets hang on the refrigerator for a long time, but, it seems like everything reaches an equilibrium after a while.
  Resonance might may not happen without the pick-up coils working together as a magnetic team, with the spinning magnets.  Follow the same method, as it took the guy quite a while to get to that point.
        NZ
gauschor
Thanks Sprocket, this helped me a lot. I think I found the reason why the LED did not work on my setup: my small coil has only 450 windings and therefore after calculating with the formula L = (µ*N²*A)/l I get only 0.005 Henry, which is much less than your 0.125 Henry. Using this formula and judging the length and diameter of your coil from your picture shows me that you have approximately 2035 windings. Thus I need to make a new coil with equal or more windings.
gauschor
Sprocket
Quote from: NickZ on June 16, 2010, 02:36:17 AM
   @All:
  You should be able to see the magnet spin back as you manually pass it by the coils like is shown in the video. If they don't spin back and out of the way, thus altering the effect of that magnetic kick, they aren't working......
There is no video showing this effect taking place, only Wendell's descriptions of what he thinks occurs while playing with the machine!  Moreover there is video evidence posted suggesting that it does NOT occur - Scotty1 I think posted it.
