Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 93 Guests are viewing this topic.
chrisC
Quote from: rave154 on September 25, 2010, 09:20:57 AM
oh dear.......chris....now i see..
hes basing his outputs wattage and therefore his COP.....on the peak voltage & peak current
The gentleman has no concept of how to measure power. To him, peak values is all you need to prove O.U. What a dork!
cheers
chrisC
ltseung888
Quote from: nievesoliveras on September 27, 2010, 07:23:59 PM
For the circuit collectors
The ? is just a LED as in the standard Joule Thief circuits.  Thanks for tidying it up.
This circuit is being reproduced for the Unviersities in Hong Kong, China and USA.  Much more could have been done.  But the decision is to keep things simple.  As long as the results can demonstrate overunity, no addistional components will be added.  The actual experiment values vary as the toroids are hand wound; the components are hand soldered; the parts are purchased at the lowest price with no quality guarantee.  The skill of the person also makes significant differences.  I shall show the result of every prototype targeted for USA.
ltseung888
A marginal Prototype
The prototype used a thicker (0.5 inch) one inch toroid.  The result was very poor.  I had to put two 1 K ohm resistors in parallel in the Joule Thief to get it to light up the two LEDs.
The Output Power = 0.58 watt
COP = 2
(based on peak-to-peak)
This shows that slight changes make big difference as expected in resonance hunting environment.
Paul-R
Quote from: Pirate88179 on September 26, 2010, 02:30:47 PM
This is exactly correct.  The amp draw was 10,000 times higher for that brief amount of time.
Cap to cap will tell the tale, one way or the other.
Yes, but watch rated voltage.
rave154
Since Tseung plans to light an entire christmas tree lights... and since he hasnt plaigersied bedini's work yet ( has he? )...
perhaps the attatched circuit might be just what hes looking for.
Please note, when constructing this circuit it is essential that only the illustrated load tree will work as placing any other device will ruin the "resonance".
Also note that the Elf's MUST be Lead-Out Energy Elf's....using any other type will result in failure to find OU with this circuit. You can just about any transistor you wish as long as its coloured red & green.
Also please note, the red & green pattern of the Elf's hats are in sync, while the red & green pattern of their socks are 180 degrees out of phase, this is ESSENTIAL in order to Lead Out the electron Motion energy.
