A Test to Prove Gravity Has Mass
Started by brian334, June 01, 2011, 04:39:08 PM
AB Hammer
Quote from: onthecuttingedge2010 on June 02, 2011, 08:22:59 PM
I am sorry but I don't buy into this gravity being a pushing force. no reputable scientist would either.
Well lets look at it this way. This falls into the common belief category. But how will their common belief hold up to a running gravity wheel. They can not fully explain gravity. At least most do admit that. The accepted belief is it pulls. But explain water in so called zero gravity. does it disperse? No it holds to together. What causes it to hold together?  Watch this video and ask. Is it having it's own gravity or is there an outside force holding it together?
http://www.youtube.com/watch?v=T4JrhW2aO6I&feature=related
We truly don't know gravity but we have an idea about gravity. Either way it keeps us on the ground.
Alan
With out a dream, there can be no vision.
Alan
Quote from: AB Hammer on June 02, 2011, 09:52:22 PM
Well lets look at it this way. This falls into the common belief category. But how will their common belief hold up to a running gravity wheel. They can not fully explain gravity. At least most do admit that. The accepted belief is it pulls. But explain water called in Zero space. does it disperse? No it holds to together. What causes it to hold together?  Watch this video and ask. Is it having it's own gravity or is there an outside force holding it together?
Alan
I have watched every single NASA feed there ever was, the waters surface tension is stronger than any gravitational force at that distance from earth.
AB Hammer
Quote from: onthecuttingedge2010 on June 02, 2011, 09:56:25 PM
Well then there needs to be a test of the water close to a larger mass and see if it gravitates towards it and spread out on it? Have they done this test? surface tension is a good possible answer. But when they put the tablet in it I have to second guess it, for here on earth it brakes up surface tension. My fact is I can't say one way or the other. But there are still many questions that need to be answered.
Alan
Alan
gravityblock
Actually at that distance from the earth, the gravitational force is still 90-95%.  They're in a free-fall weightless environment and not free from the gravitational force.  The waters surface tension being stronger than the gravitational force of the earth at that distance is a poor argument since the gravitational force isn't much weaker at that distance than it is at the surface of the earth.  Planes following a parabolic path to create a weightless environment at a much closer distance to the earth with little to no difference in the gravitational force as compared to the surface of the earth (near 100%), will also show the water holding itself together, thus making your argument even less plausible.  The most rational explanation is a universal centripetal pressure holding the water together, thus gravity could be a pushing force.
GB
GB, I smell the strong effervescent of horse shit in the air, if you really believe in this then you are welcome to roll around in it.
you will fail with your theory, completely.
I predict that in the future you will become a laughing stock among this forum.
they will have laughs about you for some time to come because you were so diligently wrong.
you offer no math to prove our predecessors wrong, nothing with taste, texture, or fulfillment nor color.
your quazen is quite distasteful.
Jerry 8)
