Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
chrisC
Quote from: hartiberlin on July 02, 2010, 07:31:45 PM
Hi All,
this  is going more and more offtopic.
This is why I moved it to this directory.
If the device on page one is built and can be demonstrated ,
we can open up a new topic about it with detailed building descriptions.
In here the informations are too vague.
Regards, Stefan.
Great idea Stefan. Why should you pay for some delusional crap again and (again)!
cheers
chrisC
sm0ky2
for those americans that are wondering what HK$200 means.
its only about (US) $40 bucks, worth of materials that goes into this thing.
we just need some kind of shopping list, and  im sure theres many of us that would put this thing to the test.
Let's examine the 3 tests in the original postings.
if you think about a spring,  you put energy int the spring to compress it, then the spring gives you the same energy back as it expands.  Now, imagine, that after compressing the spring, you get a head start and take off in the opposite direction.
now the spring will give you a boost and push you along faster.
this is exactly what placing the magnet into the core does.
it acts as a spring.  While the source current is on, your input power compresses the spring (magnetic field).
When you turn it off, the field begins collapsing, then the magnet reorients its' field, and boosts the collapsing field out of its way.
meaning the "work" done on the coil is shortened in duration.
this is the 2nd scenerio in his original demonstration.
now, if you reverse the magnetic field.... you get the 3rd scenerio.
this is like a spring that stretches, then pulls back.
While your source current is "on", the current amplifies the magnetic field, it works with it to make a more powerful field, NOW,when you turn it off, the magnetic field has a head start, its already settling in its original position, while the EMF is still collapsing. thus the "work" done on the coil is increased in duration.
what is interesting is the time during the source pulse, where there is no "work" done on the core. this is the duration of time from when you turn the coil "on", until it reaches a strength greater than the already present magnetic field. however short, this is a % of your initial pulse., which, with using scenerio one as the control test, means that scenerio two has an increased input, and a decreased output. and that scenerio three has a decreased input, and increased output. scenerios two and three are , for all intensive purposes, the exact inverse of one another.
Entropy, and Neguentropy.
almost every mechanical thing we use today is engineered under the assumptions of Scenerio #2. you're homework for this evening is to write a 4 page essay about why.
class dismissed.
ltseung888
Quote from: sm0ky2 on July 02, 2010, 11:42:14 PM
if you think about a A,  you put energy int the spring to compress it, then the spring gives you the same energy back as it expands.  Now, imagine, that after compressing the spring, you get a head start and take off in the opposite direction.
this is like a spring that A, then pulls back.
class dismissed.
Without a good understanding of the Lead-out energy theory, the above is misleading.  I shall let Patrick Kelly help to do a layman explanation.  He can do a much better job than I.  I shall let the top researches at Hong Kong University, MIT, Stanford, Imperial College or Tsinghua University do the vigorous scientific papers.
I believe my three student helpers will finish the overunity FLEET experiments within 3 weeks.  The video should be ready shortly afterwards.
chrisC
Quote from: ltseung888 on July 04, 2010, 02:23:49 AM
I believe my three  helpers will finish the overunity FLEET experiments within 3 .  The video should be ready shortly afterwards.
Yawn....
ltseung888
Prayer Continued
Came back from Church and a to-be-completed temple.  The message is clear â€" benefit the World and NOT Lawrence Tseung.  We can have an experiment space at the to-be-completed temple.  The location is very close to the work place of my daughter.  That will be an advantage.
Tseung: “I am looking for a space to do the overunity FLEET experiment.  There must be good air circulation.  I need it for two to three weeks.”
Lee: “That is very difficult.  In Hong Kong, the average rental agreement is for at least two years.  If you rent a hotel room, it would be at least HK$1,000 a day.  They may not even let you do the soldering work.”
Roy: “I know just the place for you.  I am working on decorating a half-completed temple.  They stopped work waiting for donations.  You can have a temporary working space for a few weeks.  Just give a small donation.”
Tseung: “The Almighty works in wonderful ways.  Different religions help me at the same time.  I am more optimistic on the outcome now.”
