Romero's experiments and OU principles
Started by plengo, June 10, 2011, 08:26:08 PM
romerouk
Quote from: neptune on June 16, 2011, 11:25:08 AM
@Romerouk . Many thanks for answering some of my questions .And woopy`s question . Referring to Woop`s question , can you confirm that when you added the 5mm magnets on the rotor , you added them in attraction and not in repel mode . Thanks .
attraction is what i used mainly for one of the driver coils that used the side magnets to trigger.the other one having the hall on top used attraction too but a bit of replusion at the same time.
woopy
Thank's Romero
for sake of good understanding
i made a small drawing
so it is    A or B   and if A are they all sme pole outwards or alternating ?
Many thank's
Laurent
romerouk
woopy
Thank's Romero
everything clear now
@ EM
I have refound the nice gif of the MOON effect it is at page 18 post 265 from Freeenergyinfo (in the muller dynamo thread )
http://www.overunity.com/index.php?action=dlattach;topic=3842.0;attach=52567
Sorry the above link is not animated (it does not work as a copy ) but go on the page 18 and you can see it spinning.
good luck at all
Laurent
Magluvin
Quote from: woopy on June 16, 2011, 10:00:41 AM
Hi EM  and peter
That's what i call an out of the box idea.
And yes it interests me a lot
I don't know where we go with it but i have made some test.
Here the scope shot of the both driving coil.
The first is the long pulse of the Hall sensor pointing on the big rotor magnet. As you can see the pulse is about in phase with the generative trace of the motor coils.
The second pix is the "retaining " motor drive , triggered by the very small magnet. The pulse is very short and out of the phase of the generative trace of the motor coil.
To be very clear if i separate the 2 driving coils , each one will spin the rotor in counter direction, and both are in attraction mode as per EM drawing some post earlier.
The motor works well like this, so i will go on the test.
For me it is very clear that the Romero machine consume a very high current in the no load situation. Why ?
For example my motor can go to 1200 rpm with both driving coil working in the same direction with about 150 ma (and less ) at 12 volts.
and with the 2 coils working in opposition i never get that speed and consume arround 350 to 450 ma.
And i have exactly the same rotor dimension as Romero.
So i think this 2 driving coils in opposition is to be investigated ,and also we have to remember  the MOON effect (this very fast optical second pass (which spins in counter direction of the rotor ) we discussed at the beginning of the Romero muller thread ) there was a animated gif but i can not find it, perhaps somebody can recall of  it ?
Anyway bravo EM i will follow your development.
Today my litz wire arrived (by feet from England after  5 week of patience ) so back to the workshop and coil coil coil...
Hope this helps
Good luck at all
Hey Woopy
Have you tried a free wheel diode on your drive coils? It should increase speed with the timing you have, or allow you to reduce the on time and get the same speed, and use less current.  ;]  Your doing good work here. =)
Mags
