PhysicsProf Steven E. Jones circuit shows 8x overunity ?
Started by JouleSeeker, May 19, 2011, 11:21:55 PM
conradelektro
Quote from: hartiberlin on June 26, 2011, 06:23:01 PM
P.P.S: When tuning the circuit we tested today at Per-Johan´s place, I saw, that it works like a Joule Ringer circuit.
Changing the Base current pot just changes the frequency of the Spikes and the waveforms looks very simular to the waveforms of a JouleRinger.
The 3rd coil on the core is the easiest way to get rid of the different DC level problems when you want to feedback the output to the input.
Regards, Stefan.
@Stefan: I like Per-Johan's idea (the third coil on the toroid). May be Per-Johan is willing to provide more details of his circuit (value of capacitor and resistor at the base of the transistor, which transistor, number of wire turns on the toroid).
Greetings, Conrad
conradelektro
Quote from: xee2 on June 29, 2011, 12:34:34 AM
2 uA Joule thief. Video at >>>  http://www.youtube.com/watch?v=8T9HQkDnIuU&feature=mfu_in_order&list=UL
@xee2: may be one can combine Per-Johan's idea (third coil on the toroid with full bridge rectifier) and your low power JT circuit in order to feed back power to the 10.000µF capacitor? This should reduce the power consumption even more.
Greetings, Conrad
nul-points
Quote from: JouleSeeker on June 28, 2011, 08:22:45 PM
  I found it!  I must say, Nul-Pts always provides intriguing posts, and I found this in a posting of his in May
Nul-points post, and if you care to comment further NP, I'm all ears!!
thanks for the kind words as always, Steven...
i'll just bask in those words a little longer - before having to point out that your quote about OU statistics must have been posted by someone** other than me!  :)
[EDIT:  ** it was by toranarod]
here is my contribution to the list of reported OU development, hopefully with a reasonably mainstream emphasis:-
rauen
http://www.peswiki.com/index.php/Directory:Rauen_Environmental_Heat_Engine
sheenan
http://paradigmcontent.s3.amazonaws.com/paradigm%20magazine%20article.pdf
dragone
http://www.overunity.com/index.php?action=dlattach;topic=3842.0;attach=52700
turtur
http://www.wbabin.net/physics/turtur1e.pdf
kanarev
http://pesn.com/2010/10/13/9501712_Kanarev_announces_self-running_motor-generator/
rossi
http://en.wikipedia.org/wiki/Energy_Catalyzer
these are just a sample, or review, of some of the work which these people have been doing
thanks
np
http://docsfreelunch.blogspot.com
nul-points
Quote from: xee2 on June 29, 2011, 12:57:53 AM
energy calculation for 2 uA Joule thief:
10,000 uF capacitor
start voltage = 1.358
end voltage = 0.599
time = 84 minutes = 84 * 60 seconds = 5040 sec.
Joules = 0.5*C*(V1^2 - V2^2) = 0.5*10000e-6*(1.358^2 - 0.599^2) = 0.0074
watts = Joules / seconds = 0.0074 / 5040 =  1.468 uW
hi Xee2
this result based on a start voltage of 1.3V and an end voltage of 0.6V, along with the previous test runs we did from 1.5V (?) to 1.1V, really highlights how the power consumption falls with supply voltage
you can see that your initial continuous DC Power in at 1.36V & 2mA is 2.72uW, yet your overall average is 1.47uW
obviously the lower the end voltage, the lower the average DC power value that we'll measure for a particular test
hence Steven's guideline of a voltage range between 2.55V and 1.5V  for reference purposes (also, using 1000uF caps, for direct time comparisons, of course)
nul-points
Quote from: conradelektro on June 29, 2011, 02:58:58 AM
Greetings, Conrad
hi Conrad
the tertiary winding approach looks good, but my experiences with it (posted earlier in this thread, post #163, 3rd Jun'11) suggest that it's main benefit is in decoupling the pulse o/p from the DC biasing necessary for the oscillator
(see first schematic below)
the most 'efficient' config i've been able to achieve has been to use a different approach to Looping and DC Decoupling and remove the tertiary winding altogether
(see second schematic below)
utilising both +ve & -ve o/p pulses also gave an increase in input current draw, so having a FWBR on the o/p (with the additional loss in forward voltage drops of 2 diodes, rather than a half-wave rectifier) doesn't appear to be a good way to go (in this circuit)
hope this helps
np
