giantkiller
@mkt3920,
http://merlib.org/node/5508: in reference:
I see it now. The devices that work have a metallic sink somewhere on the device. In a motor this would the windings and the ferrous. In Deyos coil it would the conductors running along the sides. In Don Smith's PVC there is a coil facing charge bar that is positioned at 90 degrees to the coil windings. In the ECD there are conductors running along the sides. My latest pretty coils have a conductor running the circumerference and 90 degrees to the windings. The GK4 had conductors at 90 degrees to the control windings but on the inside. Bedini mentioned a very simple circuit that engineers could not understand.  Jaf Cleer of Biomod stated the same thing.
So what if the simplest thing is a Radiant/RE/Reactive producer having a sink near it. A metal object to absorb the high speed energy. I leave the physics to someone else. I am just trying to show a configuration pattern.
In the rotovertor the ferrous aids the resonant tank operation. And when saturated it then collects the cold energy like a fully charged cap that charges way past its rating with a ghost charge.
In coils the collecting run is connected to caps to hold the charge. Sounds too simple but in the examples posted here the conductivity of the conductor is slower that the impinging charge. This makes me think of a hyper charge carrier.
I am going to put a bobbin coil over that neon an see what I get.
11:11
have you tried to excite the flux,
in the TPU's iron primary coil,
using high frequency sound,
(speakers, electricity thought wet sand, or moving mechanical objects)
instead of high frequency electricity,
from a signal generator ?
frequency generators are an
expensive,
fragile,
bulky weakness.
which most normal human beings don't even know exists.
let alone find the justification to purchase.
but high frequency sound,
can be generated,
in many simple ways.
if you hit the iron primary coil,
with many different frequencies,
coming from 5 or 6 different sound-generation-sources,
than they might all combine together,
to create a much higher frequency,
inside the primary.
or maybe if you used two wire coils,
and a capacitor,
to make a tank circuit,
than the tank circuit could allow the existing frequency,
to super-oscillate,
under its own power.
i've read of people using simple coil/capacitor oscillators,
to create gigahertz of frequency.
cheap,
simple,
easy to repair parts,
will be required,
if a power source is ever going to become widespread.
otherwise,
the all-powerful-at-inhibiting economic obstacles,
will doom it to never be used.
if all of its parts,
other than maybe magnet wire,
cannot be found at a hardware store,
than that is a major weakness.
the average wage slave must not only understand how to build it,
but also be able to afford it.
forest
11:11
I'm 100% with you ! Totally agree! even capacitors can be home- made
giantkiller
Yep. This go around has a better set of configurations to test.
The coil on the neon with an LED didnt' do anyhting that I could tell. I will put a scope on it tonight. Time was short.
